楼主 # 2025-08-19 17:23:59
大西冰城
所在地: 广东,广州
T113-S3主线U-BOOT(2025.07)无法正常启动
这是我的设备树,就基于mango-pi修改了uart3
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
// Copyright (C) 2022 Arm Ltd.
#include <dt-bindings/interrupt-controller/irq.h>
/dts-v1/;
#include "sun8i-t113s.dtsi"
#include "sunxi-d1s-t113-mangopi-mq-r.dtsi"
	model = "REVB-t113";
	compatible = "Steven,REVB-t113", "allwinner,sun8i-t113s";
	aliases {
		ethernet0 = &rtl8189ftv;
		serial3 = &uart3;
	chosen {
		stdout-path = "serial3:115200n8";
&cpu0 {
	cpu-supply = <&reg_vcc_core>;
&cpu1 {
&mmc1 {
	rtl8189ftv: wifi@1 {
		reg = <1>;
		interrupt-parent = <&pio>;
		interrupts = <6 10 IRQ_TYPE_LEVEL_LOW>; /* PG10 = WL_WAKE_AP */
		interrupt-names = "host-wake";
&pio {
	uart3_pg_pins: uart3-pg-pins {
		pins = "PG8", "PG9";
		function = "uart3";
&uart3 {
	pinctrl-names = "default";
	pinctrl-0 = <&uart3_pg_pins>;
通过sunxi-fel写入spl后,uart3正常输出,DRAM也识别正确,但是之后就没有输出了,如下:
#1 2025-08-20 17:18:44
曹晓宁
Re: T113-S3主线U-BOOT(2025.07)无法正常启动
还要加点日志呀,这看不出来什么
#2 2025-10-09 00:06:48
quangtn82
Please check the pin configuration of UART3, according to the schematic of Mango-pi mq dual, UART3 uses pins PB6 and PB7
