报错log
[ 191.452261] aicbsp_init
[ 191.455016] aicbsp_init, Driver Release Tag: aic-bsp-compatible(sdio)-20221108-001
[ 191.464580] [sound 403][MACH simple_parse_of] simple_dai_link_of failed
[ 191.472356] -->aicbt_rfkill_init
[ 191.476221] <--aicbt_rfkill_init
[ 191.499263] >>> rwnx_mod_init()
[ 191.502804] rwnx 20221108-004-6.4.3.0 - - 241c091M (master)
[ 191.509121] Driver Release Tag: aic-rwnx-compatible(sdio)-20221108-004
[ 191.516450] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 191.523612] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 191.531824] aicbsp: aicbsp_platform_power_on
[ 191.536619] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
[ 191.553047] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[ 191.611290] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 191.622565] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 191.642741] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 191.667848] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 191.675554] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 191.682470] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 191.697111] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 191.719837] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 191.731461] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 191.743348] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 191.756879] mmc1: new high speed SDIO card at address 390b
[ 193.643754] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[ 193.651029] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[ 193.658983] rwnx_mod_init, set power on fail!
[ 193.754579] >>> rwnx_mod_init()
[ 193.758116] rwnx 20221108-004-6.4.3.0 - - 241c091M (master)
[ 193.764454] Driver Release Tag: aic-rwnx-compatible(sdio)-20221108-004
[ 193.764463] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 193.764468] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 193.764471] aicbsp: aicbsp_platform_power_on
[ 193.774633] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[ 193.851051] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 193.857827] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 193.864599] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 193.871364] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 193.878521] mmc1: card 390b removed
[ 193.883375] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 193.896101] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 193.907348] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 193.927546] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 193.952632] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 193.960310] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 193.967175] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 193.981817] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 194.004388] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 194.016015] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 194.027907] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 194.041243] mmc1: new high speed SDIO card at address 390b
[ 195.883630] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[ 195.890912] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[ 195.898853] rwnx_mod_init, set power on fail!
modprobe: can't load module aic8800_fdrv.ko (aic8800_fdrv.ko): No such device
dts配置
rfkill: rfkill@0 {
compatible = "allwinner,sunxi-rfkill";
chip_en;
pinctrl-0 = <&wlan_pins_a>;
pinctrl-names = "default";
wlan: wlan@0 {
compatible = "allwinner,sunxi-wlan";
clock-names = "32k-fanout1";
clocks = <&ccu CLK_FANOUT1_OUT>;
wlan_busnum = <0x1>;
wlan_regon = <&pio PG 12 GPIO_ACTIVE_HIGH>;
wlan_hostwake = <&pio PG 10 GPIO_ACTIVE_HIGH>;
/*wlan_power = "VCC-3V3";
wlan_power_vol = <3300000>;*/
/*interrupt-parent = <&pio>;
interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/
wakeup-source;
bt: bt@0 {
compatible = "allwinner,sunxi-bt";
/bt_power_num = <0x01>;/
/bt_power = "axp803-dldo1";/
/bt_io_regulator = "axp803-dldo1";/
/bt_io_vol = <3300000>;/
/bt_power_vol = <330000>;/
bt_rst_n = <&pio PD 22 GPIO_ACTIVE_LOW>;
status = "disabled";
btlpm: btlpm@0 {
compatible = "allwinner,sunxi-btlpm";
uart_index = <0x1>;
bt_wake = <&pio PG 15 GPIO_ACTIVE_HIGH>;
bt_hostwake = <&pio PG 14 GPIO_ACTIVE_HIGH>;
addr_mgt: addr_mgt@0 {
compatible = "allwinner,sunxi-addr_mgt";
type_addr_wifi = <0x0>;
type_addr_bt = <0x0>;
type_addr_eth = <0x0>;
像没使能,量一下模块的供电和使能
4610 wrote:
像没使能,量一下模块的供电和使能
看着打印已经扫到卡了 mmc1: new high speed SDIO card at address 390b
