这是第一次弄全志soc和linux,一路跟着tina的文档走,前面调试rgb屏测试ok,不过后面想用i80接口,结果这几天折腾,没折腾明白,网上没找到对应的(有其他的,但没看明白,实力限制……),发个帖求助下大佬们,因为初次搞这个,操作步骤粗鄙不堪入目之处,请多多见谅,后面可以多给小弟批评指正下,多谢!
进入系统后,启动日志:
[34]HELLO! BOOT0 is starting!
[37]BOOT0 commit : 88480af
[40]set pll start
[42]periph0 has been enabled
[44]set pll end
[46][pmu]: bus read error
[48]board init ok
[50]ZQ value = 0x30
[52]get_pmu_exist() = -1
[54]DRAM BOOT DRIVE INFO: V0.33
[57]DRAM CLK = 528 MHz
[59]DRAM Type = 2 (2:DDR2,3:DDR3)
[62]DRAMC read ODT off.
[65]DRAM ODT off.
[67]ddr_efuse_type: 0xa
[69]DRAM SIZE =64 M
[71]dram_tpr4:0x0
[73]PLL_DDR_CTRL_REG:0xf8002b00
[76]DRAM_CLK_REG:0xc0000000
[78][TIMING DEBUG] MR2= 0x0
[83]DRAM simple test OK.
[85]dram size =64
[87]spinor id is: ef 40 19, read cmd: 0b
[90]Succeed in reading toc file head.
[94]The size of toc is 10c000.
[273]Entry_name = opensbi
[276]Entry_name = u-boot
[280]Entry_name = dtb
[282]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-1-g771d82e
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x41fc0400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000041fc0000-0x0000000041fdffff (A)
PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3 : 0x0000000000020000-0x0000000000027fff (A,▒
U-Boot 2018.05-g2a1965a (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
[00.367]DRAM: 64 MiB
[00.369]Relocation Offset is: 01ed9000
[00.374]secure enable bit: 0
[00.377]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.383]flash init start
[00.385]workmode = 0,storage type = 3
[00.392]spi sunxi_slave->max_hz:100000000
SF: write offset not multiple of erase size
[01.109]spi sample_mode:1 sample_delay:1d
[01.114]spi sunxi_slave->max_hz:100000000
SF: Detected w25q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
[01.126]sunxi flash init ok
[01.128]line:703 init_clocks
[01.131]drv_disp_init
request pwm success, pwm7:pwm7:0x2000c00.
fdt get node offset faill: hdmi
[01.149]unable to map hdmi registers
[01.152]drv_disp_init finish
[01.156]Loading Environment from SUNXI_FLASH... OK
[01.170]boot_gui_init:start
[01.173]set disp.dev2_output_type fail. using defval=0
[01.180]boot_gui_init:finish
partno erro : can't find partition bootloader
** Unrecognized filesystem type **
[01.190]sunxi bmp info error : unable to open logo file bootlogo.bmp
[01.196]out of usb burn from boot: not need burn key
[01.201]get secure storage map err
partno erro : can't find partition private
root_partition is rootfs
set root to /dev/mtdblock5
[01.212]update part info
[01.215]update bootcmd
[01.217]change working_fdt 0x42a98da0 to 0x42a78da0
disable nand error: FDT_ERR_NOTFOUND
No reserved memory region found in source FDT
[01.247]update dts
noncached_alloc(): addr = 0x42ae8480
noncached_alloc(): addr = 0x42ae84c0
noncached_alloc(): addr = 0x42ae8500
noncached_alloc(): addr = 0x42ac27c0
geth_sys_init:639: get node 'gmac0' error
geth_sys_init fail!
[01.267]Board Net Initialization Failed
[01.271]No ethernet found.
Hit any key to stop autoboot: 1 FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1
[01.370]LCD open finish 0
[02.417]no vendor_boot partition is found
Android's image name: f133-mq_r
Detect comp none
[02.433]
[ 0.000000] Linux version 5.4.61 (test@test-virtual-machine) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #102 PREEMPT Wed Jul 17 03:01:59 UTC 2024
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x0000000043ffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000043ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] DMA32 zone: 224 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 16384 pages, LIFO batch:3
[ 0.000000] elf_hwcap is 0x20112d
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16160
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock5 rootfstype=squashfs init=/pseudo_init partitions=boot-resource@mtdblock1:env@mtdblock2:env-redund@mtdblock3:boot@mtdblock4:rootfs@mtdblock5:UDISK@mtdblock6 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=3 androidboot.boot_type=3 gpt=1 uboot_message=2018.05-g2a1965a(07/10/2022-02:50:57) mbr_offset=1556480
[ 0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000000] Sorting __ex_table...
