楼主 #1 2021-02-19 15:37:23
raspberryman
已发帖子: 503
直接在 widora tiny200开发板测试 spi nand ubifs文件系统
参考链接:
http://www.linux-mtd.infradead.org/faq/ubifs.html
# Wipe the MTD device out. Note, we could use flash_eraseall, but we do not
# want to lose erase counters
ubiformat /dev/mtd0
# Load UBI module
modprobe ubi
# Attach mtd0 to UBI - UBI will detect that the MTD device is
# empty and automatically format it. This command will also create
# UBI device 0 and udev should create /dev/ubi0 node
ubiattach /dev/ubi_ctrl -m 0
# Create an UBI volume - the created volume will be empty
ubimkvol /dev/ubi0 -N test_volume -s 10MiB
# Mount UBIFS - it will automatically format the empty volume
mount -t ubifs ubi0:test_volume /mnt/ubifs
相关参考:
请问 buildroot 根文件系统 ubi和ubifs有什么区别呢?
http://whycan.com/t_6019.html
(出处:哇酷开发者社区)
楼主 #2 2021-02-19 15:37:52
raspberryman
已发帖子: 503
Re: 直接在 widora tiny200开发板测试 spi nand ubifs文件系统
tiny200 spi nand 现场测试:
# ubiformat /dev/mtd4
ubiformat: mtd4 (nand), size 50331648 bytes (48.0 MiB), 384 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 383 -- 100 % complete
ubiformat: 383 eraseblocks have valid erase counter, mean value is 2
ubiformat: 1 bad eraseblocks found, numbers: 192
ubiformat: formatting eraseblock 383 -- 100 % complete
# ubiattach /dev/ubi_ctrl -m 4
[  325.203966] ubi0: attaching mtd4
[  325.867234] ubi0: scanning is finished
[  325.905417] ubi0: attached mtd4 (name "overlay", size 48 MiB)
[  325.911186] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[  325.918219] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[  325.925002] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[  325.932013] ubi0: good PEBs: 383, bad PEBs: 1, corrupted PEBs: 0
[  325.938054] ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
[  325.945301] ubi0: max/mean erase counter: 4/3, WL threshold: 4096, image sequence number: 1368536342
[  325.954413] ubi0: available PEBs: 360, total reserved PEBs: 23, PEBs reserved for bad PEB handling: 19
[  325.965401] ubi0: background thread "ubi_bgt0d" started, PID 200
UBI device number 0, total 383 LEBs (48631808 bytes, 46.3 MiB), available 360 LEBs (45711360 bytes, 43.5 MiB), LEB size 126976 bytes (124.0 KiB)
# ubimkvol /dev/ubi0 -N test_volume -s 20MiB
Volume ID 0, size 166 LEBs (21078016 bytes, 20.1 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "test_volume", alignment 1
# mkdir -p /mnt/ubifs/; mount -t ubifs ubi0:test_volume /mnt/ubifs
[  396.316740] UBIFS (ubi0:0): default file-system created
[  396.323943] UBIFS (ubi0:0): Mounting in unauthenticated mode
[  396.334069] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 206
[  396.510137] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "test_volume"
[  396.518175] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[  396.528174] UBIFS (ubi0:0): FS size: 19808256 bytes (18 MiB, 156 LEBs), journal size 1015809 bytes (0 MiB, 8 LEBs)
[  396.538550] UBIFS (ubi0:0): reserved for root: 935592 bytes (913 KiB)
[  396.544998] UBIFS (ubi0:0): media format: w5/r0 (latest is w5/r0), UUID DDF61ED8-29D8-41D3-B75C-D06A4B5B5FC8, small LPT model
[  396.560487] UBIFS (ubi0:0): full atime support is enabled.
