楼主 # 2025-02-12 16:13:57
kedren
求固件,全志A40I,sun8iw11p1
[ 0.33]HELLO! BOOT0 is starting!
[ 0.37]boot0 commit : f9c9977c4b0831d470ee78e31aac15ce486185f7
[ 0.44]boot0 version : 4.0
[ 0.47]set pll start
[ 0.51]set pll end
[ 0.87]rtc[0] value = 0x00000000
[ 0.90]rtc[1] value = 0x00000000
[ 0.93]rtc[2] value = 0x00000000
[ 0.97]rtc[3] value = 0x00000000
[ 0.100]rtc[4] value = 0x00000000
[ 0.103]rtc[5] value = 0x00000000
[ 0.107]DRAMC IS FOUR
[ 0.109]DRAM BOOT DRIVE INFO: V1.1
[ 0.113]Found A40
[ 0.115]Found A40
[ 0.117]Found A40
[ 0.119]Found A40
[ 0.121]Found A40
[ 0.127]PMU: [ 0.128]AXP221
[ 0.130]ddr voltage = 1500 mv
[ 0.133]DRAM CLK =576 MHZ
[ 0.136]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[ 0.141]DRAM zq value: 0x003b3bfb
[ 0.147]DRAM SIZE =1024 M
[ 0.150]DRAM simple test OK.
[ 0.153]dram size =1024
[ 0.156]rtc standby flag is 0x00000000, super standby flag is 0x00000000
[ 0.164]card no is 2
[ 0.166]sdcard 2 line count 8
[ 0.169][mmc]: mmc driver ver 2016-07-01 15:30
[ 0.174][mmc]: wrong freq 2 at spd md 2
[ 0.187][mmc]: Try MMC card 2
[ 0.203][mmc]: MMC 5.1
[ 0.206][mmc]: HSSDR52/SDR25 8 bit
[ 0.209][mmc]: 50000000 Hz
[ 0.212][mmc]: 7456 MB
[ 0.214][mmc]: SD/MMC 2 init OK!!!
[ 0.305]Succeed in loading uboot from sdmmc flash.
[ 0.309]Entry_name = u-boot
[ 0.329]Ready to disable icache.
[ 0.332]0xffffffff 0xffffffff
[ 0.335]0xffffffff 0xffffffff
[ 0.339]0xffffffff 0xffffffff
[ 0.342]0xffffffff 0xffffffff
[ 0.345]0xffffffff 0xffffffff
[ 0.348]0xffffffff 0xffffffff
[ 0.351]Jump to secend Boot.
U-Boot 2014.07 (Aug 01 2022 - 11:28:11) ThunderStone Technology
uboot commit : 8e504c02cd7217d2bce20b5a78d0be6c4e478794
i2c_init: by cpux
i2c_init ok
[ 0.368]pmbus: ready
[ 0.387]PMU: AXP221
[ 0.387]PMU: AXP22x found
[ 0.388]PMU: dcdc2 1160
[ 0.431]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz MBus=400Mhz
set power on vol to default
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1160, onoff=1
dcdc3_vol = 1100, onoff=1
dcdc4_vol = 1100, onoff=0
dcdc5_vol = 1550, onoff=1
aldo1_vol = 3300, onoff=1
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dc1sw_vol = 3300, onoff=1
dc5ldo_vol = 1100, onoff=0
dldo1_vol = 3300, onoff=1
dldo2_vol = 1800, onoff=1
dldo3_vol = 1800, onoff=1
dldo4_vol = 2500, onoff=0
eldo1_vol = 2800, onoff=0
eldo2_vol = 3300, onoff=1
eldo3_vol = 1200, onoff=0
gpio0_vol = 3300, onoff=1
gpio1_vol = 3300, onoff=1
find power_sply to end
vbus exist
run key detect
no key found
no uart input
DRAM: 1 GiB
fdt addr: 0x76e7ce58
Relocation Offset is: 35edf000
In: serial
Out: serial
Err: serial
gic: normal mode
workmode = 0,storage type = 2
[ 0.581]MMC: 2
[mmc]: mmc driver ver 2016-07-01 15:50:00
[mmc]: mmc_update_timing_para: error sdc_no 2
SUNXI SD/MMC: 2
[mmc]: 50 MHz...
[mmc]: sample: 52 - 192(ps)
[mmc]: ds: 52 - 192(ps)
[mmc]: 100 MHz...
[mmc]: sample: 26 - 192(ps)
[mmc]: ds: 26 - 192(ps)
[mmc]: 200 MHz...