[ 0.000000] Memory: 56072K/65536K available (3963K kernel code, 419K rwdata, 1676K rodata, 136K init, 222K bss, 9464K reserved, 0K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
[ 0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000027] riscv_timer_clockevent depends on broadcast, but no broadcast function available
[ 0.000363] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000925] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000945] pid_max: default: 32768 minimum: 301
[ 0.001116] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.001139] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.003003] ASID allocator initialised with 65536 entries
[ 0.003180] rcu: Hierarchical SRCU implementation.
[ 0.003869] devtmpfs: initialized
[ 0.022074] random: get_random_u32 called from bucket_table_alloc.isra.27+0xfa/0x11c with crng_init=0
[ 0.022946] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.022978] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.023140] pinctrl core: initialized pinctrl subsystem
[ 0.024565] NET: Registered protocol family 16
[ 0.025315] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.025902] cpuidle: using governor menu
[ 0.064749] rtc_ccu: sunxi ccu init OK
[ 0.073056] clock: sunxi ccu init OK
[ 0.074810] clock: sunxi ccu init OK
[ 0.103572] iommu: Default domain type: Translated
[ 0.103766] sunxi iommu: irq = 4
[ 0.104930] SCSI subsystem initialized
[ 0.105150] usbcore: registered new interface driver usbfs
[ 0.105234] usbcore: registered new interface driver hub
[ 0.105340] usbcore: registered new device driver usb
[ 0.106322] Advanced Linux Sound Architecture Driver Initialized.
[ 0.107207] pwm module init!
[ 0.108815] g2d 5410000.g2d: Adding to iommu group 0
[ 0.109329] G2D: rcq version initialized.major:252
[ 0.109940] clocksource: Switched to clocksource riscv_clocksource
[ 0.121725] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.124830] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[ 0.125661] NET: Registered protocol family 2
[ 0.126536] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.126591] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.126609] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.126624] TCP: Hash tables configured (established 512 bind 512)
[ 0.126791] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.126837] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.127072] NET: Registered protocol family 1
[ 0.128254] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.128875] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.129124] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
[ 0.129193] sunxi_spi_resource_get()2163 - sample_mode:1 sample_delay:29
[ 0.129250] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
[ 0.130225] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base ffffffd00405a000, irq 31
[ 0.132323] workingset: timestamp_bits=62 max_order=14 bucket_order=0
[ 0.137849] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.138093] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.138379] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.138752] fuse: init (API version 7.31)
[ 0.159206] io scheduler mq-deadline registered
[ 0.159222] io scheduler kyber registered
// disp初始化
[ 0.160168] [DISP]disp_module_init
[ 0.160764] disp 5000000.disp: Adding to iommu group 0
[ 0.161372] [DISP] disp_init,line:2386:
[ 0.161379] smooth display screen:0 type:1 mode:4
// lcd初始化
[ 0.161519] lcd_init
[ 0.162442] display_fb_request,fb_id:0
[ 0.164044] [DISP] Fb_copy_boot_fb,line:1505:
[ 0.164052] src_height(480) > dst_height(240),please cut the height
[ 0.164566] disp_al_manager_apply ouput_type:1
[ 0.164686] lcd_clk_config
[ 0.164714] [DISP] lcd_clk_config,line:895:
[ 0.164724] disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
[ 0.164724] clk real:pll(297000000),clk(288000000),dclk(0) dsi_rate(0)
[ 0.165384] [DISP]disp_module_init finish
// 初始化完成
[ 0.166269] sunxi_sid_init()551 - insmod ok
[ 0.166844] pwm-regulator: supplied by regulator-dummy
[ 0.168566] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.169052] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.169458] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
[ 0.169485] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[ 0.901824] printk: console [ttyS0] enabled
[ 0.907650] misc dump reg init
[ 0.912094] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.923384] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.930643] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.937997] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.945427] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.951966] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.958911] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.966651] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.974595] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 0.982747] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.990495] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.997223] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 1.004867] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 1.013067] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 1.020810] [ADDR_MGT] addr_mgt_probe: success.