# cd /mnt/ubifs/
# dd if=/dev/urandom of=test1.bin bs=15M count=1
1+0 records in
1+0 records out
# ls -l
total 15360
-rw-r--r--    1 root     root      15728640 Jan  1 00:07 test1.bin
# md5sum test1.bin
30303d04108632117aa0f3a656dadb14  test1.bin
# md5sum test1.bin
楼主 #3 2021-02-19 15:54:51
raspberryman
已发帖子: 503
重启之后15M随机数文件test1.bin md5码依然是正确的!
#ubiattach /dev/ubi_ctrl -m 4
[   42.202019] ubi0: attaching mtd4
[   42.875260] ubi0: scanning is finished
[   42.920832] ubi0: attached mtd4 (name "overlay", size 48 MiB)
[   42.926746] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[   42.933618] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[   42.940486] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[   42.947485] ubi0: good PEBs: 383, bad PEBs: 1, corrupted PEBs: 0
[   42.953485] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[   42.960736] ubi0: max/mean erase counter: 5/3, WL threshold: 4096, image sequence number: 1368536342
[   42.969884] ubi0: available PEBs: 194, total reserved PEBs: 189, PEBs reserved for bad PEB handling: 19
[   42.981773] ubi0: background thread "ubi_bgt0d" started, PID 194
UBI device number 0, total 383 LEBs (48631808 bytes, 46.3 MiB), available 194 LEBs (24633344 bytes, 23.4 MiB), LEB size 126976 bytes (124.0 KiB)
[   73.033794] UBIFS (ubi0:0): Mounting in unauthenticated mode
[   73.050609] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 199
[   73.285632] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "test_volume"
[   73.293482] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[   73.303552] UBIFS (ubi0:0): FS size: 19808256 bytes (18 MiB, 156 LEBs), journal size 1015809 bytes (0 MiB, 8 LEBs)
[   73.313941] UBIFS (ubi0:0): reserved for root: 935592 bytes (913 KiB)
[   73.320457] UBIFS (ubi0:0): media format: w5/r0 (latest is w5/r0), UUID DDF61ED8-29D8-41D3-B75C-D06A4B5B5FC8, small LPT model
[   73.338918] UBIFS (ubi0:0): full atime support is enabled.
# cd /mnt/ubifs/
# md5sum test1.bin
# md5sum test1.bin
说明:测试OK!
楼主 #4 2021-02-19 15:57:45
raspberryman
已发帖子: 503
&spi0 {
        spi-nand@0 {
                #address-cells = <1>;
                #size-cells = <1>;
                compatible = "spi-nand";
                reg = <0>;
                partitions {
                        #size-cells = <1>;
                        partition@0 {
                                label = "u-boot";
                                reg = <0x000000 0x80000>;
                                read-only;
                        partition@1 {
                                label = "dtb";
                                reg = <0x80000 0x20000>;
                                read-only;
                        partition@2 {
                                label = "kernel";
                                reg = <0x100000 0x700000>;
                                read-only;
                        partition@3 {
                                label = "rom";
                                reg = <0x800000 0x4000000>;
                                read-only;
                        partition@4 {
                                label = "overlay";
                                reg = <0x4800000 0x3000000>;
spi nand分区是 aodzip 大佬默认的配置.
[    0.879898] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.892723] spi-nand spi0.0: GigaDevice SPI NAND was found.