[mmc]: sample: 13 - 192(ps)
[mmc]: ds: 13 - 192(ps)
[mmc]: media type 0x8000000
[mmc]: host caps: 0x6f
[mmc]: MID 0000ea PSN 1b13233e
[mmc]: PNM SPeMMC -- 0x53-50-65-4d-4d
[mmc]: PRV 1.0
[mmc]: MDT m-8 y-2022
[mmc]: MMC v5.1
[mmc]: speed mode : HSSDR52/SDR25
[mmc]: clock : 50000000 Hz
[mmc]: bus_width : 8 bit
[mmc]: user capacity : 7456 MB
[mmc]: boot capacity : 4096 KB
[mmc]: rpmb capacity : 4096 KB
[mmc]: use default speed mode: 1-HSSDR52/SDR25, ifreq: 2
[mmc]: ========best spd md: 1-HSSDR52/SDR25, freq: 2-50000000
[mmc]: already at HSSDR52_SDR25 mode
[mmc]: erase_grp_size : 0x400WrBlk*0x200=0x80000 Byte
[mmc]: secure_feature : 0x55
[mmc]: secure_removal_type : 0x1
[mmc]: EOL Info(Rev blks): Normal
[mmc]: Wear out(type A): 0%-10% life time used
[mmc]: Wear out(type B): 0%-10% life time used
[ 0.784]sunxi flash init ok
最近编辑记录 kedren (2025-02-12 16:14:17)
楼主 #1 2025-02-14 08:44:42
kedren
Re: 求固件,全志A40I,sun8iw11p1
有没有大佬看一下这款屏幕怎么点亮,下面是我的屏幕参数,板子上电后屏幕没有任何反应
[lcd0]
lcd_used = 1
lcd_driver_name = "default_lcd"
lcd_backlight = 150
lcd_if = 3
lcd_x = 1600
lcd_y = 900
lcd_width =
lcd_height =
lcd_dclk_freq = 58
lcd_pwm_used = 1
lcd_pwm_ch = 2
lcd_pwm_freq = 25000
lcd_pwm_pol = 1
lcd_pwm_max_limit = 255
lcd_hbp = 216
lcd_ht = 1056
lcd_hspw = 8
lcd_vbp = 26
lcd_vt = 926
lcd_vspw = 2
lcd_lvds_if = 1
lcd_lvds_colordepth = 0
lcd_lvds_mode = 0
lcd_frm = 0
lcd_hv_clk_phase = 0
lcd_hv_sync_polarity= 0
lcd_gamma_en = 0
lcd_bright_curve_en = 0
lcd_cmap_en = 0
deu_mode = 1
lcdgamma4iep = 22
smart_color = 90
lcd_bl_en = port:PB13<1><0><default><1>
;vdd_5v
lcd_gpio_0 = port:PH26<1><0><default><1>
;vdd_3v3
lcd_gpio_1 = port:PH27<1><0><default><1>
;pwm
lcd_gpio_2 = port:PB9<4><0><default><1>
lcd_power = "vcc-lcd"
lcdd0 = port:PD00<3><0><default><default>
lcdd1 = port:PD01<3><0><default><default>
lcdd2 = port:PD02<3><0><default><default>
lcdd3 = port:PD03<3><0><default><default>
lcdd4 = port:PD04<3><0><default><default>
lcdd5 = port:PD05<3><0><default><default>
lcdd6 = port:PD06<3><0><default><default>
lcdd7 = port:PD07<3><0><default><default>
lcdd8 = port:PD08<3><0><default><default>
lcdd9 = port:PD09<3><0><default><default>
lcdd10 = port:PD10<3><0><default><default>
lcdd11 = port:PD11<3><0><default><default>
lcdd12 = port:PD12<3><0><default><default>
lcdd13 = port:PD13<3><0><default><default>
lcdd14 = port:PD14<3><0><default><default>
lcdd15 = port:PD15<3><0><default><default>
lcdd16 = port:PD16<3><0><default><default>
lcdd17 = port:PD17<3><0><default><default>
lcdd18 = port:PD18<3><0><default><default>
lcdd19 = port:PD19<3><0><default><default>
;lcdd20 = port:PD20<2><0><default><default>
;lcdd21 = port:PD21<2><0><default><default>
;lcdd22 = port:PD22<2><0><default><default>
;lcdd23 = port:PD23<2><0><default><default>
;lcdclk = port:PD24<2><0><default><default>
;lcdde = port:PD25<2><0><default><default>
;lcdhsync = port:PD26<2><0><default><default>
;lcdvsync = port:PD27<2><0><default><default>
[lcd0_suspend]
lcdd0 = port:PD00<7><0><default><default>
lcdd1 = port:PD01<7><0><default><default>
lcdd2 = port:PD02<7><0><default><default>
lcdd3 = port:PD03<7><0><default><default>
lcdd4 = port:PD04<7><0><default><default>
lcdd5 = port:PD05<7><0><default><default>
lcdd6 = port:PD06<7><0><default><default>
lcdd7 = port:PD07<7><0><default><default>
lcdd8 = port:PD08<7><0><default><default>
lcdd9 = port:PD09<7><0><default><default>
lcdd10 = port:PD10<7><0><default><default>
lcdd11 = port:PD11<7><0><default><default>
lcdd12 = port:PD12<7><0><default><default>
lcdd13 = port:PD13<7><0><default><default>
lcdd14 = port:PD14<7><0><default><default>
lcdd15 = port:PD15<7><0><default><default>
lcdd16 = port:PD16<7><0><default><default>
lcdd17 = port:PD17<7><0><default><default>
lcdd18 = port:PD18<7><0><default><default>
lcdd19 = port:PD19<7><0><default><default>
;lcdd20 = port:PD20<7><0><default><default>
;lcdd21 = port:PD21<7><0><default><default>
;lcdd22 = port:PD22<7><0><default><default>
;lcdd23 = port:PD23<7><0><default><default>
;lcdclk = port:PD24<7><0><default><default>
;lcdde = port:PD25<7><0><default><default>
;lcdhsync = port:PD26<7><0><default><default>
;lcdvsync = port:PD27<7><0><default><default>