[ 1.027372] spi-nor spi0.0: w25q256 (32768 Kbytes)
[ 1.037933] 7 sunxipart partitions found on MTD device spi0.0
[ 1.044469] Creating 7 MTD partitions on "spi0.0":
[ 1.049818] 0x000000000000-0x000000180000 : "uboot"
[ 1.060809] 0x000000180000-0x000000190000 : "boot-resource"
[ 1.080774] 0x000000190000-0x0000001d0000 : "env"
[ 1.090766] 0x0000001d0000-0x000000210000 : "env-redund"
[ 1.110713] 0x000000210000-0x000000990000 : "boot"
[ 1.120792] 0x000000990000-0x000001110000 : "rootfs"
[ 1.140711] 0x000001110000-0x000002000000 : "UDISK"
[ 1.151730] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.162746] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.173538] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.184770] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.190542] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.201147] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T01:48:07 UTC (6487)
[ 1.210372] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.216333] sunxi cedar version 1.1
[ 1.220563] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.226850] VE: install start!!!
[ 1.226850]
[ 1.232424] VE: cedar-ve the get irq is 6
[ 1.232424]
[ 1.238767] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
[ 1.238767]
[ 1.250410] VE: install end!!!
[ 1.250410]
[ 1.255457] VE: sunxi_cedar_probe
[ 1.260173] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.270510] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
[ 1.280594] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 1.286778] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 1.293187] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 1.299594] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 1.306032] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 1.312599] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 1.319103] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 1.325677] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 1.332240] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.341805] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.352957] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 1.373154] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.397401] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 1.405082] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[ 1.412215] ashmem: initialized
[ 1.415741] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[ 1.422620] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.434591] exFAT: Version 1.3.0
[ 1.443037] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.454731] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 1.454731]
[ 1.472032] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 1.483505] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 1.491683] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 1.499335] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 1.506756] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 1.516485] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 1.523390] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 1.530012] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 1.536801] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.550507] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 1.561940] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
[ 1.574246] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 1.583699] NET: Registered protocol family 10
[ 1.590012] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 1.597568] Segment Routing with IPv6
[ 1.601987] NET: Registered protocol family 17
[ 1.608786] HDMI 2.0 driver init start!
[ 1.613210] boot_hdmi=false
[ 1.616379] ERROR: can not get hdmi_cts_compatibility
[ 1.622072] ERROR: pinctrl_get for HDMI2.0 DDC fail
[ 1.627539] ERROR: can not get ddc_en_io_ctrl
[ 1.632453] ERROR: can not get hdmi_power_cnt
[ 1.638751] HDMI2.0 module init end
[ 1.669910] UBI error: cannot open mtd sys, error -2
[ 1.675558] UBI: block: can't open volume on ubi0_-1, err=-19
[ 1.683395] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.693150] clk: Not disabling unused clocks
[ 1.697919] ALSA device list:
[ 1.701304] cfg80211: failed to load regulatory.db
[ 1.706688] #0: audiocodec
[ 1.710043] alloc_fd: slot 0 not NULL!
[ 1.718663] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 1.731227] devtmpfs: mounted
[ 1.734722] Freeing unused kernel memory: 136K
[ 1.739673] This architecture does not have kernel memory protection.
[ 1.746982] Run /pseudo_init as init process
[ 1.764008] random: fast init done
mount: mounting none on /dev failed: Device or resource busy
[ 3.071008] MTD: Couldn't look up '/dev/by-name/rootfs_data': -2
mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such file or directory
Mount Failed: formating /dev/by-name/rootfs_data to jffs2 ...
