suniv.dtsi
line124
uart0_pins_a: uart-pins-pe {
pins = "PE0", "PE1";
function = "uart0";
uart1_pins_a: uart-pins-pa {
pins = "PA2", "PA3";
function = "uart1";
u-boot\arch\arm\mach-sunxi\board.c
line86
#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0);
sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0);
sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
之前花了一点时间改了一下,希望帮得上忙
这个文件 include/configs/suniv.h 还得加上:
#define CONFIG_CONS_INDEX 1 //UART0
#define CONFIG_CONS_INDEX 2 //UART1
#define CONFIG_CONS_INDEX 3 //UART2
diff --git a/arch/arm/dts/suniv.dtsi b/arch/arm/dts/suniv.dtsi
index 10da83b53a..9dd95f38e1 100644
--- a/arch/arm/dts/suniv.dtsi
+++ b/arch/arm/dts/suniv.dtsi
@@ -125,6 +125,16 @@
function = "uart0";
+ uart1_pins_a: uart-pins-pa {
+ pins = "PA2", "PA3";
+ function = "uart1";
+ uart2_pins_a: uart-pins-pe-uart2 {
+ pins = "PE7", "PE8";
+ function = "uart2";
timer@1c20c00 {
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h
index b0a946d3b7..09c1a78adc 100644
--- a/arch/arm/include/asm/arch-sunxi/gpio.h
+++ b/arch/arm/include/asm/arch-sunxi/gpio.h
@@ -176,6 +176,9 @@ enum sunxi_gpio_number {
#define SUNXI_GPD_LVDS0 3
#define SUNIV_GPE_UART0 5
+#define SUNIV_GPA_UART1 5
+#define SUNIV_GPE_UART2 3
#define SUN5I_GPE_SDC2 3
#define SUN8I_GPE_TWI2 3
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c
index 6afbb7affa..7a44996505 100644
--- a/arch/arm/mach-sunxi/board.c
+++ b/arch/arm/mach-sunxi/board.c
@@ -87,6 +87,14 @@ static int gpio_init(void)
sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0);
sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0);
sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP);
+#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
+ sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPA_UART1);
+ sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPA_UART1);
+ sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
+#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUNIV)
+ sunxi_gpio_set_cfgpin(SUNXI_GPE(7), SUNIV_GPE_UART2);
+ sunxi_gpio_set_cfgpin(SUNXI_GPE(8), SUNIV_GPE_UART2);
+ sunxi_gpio_set_pull(SUNXI_GPA(8), SUNXI_GPIO_PULL_UP);
#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \
defined(CONFIG_MACH_SUN7I) || \
defined(CONFIG_MACH_SUN8I_R40))
diff --git a/include/configs/suniv.h b/include/configs/suniv.h
index cadb003f02..b1448f49d4 100644
--- a/include/configs/suniv.h
+++ b/include/configs/suniv.h
@@ -29,4 +29,7 @@
#define CONFIG_HIDE_LOGO_VERSION
+#undef CONFIG_CONS_INDEX
+#define CONFIG_CONS_INDEX 3
#endif /* __CONFIG_H */从 UART2(PE7/PE8)输出, 刚刚改完, 还没测试呢, 可能有坑。
改这个只能影响u-boot 的 spl 串口输出, 如果u-boot输出还得改 dts 文件:
diff --git a/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts b/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
index 9c111e6228..45658d2b1d 100644
--- a/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
+++ b/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
@@ -15,11 +15,12 @@
aliases {
serial0 = &uart0;
+ serial2 = &uart2;
spi0 = &spi0;
chosen {
- stdout-path = "serial0:115200n8";
+ stdout-path = "serial2:115200n8";
@@ -47,6 +48,18 @@
+&uart1 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&uart1_pins_a>;
+ status = "okay";
+&uart2 {
+ pinctrl-0 = <&uart2_pins_e>;
+ status = "okay";
&usb_otg {
dr_mode = "otg";
index 10da83b53a..d3b937a16d 100644
function = "uart0";
+ uart2_pins_e: uart-pins-pe-uart2 {
timer@1c20c00 {
@@ -29,4 +29,7 @@
从 UART2(PE7/PE8)输出搞定!