[    0.898426] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    0.908036] 5 fixed-partitions partitions found on MTD device spi0.0
[    0.914397] Creating 5 MTD partitions on "spi0.0":
[    0.919311] 0x000000000000-0x000000080000 : "u-boot"
[    0.929945] 0x000000080000-0x0000000a0000 : "dtb"
[    0.938921] 0x000000100000-0x000000800000 : "kernel"
[    0.947089] random: fast init done
[    0.977131] 0x000000800000-0x000004800000 : "rom"
[    1.222006] 0x000004800000-0x000007800000 : "overlay"
[    1.407977] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
这是开机log
# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00080000 00020000 "u-boot"
mtd1: 00020000 00020000 "dtb"
mtd2: 00700000 00020000 "kernel"
mtd3: 04000000 00020000 "rom"
mtd4: 03000000 00020000 "overlay"
这是分区信息。
楼主 #5 2021-02-19 15:58:12
raspberryman
已发帖子: 503
继续创建一个 test_volume2 卷,写入10M test2.bin 文件, 重启检查md5校验码:
# cat /proc/mtd
# df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root               114901     92103     14197  87% /
devtmpfs                 18852         0     18852   0% /dev
tmpfs                    27556         0     27556   0% /dev/shm
tmpfs                    27556        32     27524   0% /tmp
tmpfs                    27556        68     27488   0% /run
ubi0:test_volume         17200     14936      1352  92% /mnt/ubifs
# ubimkvol /dev/ubi0 -N test_volume2 -s 15MiB
Volume ID 1, size 124 LEBs (15745024 bytes, 15.0 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "test_volume2", alignment 1
# mkdir -p /mnt/ubifs2/; mount -t ubifs ubi0:test_volume2 /mnt/ubifs2
[ 1491.419679] UBIFS (ubi0:1): default file-system created
[ 1491.428380] UBIFS (ubi0:1): Mounting in unauthenticated mode
[ 1491.439012] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 214
[ 1491.614619] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "test_volume2"
[ 1491.622701] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 1491.632704] UBIFS (ubi0:1): FS size: 14475264 bytes (13 MiB, 114 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 1491.643085] UBIFS (ubi0:1): reserved for root: 683702 bytes (667 KiB)
[ 1491.649575] UBIFS (ubi0:1): media format: w5/r0 (latest is w5/r0), UUID 90D01E93-DCFB-4015-916E-426926CA867C, small LPT model
[ 1491.665149] UBIFS (ubi0:1): full atime support is enabled.
# df
/dev/root               114901     92104     14196  87% /
ubi0:test_volume2        12384        20     11696   0% /mnt/ubifs2
# cd /mnt/ubifs2; dd if=/dev/urandom of=test2.bin bs=10M count=1
1+0 records in
1+0 records out
# md5sum test2.bin
a7a11444e92abb24b92da2d459142ef7  test2.bin
# md5sum test2.bin
执行命令:
md5sum /mnt/ubifs/test1.bin
md5sum /mnt/ubifs2/test2.bin
运行结果:
m[  117.787394] ubi0: attaching mtd4
kdir -p /mnt/ubifs/; mount -t ubifs ubi0:test_volume [  118.474268] ubi0: scanning is finished
/mnt/[  118.518382] ubi0: attached mtd4 (name "overlay", size 48 MiB)
[  118.524234] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[  118.531237] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[  118.538097] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[  118.545064] ubi0: good PEBs: 383, bad PEBs: 1, corrupted PEBs: 0
[  118.551153] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[  118.558415] ubi0: max/mean erase counter: 5/3, WL threshold: 4096, image sequence number: 1368536342
[  118.567585] ubi0: available PEBs: 70, total reserved PEBs: 313, PEBs reserved for bad PEB handling: 19
ubifs
mk[  118.579706] ubi0: background thread "ubi_bgt0d" started, PID 196
dir -UBI device number 0, total 383 LEBs (48631808 bytes, 46.3 MiB), available 70 LEBs (8888320 bytes, 8.4 MiB), LEB size 126976 bytes (124.0 KiB)
p /[  118.664103] UBIFS (ubi0:0): Mounting in unauthenticated mode
[  118.673953] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 200
mnt/ubifs2/; mount -[  118.908290] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "test_volume"
[  118.916285] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[  118.926338] UBIFS (ubi0:0): FS size: 19808256 bytes (18 MiB, 156 LEBs), journal size 1015809 bytes (0 MiB, 8 LEBs)
[  118.936716] UBIFS (ubi0:0): reserved for root: 935592 bytes (913 KiB)
[  118.943184] UBIFS (ubi0:0): media format: w5/r0 (latest is w5/r0), UUID DDF61ED8-29D8-41D3-B75C-D06A4B5B5FC8, small LPT model
t ubifs[  118.961970] UBIFS (ubi0:0): full atime support is enabled.