mkfs.jffs2: error!: Unrecognisable erase size
------run rc.preboot file-----
[ 3.610097] jffs2: notice: (99) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
------run rc.modules file-----
[ 3.707454] random: crng init done
[ 5.239976] hdmi_hpd_sys_config_release
[ 20.156128] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[ 20.267209] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
[ 20.273730] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 20.294444] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 20.314953] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 20.340686] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 20.356451] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 20.370895] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
[ 20.390608] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 20.403338] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 20.416776] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 20.431008] mmc0: new high speed SDIO card at address 0001
[ 31.849997] pio-18: disabling
[ 31.853340] pio-33: disabling
[ 31.856647] usb1-vbus: disabling
------run rc.final file-----
------run profile file-----
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 5C1C9C53)
nodev debugfs
root@TinaLinux:/# [ 34.165790] file system registered
[ 34.207543] configfs-gadget 4100000.udc-controller: failed to start g1: -19
sh: write error: No such device
[ 34.268250] read descriptors
[ 34.272099] read strings
[ 34.437927] sunxi_set_cur_vol_work()485 WARN: get power supply failed
[ 34.509331] configfs-gadget gadget: high-speed config #1: c
root@TinaLinux:/# lcd初始化部分,设备树设置的320*240,不知道这里fb的800哪里来的
然后查看disp的sys信息
root@TinaLinux:/# cat /sys/class/disp/disp/attr/sys
screen 0:
de_rate 300000000 hz, ref_fps:-1
mgr0: 0x0 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[1] force_sync[0] unblank direct_show[false] iommu[1]
dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[32]
lcd output backlight( 0) fps:60.2 0x 0
err:12387 skip:86 irq:12389 vsync:0 vsync_skip:0
BUF enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[ 0] fb[ 320, 240; 320, 240; 320, 240] crop[ 0, 0, 320, 240] frame[ 0, 0, 800, 480] addr[fff80000, 0, 0] flags[0x 0] trd[0,0]
depth[ 0] root@TinaLinux:/#
root@TinaLinux:/#可以看到mgr0是0x0,后面frame又是800x480,有问题,但不知出在哪儿……前面rgb屏frame也是这样,不过我用测试代码修改了fb_var_screeninfo才行
切换到dispdbg,用suspend命令
root@TinaLinux:/# cd /sys/kernel/debug/dispdbg/
root@TinaLinux:/sys/kernel/debug/dispdbg# echo disp0 > name
root@TinaLinux:/sys/kernel/debug/dispdbg# echo suspend >command
root@TinaLinux:/sys/kernel/debug/dispdbg# echo 1 >start
[ 1170.840215] disp_suspend
[ 1170.843048] [DISP] disp_lcd_disable,line:2369:
[ 1170.843053] lcd_panel_fun[0](--).cfg_close_flow is NULL
[ 1170.870085] disp_suspend finish
root@TinaLinux:/sys/kernel/debug/dispdbg# lcd_panel_fun0.cfg_close_flow is NULL这个搞的有点蒙,在lcdpanel里,这里cfg_close_flow是有的,不知道这里为啥是个NULL,另外lcd_panel_fun0这里括号,是我在源码
lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/de/disp_lcd.c----->disp_lcd_disable中改的
DE_WRN("lcd_panel_fun[%d](%s--%s).cfg_close_flow is NULL\n", lcd->disp,lcdp->panel_info.lcd_model_name,lcdp->panel_info.lcd_driver_name);但似乎,都是空值,所以是不是驱动挂的不是指定的panel呢?
下面是我添加驱动到配置的具体步骤,新手操作,粗鄙难入眼之处,请多担待……
根据手头的Tina的开发文档,及自己的理解,我分为以下几个步骤:
在lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/路径添加ili9341_80.c和ili9341_80.h
如下,c文件
* drivers/video/fbdev/sunxi/disp2/disp/lcd/ili9341/ili9341.c
* Copyright (c) 2007-2018 Allwinnertech Co., Ltd.