和u-boot 类似修改dts
diff --git a/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts b/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
index f46e190..c31e4ea 100644
--- a/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
+++ b/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
@@ -7,7 +7,8 @@
#include "suniv-f1c100s.dtsi"
+#include <dt-bindings/input/input.h>
+#include <dt-bindings/interrupt-controller/irq.h>
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
@@ -15,11 +16,12 @@
aliases {
serial0 = &uart0;
+ serial1 = &uart1;
spi0 = &spi0;
chosen {
+ stdout-path = "serial1:115200n8";
panel: panel {
@@ -67,13 +69,52 @@
pinctrl-0 = <&spi0_pins_a>;
- flash@0 {
+ spi-max-frequency = <50000000>;
+ flash: w25q128@0 {
#address-cells = <1>;
#size-cells = <1>;
reg = <0>;
- spi-max-frequency = <40000000>;
+ partitions {
+ compatible = "fixed-partitions";
+ #address-cells = <1>;
+ #size-cells = <1>;
+ partition@0 {
+ label = "u-boot";
+ reg = <0x000000 0x100000>;
+ read-only;
+ partition@100000 {
+ label = "dtb";
+ reg = <0x100000 0x10000>;
+ read-only;
+ partition@110000 {
+ label = "kernel";
+ reg = <0x110000 0x400000>;
+ read-only;
+ partition@510000 {
+ label = "rootfs";
+ reg = <0x510000 0xAF0000>;
+&i2c0 {
+ pinctrl-0 = <&i2c0_pins>;
+ status = "okay";
+ ns2009: ns2009@48 {
+ compatible = "nsiway,ns2009";
+ reg = <0x48>;
@@ -95,7 +136,11 @@
pinctrl-0 = <&uart0_pins_a>;
+&uart1 {
+ status = "okay";
&usb_otg {
dr_mode = "otg";
diff --git a/arch/arm/boot/dts/suniv.dtsi b/arch/arm/boot/dts/suniv.dtsi
index ee600cd..d0d2fc7 100644
--- a/arch/arm/boot/dts/suniv.dtsi
+++ b/arch/arm/boot/dts/suniv.dtsi
@@ -228,12 +228,18 @@
"PD20", "PD21";
function = "lcd";
+ i2c0_pins: i2c0 {
+ pins = "PD12", "PD0";
+ function = "i2c0";
function = "uart0";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
@@ -284,6 +290,18 @@
status = "disabled";
+ i2c0: i2c@1c27000 {
+ compatible = "allwinner,sun6i-a31-i2c";
+ reg = <0x01C27000 0x400>;
+ interrupts = <7>;
+ clocks = <&ccu CLK_BUS_I2C0>;
+ resets = <&ccu RST_BUS_I2C0>;
+ status = "disabled";
+ #size-cells = <0>;
usb_otg: usb@1c13000 {
diff --git a/drivers/mtd/spi-nor/spi-nor.c b/drivers/mtd/spi-nor/spi-nor.c
index bc266f7..99dc551 100644
--- a/drivers/mtd/spi-nor/spi-nor.c
+++ b/drivers/mtd/spi-nor/spi-nor.c
@@ -1182,7 +1182,7 @@ static const struct flash_info spi_nor_ids[] = {
{ "w25q80", INFO(0xef5014, 0, 64 * 1024, 16, SECT_4K) },
{ "w25q80bl", INFO(0xef4014, 0, 64 * 1024, 16, SECT_4K) },
- { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) },
+ { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, 0) },
{ "w25q256", INFO(0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
{ "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 1024,
SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ) }, 离线
U-BOOT改好了,参数好像会直接传递到内核,所以内核那边是不需要去改的。只停在start kernel可能是原来传递的是ttyS0,你没改到ttyS1.
应该是正解
@迪卡
能分享下教程么?我想我串口2打印日志,BSP LINUX3.10 修改fex文件和uboot都不好使,现在想用主线UBOOT引导BSP来实现,但是不知道怎么实现
迪卡 wrote:
只更改rootfs中的/etc/inittab里的还是不行,只停在start kernel
后来解决了吗
楼主可以整理一下主线u-boot修改的步骤吗。
