以下由 @哇酷小管家 2021-12-16 添加:
用 buildroot 更方便,参考这两个链接
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 已支持DVP摄像头
https://whycan.com/t_5221.html
(V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
https://whycan.com/t_7248.html#p69178
完毕
pack.sh
#!/bin/bash
_UBOOT_SIZE=1
###第一个分区(FAT)大小,单位MiB##
_P1_SIZE=16
###TF卡镜像文件名称###
_IMG_FILE='f1c100s_tfcard_img.bin'
###TF卡镜像文件大小, 单位MiB###
_IMG_SIZE=120
temp_root_dir=$PWD
_UBOOT_FILE="${temp_root_dir}/data/u-boot-sunxi-with-spl.bin"
_SPLASH_BMP_FILE="${temp_root_dir}/data/splash.bmp"
_BOOT_SCR_FILE="${temp_root_dir}/data/boot.scr"
_KERNEL_IMAGE_FILE="${temp_root_dir}/data/zImage"
_DTB_FILE="${temp_root_dir}/data/dtb.bin"
_ROOTFS_TGZ_FILE="${temp_root_dir}/data/rootfs.tgz"
###初始化镜像文件###
dd if=/dev/zero of=$_IMG_FILE bs=1M count=$_IMG_SIZE
###判断镜像文件是否初始化成功###
if [ $? -ne 0 ]
then
echo "getting error in creating dd img!"
exit
fi
###获取一个循环设备###
_LOOP_DEV=$(sudo losetup -f)
#echo ${_LOOP_DEV}
##再次判断此设备是否存在###
if [ -z $_LOOP_DEV ]
then
echo "can not find a loop device!"
exit
fi
###把镜像文件和循环设备关联###
sudo losetup $_LOOP_DEV $_IMG_FILE
if [ $? -ne 0 ]
then
echo "dd img --> $_LOOP_DEV error!"
sudo losetup -d $_LOOP_DEV >/dev/null 2>&1 && exit
fi
echo "--->creating partitions for tf image ..."
#blockdev --rereadpt $_LOOP_DEV >/dev/null 2>&1
# size only can be integer
###分区###
cat <<EOT |sudo sfdisk ${_IMG_FILE}
${_UBOOT_SIZE}M,${_P1_SIZE}M,c
,,L
EOT
###格式化###
sleep 2
sudo partx -u $_LOOP_DEV
sudo mkfs.vfat ${_LOOP_DEV}p1 ||exit
sudo mkfs.ext4 ${_LOOP_DEV}p2 ||exit
if [ $? -ne 0 ]
then
echo "error in creating partitions"
#sudo partprobe $_LOOP_DEV >/dev/null 2>&1 && exit
fi
###u-boot写到TF卡8K偏移处###
#pack uboot
echo "--->writing u-boot-sunxi-with-spl to $_LOOP_DEV"
# sudo dd if=/dev/zero of=$_LOOP_DEV bs=1K seek=1 count=1023 # clear except mbr
sudo dd if=$_UBOOT_FILE of=$_LOOP_DEV bs=1024 seek=8
if [ $? -ne 0 ]
then
echo "writing u-boot error!"
fi
###新建 p1,p2 目录,并挂载TF卡两个分区###
sudo sync
mkdir -p ${temp_root_dir}/output/p1 >/dev/null 2>&1
mkdir -p ${temp_root_dir}/output/p2 > /dev/null 2>&1
sudo mount ${_LOOP_DEV}p1 ${temp_root_dir}/output/p1
sudo mount ${_LOOP_DEV}p2 ${temp_root_dir}/output/p2
echo "--->copy boot and rootfs files..."
sudo rm -rf ${temp_root_dir}/output/p1/* && sudo rm -rf ${temp_root_dir}/output/p2/*
###复制zImage, dtb, boot.scr, splash.bmp 等文件到第一分区 ###
sudo cp ${_KERNEL_IMAGE_FILE} ${temp_root_dir}/output/p1/zImage &&\
sudo cp ${_DTB_FILE} ${temp_root_dir}/output/p1/ &&\
sudo cp ${_BOOT_SCR_FILE} ${temp_root_dir}/output/p1/ &&\
sudo cp ${_SPLASH_BMP_FILE} ${temp_root_dir}/output/p1/ &&\
echo "--->p1 done~"
###解压 rootfs.tgz 到第二分区###
sudo tar xvf ${_ROOTFS_TGZ_FILE} -C ${temp_root_dir}/output/p2/ &&\
echo "--->p2 done~"
###同步, 等待, 卸载, 退出###
sudo sync
sleep 2
sudo umount ${temp_root_dir}/output/p1 ${temp_root_dir}/output/p2 && sudo losetup -d $_LOOP_DEV
if [ $? -ne 0 ]
then
echo "umount or losetup -d error!!"