* Author: zhengxiaobin <zhengxiaobin@allwinnertech.com>
* This software is licensed under the terms of the GNU General Public
* License version 2, as published by the Free Software Foundation, and
* may be copied, distributed, and modified under those terms.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
[lcd0]
lcd_used = 1
lcd_driver_name = "ili9341"
lcd_x = 240
lcd_y = 320
lcd_width = 108
lcd_height = 64
lcd_dclk_freq = 60
lcd_pwm_used = 0
lcd_pwm_ch = 0
lcd_pwm_freq = 50000
lcd_pwm_pol = 1
lcd_pwm_max_limit = 255
lcd_hbp = 20
;10 + 20 + 10 + 240*3 = 760 real set 1000
lcd_ht = 1000
lcd_hspw = 10
lcd_vbp = 5
lcd_vt = 340
lcd_vspw = 2
lcd_frm = 0
lcd_if = 0
lcd_hv_if = 8
lcd_hv_clk_phase = 0
lcd_hv_sync_polarity = 0
lcd_hv_srgb_seq = 0
lcd_io_phase = 0x0000
lcd_gamma_en = 0
lcd_bright_curve_en = 1
lcd_cmap_en = 0
lcd_rb_swap = 0
deu_mode = 0
lcdgamma4iep = 22
smart_color = 90
;reset
lcd_gpio_0 = port:PD16<1><0><default><1>
lcdd2 = port:PD00<2><0><2><default>
lcdd3 = port:PD01<2><0><2><default>
lcdd4 = port:PD02<2><0><2><default>
lcdd5 = port:PD03<2><0><2><default>
lcdd6 = port:PD04<2><0><2><default>
lcdd7 = port:PD05<2><0><2><default>
lcdd10 = port:PD06<2><0><2><default>
lcdd11 = port:PD07<2><0><2><default>
lcdd12 = port:PD08<2><0><2><default>
lcdd13 = port:PD09<2><0><2><default>
lcdd14 = port:PD10<2><0><2><default>
lcdd15 = port:PD11<2><0><2><default>
lcdd18 = port:PD12<2><0><2><default>
lcdd19 = port:PD13<2><0><2><default>
lcdd20 = port:PD14<2><0><2><default>
lcdd21 = port:PD15<2><0><2><default>
lcdclk = port:PD18<7><0><3><default>
lcdde = port:PD19<7><0><3><default>
lcdhsync = port:PD20<7><0><3><default>
lcdvsync = port:PD21<7><0><3><default>
#include "ili9341_80.h"
#define CPU_TRI_MODE
#define ili9341c_spi_reset_1 sunxi_lcd_gpio_set_value(0, 0, 1)
#define ili9341c_spi_reset_0 sunxi_lcd_gpio_set_value(0, 0, 0)
static void lcd_panel_ili9341_init(struct disp_panel_para *info);
static void LCD_power_on(u32 sel);
static void LCD_power_off(u32 sel);
static void LCD_bl_open(u32 sel);
static void LCD_bl_close(u32 sel);
static void LCD_panel_init(u32 sel);
static void LCD_panel_exit(u32 sel);
extern s32 tcon0_cpu_set_tri_mode(u32 sel);
void write_tcon_register(int offset, int value)
volatile int *tcon_reg = (int *)(0xf1c0c000 + offset);
int reg = 0;
reg = *((volatile int *)tcon_reg);
reg |= value;
*((volatile int *)tcon_reg) = reg;
static void lcd_cfg_panel_info(struct panel_extend_para *info)
u32 i = 0, j = 0;
u32 items;
u8 lcd_gamma_tbl[][2] = {
//{input value, corrected value}
{0, 0}, {15, 15}, {30, 30}, {45, 45}, {60, 60},
{75, 75}, {90, 90}, {105, 105}, {120, 120}, {135, 135},
{150, 150}, {165, 165}, {180, 180}, {195, 195}, {210, 210},
{225, 225}, {240, 240}, {255, 255},
u32 lcd_cmap_tbl[2][3][4] = {
{LCD_CMAP_G0, LCD_CMAP_B1, LCD_CMAP_G2, LCD_CMAP_B3},
