楼主 # 2023-12-31 16:06:45
zm
xboot 跑在t113-s3上,是如何识别boot device的?
最近在研究xboot对于T113-S3的启动源码,有一点一直搞不明白,就是在sys-copyself.c中的get_boot_device函数,源码如下:
static int get_boot_device(void)
	uint8_t s = *((volatile uint8_t *)(0x00020000 + 0x28));
	if(s == 0x3)
		sys_uart_putc('3');
		return BOOT_DEVICE_SPINOR;
	else if(s == 0x4)
		sys_uart_putc('4');
		return BOOT_DEVICE_SPINAND;
	else if(s == 0x0)
		sys_uart_putc('0');
		return BOOT_DEVICE_SDCARD;
	sys_uart_putc(s);
我还添加了打印,
log在下面:
xboot: /# 3
       _                   _
 _  _ | |___ _____ _____ _| |_
\ \/ /|  _  |  _  |  _  |_   _|  (C) 2007-2023
 )  ( | |_| | |_| | |_| | | |____JIANJUN.JIANG__
/_/\_\|_____|_____|_____| |_____________________|
V3.0.0 (Dec 31 2023 - 02:44:20) - [mangopi][MangoPi-MQ Based On Allwinner T133-S3 SOC]
[    0.000020]Probe device 'blk-romdisk.0' with blk-romdisk
[    0.000800]Probe device 'ext-32k' with clk-fixed
[    0.000810]Probe device 'rc-16m' with clk-fixed
[    0.000820]Probe device 'dcxo24m' with clk-fixed
我理解的0x00020000 + 0x28这个地方应该存放的是xboot.bin的开头的识别信息里platform information,我把mksunxi之后的xboot.bin给反汇编了(mksunxi中貌似也只是修改了_spl_size和checksum吧),根据反汇编:
00000000 <.data>:
       0:	ea00000e 	b	0x40
       4:	4e4f4765 	cdpmi	7, 4, cr4, cr15, cr5, {3}
       8:	3054422e 	subscc	r4, r4, lr, lsr #4
       c:	c019bd71 	andsgt	fp, r9, r1, ror sp
      10:	0000c000 	andeq	ip, r0, r0
      14:	00000030 	andeq	r0, r0, r0, lsr r0
      18:	30303033 	eorscc	r3, r0, r3, lsr r0
      1c:	00020000 	andeq	r0, r2, r0
      20:	00020000 	andeq	r0, r2, r0
      2c:	00302e34 	eorseq	r2, r0, r4, lsr lr
      40:	ea00000d 	b	0x7c
      44:	e59ff014 	ldr	pc, [pc, #20]	; 0x60
      48:	e59ff014 	ldr	pc, [pc, #20]	; 0x64
      4c:	e59ff014 	ldr	pc, [pc, #20]	; 0x68
      50:	e59ff014 	ldr	pc, [pc, #20]	; 0x6c
      54:	e59ff014 	ldr	pc, [pc, #20]	; 0x70
      58:	e59ff014 	ldr	pc, [pc, #20]	; 0x74
      5c:	e59ff014 	ldr	pc, [pc, #20]	; 0x78
      60:	40000400 	andmi	r0, r0, r0, lsl #8
      64:	400004c0 	andmi	r0, r0, r0, asr #9
我发现,0x28处就是0啊,但实际打印出来却是0x3,但我一直找不到是在什么时候把0x00020000 + 0x28处的值改成0x3了,希望有大佬能解释一下。
最近编辑记录 zm (2023-12-31 16:11:43)
#1 2024-07-27 21:52:18
xing
Re: xboot 跑在t113-s3上,是如何识别boot device的?
楼主,弄清楚了吗? 我也在疑惑这个问题。