exit
fi目录结构:
pack.sh
data/
boot.scr
dtb.bin
rootfs.tgz
zImage以上脚本参考本站 @xiaohui 的打包脚本, 我加了部分注释, 把其他非打包脚本剥离开了。
这个脚本真是 666666
这个脚本可以打包F1C200S么
向大神学习, 学习
入坑了,当初荔枝派的脚本找了很久.....
这个脚本好!
自己画一个板子,需要做什么才能让它从spiflash引导启动呢?
感谢楼主分享,新买的Tiny200,正好下载下来测试一下
新的BuildRoot里面有个support/scripts/genimage.sh,不过完全看不懂
#!/usr/bin/env bash
die() {
cat <<EOF >&2
Error: $@
Usage: ${0} -c GENIMAGE_CONFIG_FILE
EOF
exit 1
# Parse arguments and put into argument list of the script
opts="$(getopt -n "${0##*/}" -o c: -- "$@")" || exit $?
eval set -- "$opts"
GENIMAGE_TMP="${BUILD_DIR}/genimage.tmp"
while true ; do
case "$1" in
-c)
GENIMAGE_CFG="${2}";
shift 2 ;;
--) # Discard all non-option parameters
shift 1;
break ;;
die "unknown option '${1}'" ;;
esac
done
[ -n "${GENIMAGE_CFG}" ] || die "Missing argument"
# Pass an empty rootpath. genimage makes a full copy of the given rootpath to
# ${GENIMAGE_TMP}/root so passing TARGET_DIR would be a waste of time and disk
# space. We don't rely on genimage to build the rootfs image, just to insert a
# pre-built one in the disk image.
trap 'rm -rf "${ROOTPATH_TMP}"' EXIT
ROOTPATH_TMP="$(mktemp -d)"
rm -rf "${GENIMAGE_TMP}"
genimage \
--rootpath "${ROOTPATH_TMP}" \
--tmppath "${GENIMAGE_TMP}" \
--inputpath "${BINARIES_DIR}" \
--outputpath "${BINARIES_DIR}" \
--config "${GENIMAGE_CFG}"离线
我平时用的只有下面四个文件
sun8i-v3s-licheepi-zero-dock.dtb
zImage
rootfs.tar
也能打包成为TF卡的烧写程序吗?
怎么做呢?
zhang235hai wrote:
我平时用的只有下面四个文件
zImage
rootfs.tar
也能打包成为TF卡的烧写程序吗?
怎么做呢?
可以的,按一楼那个脚本就行,只要写一个 boot.cmd的文本文件,编译成 boot.scr 就可以了。
怎么编译成 boot.scr啊?不用这个就行了吧?
mkimage -C none -A arm -T script -d boot.cmd boot.scr
非常感谢!boot.cmd是怎么来的,新建一个空的文本文件吗?
请教一下,boot.cmd该怎么写,V3s没有用到啊
是的,将你的一些加载、启动命令写入进去就行了,再按照上面的命令生成boot.src!
实在是看不明白啊,请问是哪些加载、启动命令呢?能介绍清楚一些么?
麻烦老大,能不能写一个V3s能用的。boot.cmd不知道怎么写,boot.scr 没有文档啊
当然可以,而且本来就是。
fatload mmc 1:1 0x46000000 zImage
fatload mmc 1:1 0x49000000 sun8i-x3-smallwit-card-taurus.dtb
setenv bootargs console=ttyS0,115200 earlyprintk root=/dev/mmcblk2p2 rootwait panic=10
bootz 0x46000000 - 0x49000000,类似于这些。
感谢晕哥,这个方便很多了
这个实用
这脚本实在是太方便了啊,感谢
V3S生成的设备树文件是dtb,脚本用到的dtb.bin,这2者怎么转化
zhang235hai wrote:
我平时用的只有下面四个文件
zImage
rootfs.tar
也能打包成为TF卡的烧写程序吗?
怎么做呢?
同问,怎么打包 spinand 128MB 用全志的 PhoenixSuit 烧录?打包成bin文件烧录太慢了
有没有全志v3s的uboot,sd卡启动的
同求全志v3s的uboot,sd卡启动的
