使用LC-PI-200S开发板驱动LED闪烁
开发板芯片:F1C200S
开发板网址:http://wiki.lcmaker.com/index.php?title=LC-PI-200S
测试驱动引脚:PA0
路径"\lc\buildroot\board\widora\mangopi\r3\devicetree\linux\devicetree.dts"
led {
compatible = "led";
gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;
pinctrl-names = "default";
&pio {
led_pins: led_pins {
pins = "PA0";
};led.c
#include <linux/init.h>
#include <linux/module.h>
#include <linux/fs.h>
#include <linux/io.h>
#include <linux/uaccess.h>
#include <linux/device.h>
#include <linux/of.h>
#include <linux/gpio.h>
#include <linux/of_gpio.h>
#define CDEV_NAME "led"
#define LED_NODE_PATH "/led"
#define LED_NODE_PROPERTY "gpios"
int major = -1;
int gpionum = -1;
struct class *cls = NULL;
struct device *dev = NULL;
struct device_node *led_node = NULL;
char kbuf[128] = {0};
ssize_t my_write (struct file *file, const char __user *ubuf, size_t size, loff_t *offset)
size = size > sizeof(kbuf) ? sizeof(kbuf) : size;
if(copy_from_user(kbuf, ubuf, size))
printk("copy data from user failed!\n");
return -EINVAL;
if(kbuf[0] == '1')
gpio_set_value(gpionum,1); //设置高电平
gpio_set_value(gpionum,0); //设置低电平
return size;
struct file_operations fops = {
.write = my_write,
int gpio_init(void)
//获取节点
led_node = of_find_node_by_path(LED_NODE_PATH);
if(led_node == NULL)
printk("find node %s failed!\n",LED_NODE_PATH );
return -ENODEV;
//获取gpio编号
gpionum = of_get_named_gpio(led_node, LED_NODE_PROPERTY, 0);
if(gpionum < 0)
printk("get property %s failed!\n",LED_NODE_PROPERTY );
return -EINVAL;
//申请GPIO
if(gpio_request(gpionum,NULL))
printk("request gpio failed!\n");
return -EINVAL;
//设置GPIO为输出
if(gpio_direction_output(gpionum, 0))
printk("set gpio direction failed!\n");
return -EINVAL;
static int __init mydev_init(void)
//注册字符设备
major = register_chrdev(0,CDEV_NAME,&fops);
if(major < 0)
printk("register chardev failed! \n");
return -1;
//自动创建设备节点
//提交目录信息
cls = class_create(THIS_MODULE,CDEV_NAME);
if(IS_ERR(cls))
printk("auto create node failed! \n");
return PTR_ERR(cls);
//提交设备信息
dev = device_create(cls,NULL,MKDEV(major,0),NULL,CDEV_NAME);
if(IS_ERR(dev))
printk("device create failed! \n");
return PTR_ERR(dev);
gpio_init();
void gpio_deinit(void)
gpio_free(gpionum);
static void __exit mydev_exit(void)
gpio_deinit();
device_destroy(cls, MKDEV(major,0));
class_destroy(cls);
unregister_chrdev(major,CDEV_NAME);
module_init(mydev_init);
module_exit(mydev_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("yuan u1232@qq.com");
MODULE_VERSION("1.0");Makefile
KERNELDIR:=/home/test/lc/buildroot/output/build/linux-5.4.99/ #内核源码路径
ARCH=arm
CROSS_COMPILE=/home/test/lc/buildroot/output/host/bin/arm-buildroot-linux-gnueabi-
export ARCH CROSS_COMPILE
obj-m += led.o
module:
make -C $(KERNELDIR) M=$(CURDIR) ARCH=arm modules
clean:
make -C $(KERNELDIR) M=$(CURDIR) ARCH=arm clean编译"/home/test/lc/buildroot/output/host/bin/arm-linux-gcc test.c -o test"
test.c
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
int main()
int fd = open("/dev/led",O_RDWR);
if(fd == -1)
printf("open failed");
return -1;
while(1)
write(fd,"1",1);
sleep(1);
write(fd,"0",1);
sleep(1);
close(fd);
}最近编辑记录 a-path (2025-09-30 11:48:51)
这个芯片还是老老实实玩裸机吧
lanlanzhilian wrote:
这个芯片还是老老实实玩裸机吧
我感觉还可以吧,为啥不建议跑Linux