{LCD_CMAP_B0, LCD_CMAP_R1, LCD_CMAP_B2, LCD_CMAP_R3},
{LCD_CMAP_R0, LCD_CMAP_G1, LCD_CMAP_R2, LCD_CMAP_G3},
{LCD_CMAP_B3, LCD_CMAP_G2, LCD_CMAP_B1, LCD_CMAP_G0},
{LCD_CMAP_R3, LCD_CMAP_B2, LCD_CMAP_R1, LCD_CMAP_B0},
{LCD_CMAP_G3, LCD_CMAP_R2, LCD_CMAP_G1, LCD_CMAP_R0},
items = sizeof(lcd_gamma_tbl) / 2;
for (i = 0; i < items - 1; i++) {
u32 num = lcd_gamma_tbl[i + 1][0] - lcd_gamma_tbl[i][0];
for (j = 0; j < num; j++) {
u32 value = 0;
value =
lcd_gamma_tbl[i][1] +
((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1]) *
j) /
num;
info->lcd_gamma_tbl[lcd_gamma_tbl[i][0] + j] =
(value << 16) + (value << 8) + value;
info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) +
(lcd_gamma_tbl[items - 1][1] << 8) +
lcd_gamma_tbl[items - 1][1];
memcpy(info->lcd_cmap_tbl, lcd_cmap_tbl, sizeof(lcd_cmap_tbl));
static s32 lcd_open_flow(u32 sel)
LCD_OPEN_FUNC(sel, LCD_power_on, 40);
#ifdef CPU_TRI_MODE
LCD_OPEN_FUNC(sel, LCD_panel_init, 50);
LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50);
#else
LCD_OPEN_FUNC(sel, LCD_bl_open, 0);
static s32 lcd_close_flow(u32 sel)
LCD_CLOSE_FUNC(sel, LCD_bl_close, 50);
#ifdef CPU_TRI_MODE
LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 10);
LCD_CLOSE_FUNC(sel, LCD_panel_exit, 10);
#else
LCD_CLOSE_FUNC(sel, LCD_power_off, 10);
sunxi_lcd_power_enable(sel, 0);
sunxi_lcd_pin_cfg(sel, 1);
sunxi_lcd_pin_cfg(sel, 0);
sunxi_lcd_power_disable(sel, 0);
sunxi_lcd_pwm_enable(sel);
/*config lcd_bl_en pin to open lcd backlight*/
sunxi_lcd_backlight_enable(sel);
/*config lcd_bl_en pin to close lcd backlight*/
sunxi_lcd_backlight_disable(sel);
sunxi_lcd_pwm_disable(sel);
static void LCD_WRITE_DATA(u32 value)
sunxi_lcd_cpu_write_data(0,value&0xFFFF);
static void LCD_WRITE_COMMAND(u32 value)
sunxi_lcd_cpu_write_index(0,value&0xFFFF);
struct disp_panel_para *info =
kmalloc(sizeof(struct disp_panel_para), GFP_KERNEL | __GFP_ZERO);
bsp_disp_get_panel_info(sel, info);
lcd_panel_ili9341_init(info);
kfree(info);
return;
LCD_WRITE_COMMAND(0x28);
LCD_WRITE_COMMAND(0x10);
sunxi_lcd_delay_ms(300);
kfree(info);
return;
//************* Start Initial Sequence **********//
//************* Reset LCD Driver ****************//
ili9341c_spi_reset_1;
sunxi_lcd_delay_ms(1);
ili9341c_spi_reset_0;
/*Delay 10ms This delay time is necessary*/
sunxi_lcd_delay_ms(10);
/*Delay 120 ms*/
sunxi_lcd_delay_ms(120);
/************** Start Initial Sequence ***********/
/*Pixel Format Set*/
LCD_WRITE_COMMAND(0x3A);
LCD_WRITE_DATA(0x55);
LCD_WRITE_COMMAND(0xF6);
LCD_WRITE_DATA(0x01);
LCD_WRITE_DATA(0x33);
LCD_WRITE_COMMAND(0xB5);
LCD_WRITE_DATA(0x04);
LCD_WRITE_DATA(0x0A);
LCD_WRITE_DATA(0x14);
LCD_WRITE_COMMAND(0x35);
LCD_WRITE_DATA(0x00);
LCD_WRITE_COMMAND(0xCF);
LCD_WRITE_DATA(0xEA);
LCD_WRITE_DATA(0xF0);
LCD_WRITE_COMMAND(0xED);
LCD_WRITE_DATA(0x64);
LCD_WRITE_DATA(0x03);
LCD_WRITE_DATA(0x12);
LCD_WRITE_DATA(0x81);
LCD_WRITE_COMMAND(0xE8);
LCD_WRITE_DATA(0x85);
LCD_WRITE_DATA(0x78);
LCD_WRITE_COMMAND(0xCB);
LCD_WRITE_DATA(0x39);
LCD_WRITE_DATA(0x2C);
LCD_WRITE_DATA(0x06);
LCD_WRITE_COMMAND(0xF7);
LCD_WRITE_DATA(0x20);
LCD_WRITE_COMMAND(0xEA);
/*VRH[5:0]*/
LCD_WRITE_COMMAND(0xC0);
LCD_WRITE_DATA(0x21);
LCD_WRITE_COMMAND(0xC1);
LCD_WRITE_DATA(0x10);
LCD_WRITE_COMMAND(0xC5);
LCD_WRITE_DATA(0x31);
LCD_WRITE_DATA(0x3C);
LCD_WRITE_COMMAND(0x36);
LCD_WRITE_DATA(0x08);
LCD_WRITE_COMMAND(0xB0);
/*E0,E9D340*/
LCD_WRITE_DATA(0xE9);
LCD_WRITE_COMMAND(0xB1);
LCD_WRITE_DATA(0x13);
LCD_WRITE_COMMAND(0xB6);
LCD_WRITE_DATA(0xA2);
LCD_WRITE_COMMAND(0xF2);
LCD_WRITE_DATA(0x02);
LCD_WRITE_DATA(0x30);
LCD_WRITE_DATA(0x07);
LCD_WRITE_COMMAND(0x26);
LCD_WRITE_COMMAND(0xE0);
LCD_WRITE_DATA(0x0F);
LCD_WRITE_DATA(0x24);
LCD_WRITE_DATA(0x51);
LCD_WRITE_DATA(0x50);
LCD_WRITE_DATA(0x45);
LCD_WRITE_DATA(0x0a);
LCD_WRITE_DATA(0x15);
LCD_WRITE_DATA(0x40);
LCD_WRITE_COMMAND(0xE1);
LCD_WRITE_DATA(0x22);
LCD_WRITE_DATA(0x38);
LCD_WRITE_DATA(0x32);
LCD_WRITE_DATA(0x2c);
LCD_WRITE_DATA(0x34);
LCD_WRITE_COMMAND(0x11);
LCD_WRITE_COMMAND(0x29);
/*Display on*/
LCD_WRITE_COMMAND(0x2C);
void lcd_reflush(void)
/************** Reset LCD Driver *****************/
/*Delay 120 ms*/
/*VRH[5:0]*/
LCD_WRITE_DATA(0x4F);
/*Display on*/
static s32 lcd_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
struct __lcd_panel ili9341_80_panel = {
/* panel driver name, must mach the name of lcd_drv_name in sys_config.fex
.name = "ili9341_80",
.func = {
.cfg_panel_info = lcd_cfg_panel_info,
.cfg_open_flow = lcd_open_flow,
.cfg_close_flow = lcd_close_flow,
.lcd_user_defined_func = lcd_user_defined_func,
};H文件
#ifndef __ILI9341_80_PANEL_H__
#define __ILI9341_80_PANEL_H__
#include "panels.h"
extern struct __lcd_panel ili9341_80_panel;
#endif2.在kconfig添加驱动项
文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/Kconfig,增加
config LCD_SUPPORT_ILI9341_80_PANEL
bool "LCD support ili9341 i80 panel"
default y
---help---
If you want to support led panel for display driver, select it.This panel used for ili9341 i80 mode.makfile添加编译
文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/Makefile,在屏幕编译部分添加
disp-$(CONFIG_LCD_SUPPORT_HE0801A068) += lcd/he0801a068.o
disp-$(CONFIG_LCD_SUPPORT_K101_MM2QA01_A) += lcd/K101_MM2QA01_A.o
disp-$(CONFIG_LCD_SUPPORT_ILI9341_80_PANEL) += lcd/ili9341_80.o将上面的panel添加到panels
文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/panels.h
在后面最后一行#endif前添加
#ifdef CONFIG_LCD_SUPPORT_ILI9341_80_PANEL
extern __lcd_panel_t ili9341_80_panel;
#endif文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/panels.c
panel_array结构体最后的null前面添加
&ili9341_80_panel,
#endif修改设备树
在lichee/linux-5.4/arch/riscv/boot/dts/sunxi/sun20iw1p1.dtsi添加I80的引脚分配
pio: pinctrl@2000000 {
I8080_16bit_pins_a: I8080_16bit@0 {
pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
"PD6", "PD7" ,"PD8","PD9","PD10", "PD11","PD12","PD13","PD14","PD15", \
"PD18", "PD19", "PD20", "PD21";
function = "lcd0";
drive-strength = <30>;
bias-disable;
I8080_16bit_pins_b: I8080_16bit@1 {
function = "io_disabled";
bias-disable;
}在device/config/chips/f133/configs/mq_r/linux-5.4/board.dts
添加lcd0的配置,将其他lcd0屏蔽
根据Tina_lcd的文档,lcd_cpu_if取值
0: 18bit/1cycle (RGB666)
2: 16bit/3cycle (RGB666)
4: 16bit/2cycle (RGB666)
6: 16bit/2cycle (RGB666)
8: 16bit/1cycle (RGB565)
10: 9bit/1cycle (RGB666)
12: 8bit/3cycle (RGB666)
14: 8bit/2cycle (RGB565)
;8080 320*240*/
&lcd0 {
lcd_used = <1>;
lcd_driver_name = "ili9341_80";
lcd_backlight = <80>;
lcd_if = <1>;
lcd_cpu_if = <8>;
lcd_x = <320>;
lcd_y = <240>;
lcd_width = <108>;
lcd_height = <64>;
lcd_dclk_freq = <16>;
lcd_hbp = <20>;
lcd_ht = <360>;
lcd_hspw = <10>;
lcd_vbp = <8>;
lcd_vt = <256>;
lcd_vspw = <4>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <7>;
lcd_pwm_freq = <500>;
lcd_pwm_pol = <0>;
lcd_lvds_if = <0>;
lcd_lvds_colordepth = <1>;
lcd_lvds_mode = <0>;
lcd_frm = <0>;
lcd_io_phase = <0x0000>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
pinctrl-0 = <&I8080_16bit_pins_a>;
pinctrl-1 = <&I8080_16bit_pins_b>;
lcd_gpio_0 = <&pio PD 16 GPIO_ACTIVE_HIGH>;
};在device/config/chips/f133/configs/mq_r/uboot-board.dts同样修改
;8080 320*240*/
&lcd0 {
lcd_used = <1>;
lcd_if = <1>;
lcd_cpu_if = <8>;
lcd_x = <320>;
lcd_y = <240>;
lcd_width = <108>;
lcd_height = <64>;
lcd_hbp = <20>;
lcd_ht = <360>;
lcd_hspw = <10>;
lcd_vbp = <8>;
lcd_vt = <256>;
lcd_vspw = <4>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <7>;
lcd_pwm_pol = <0>;
lcd_lvds_if = <0>;
lcd_frm = <0>;
lcd_gamma_en = <0>;
lcd_cmap_en = <0>;
deu_mode = <0>;
smart_color = <90>;
};在lichee/brandy-2.0/u-boot-2018/configs/sun20iw1p1_defconfig屏幕部分添加
CONFIG_LCD_SUPPORT_ILI9341_80_PANEL=y
编译打包烧录
这是整个操作步骤,最后结果就是开头部分,是哪里没有改到还是弄错了的
上面两个board的设备树,少加了disp的设置,补上
&disp {
disp_init_enable = <1>;
disp_mode = <0>;
screen0_output_type = <1>;
screen0_output_mode = <4>;
screen1_output_type = <1>;
screen1_output_mode = <4>;
screen1_output_format = <0>;
screen1_output_bits = <0>;
screen1_output_eotf = <4>;
screen1_output_cs = <257>;
screen1_output_range = <2>;
screen1_output_scan = <0>;
screen1_output_aspect_ratio = <8>;
dev0_output_type = <1>;
dev0_output_mode = <4>;
dev0_screen_id = <0>;
dev0_do_hpd = <0>;
dev1_output_type = <4>;
dev1_output_mode = <10>;
dev1_screen_id = <1>;
dev1_do_hpd = <1>;
def_output_dev = <0>;
fb0_format = <0>;
fb0_width = <320>;
fb0_height = <240>;
fb0_width = <320>;
fb0_height = <240>;
fb1_format = <0>;
fb1_width = <0>;
fb1_height = <0>;
chn_cfg_mode = <1>;
disp_para_zone = <1>;
/*VCC-LCD*/
/* dc1sw-supply = <®_dc1sw>;*/
/*VCC-DSI*/
/* eldo3-supply = <®_eldo3>;*/
/*VCC-PD*/
/* dcdc1-supply = <®_dcdc1>;*/
};最近编辑记录 一篮子bug (2024-07-17 16:36:00)