md5[  119.401852] UBIFS (ubi0:1): Mounting in unauthenticated mode
su[  119.412234] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 203
m[  119.644532] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "test_volume2"
[  119.652611] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[  119.662659] UBIFS (ubi0:1): FS size: 14475264 bytes (13 MiB, 114 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[  119.673054] UBIFS (ubi0:1): reserved for root: 683702 bytes (667 KiB)
[  119.679560] UBIFS (ubi0:1): media format: w5/r0 (latest is w5/r0), UUID 90D01E93-DCFB-4015-916E-426926CA867C, small LPT model
d5sum /m[  119.698437] UBIFS (ubi0:1): full atime support is enabled.
n#
# md5sum /mnt/ubifs/test1.bin
/ubifs2/test2.bin
30303d04108632117aa0f3a656dadb14  /mnt/ubifs/test1.bin
# md5sum /mnt/ubifs2/test2.bin
a7a11444e92abb24b92da2d459142ef7  /mnt/ubifs2/test2.bin
两个卷的随机数大文件校验码仍然正常。
楼主 #6 2021-02-19 16:14:14
raspberryman
已发帖子: 503
占坑
楼主 #7 2021-02-19 16:31:52
raspberryman
已发帖子: 503
占坑
楼主 #8 2021-02-19 16:32:17
raspberryman
已发帖子: 503
占坑
#9 2021-02-19 17:57:46
HackforFun
Cool
cool
楼主 #10 2021-02-20 09:30:03
raspberryman
已发帖子: 503
buildroot关于ubi文件系统的配置:
BR2_TARGET_ROOTFS_TAR=y
BR2_TARGET_ROOTFS_TAR_NONE=y
BR2_TARGET_ROOTFS_TAR_OPTIONS=""
BR2_TARGET_ROOTFS_UBI=y
BR2_TARGET_ROOTFS_UBI_PEBSIZE=0x20000
BR2_TARGET_ROOTFS_UBI_SUBSIZE=2048
BR2_TARGET_ROOTFS_UBI_OPTS=""
BR2_TARGET_ROOTFS_UBIFS=y
BR2_TARGET_ROOTFS_UBIFS_LEBSIZE=0x1f000
BR2_TARGET_ROOTFS_UBIFS_MINIOSIZE=0x800
BR2_TARGET_ROOTFS_UBIFS_MAXLEBCNT=2048
BR2_TARGET_ROOTFS_UBIFS_RT_LZO=y
BR2_TARGET_ROOTFS_UBIFS_NONE=y
BR2_TARGET_ROOTFS_UBIFS_OPTS=""
把buildroot生成的rootfs.ubi烧录到 nand flash:
# flash_eraseall /dev/mtd3
Erasing 128 Kibyte @ 33a0000 - 46% complete.
Skipping bad block at 0x033c0000
Erasing 128 Kibyte @ 57e0000 - 78% complete.
Skipping bad block at 0x05800000
Erasing 128 Kibyte @ 7000000 - 100% complete.
# ubiformat /dev/mtd3 -f /mnt/udisk/rootfs.ubi -s 2048 -O 2048
ubiformat: mtd3 (nand), size 117440512 bytes (112.0 MiB), 896 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 895 -- 100 % complete
ubiformat: 894 eraseblocks are supposedly empty
ubiformat: 2 bad eraseblocks found, numbers: 414, 704
ubiformat: flashing eraseblock 422 -- 100 % complete
ubiformat: formatting eraseblock 895 -- 100 % complete
# ubiattach /dev/ubi_ctrl -m 3
[ 2338.369507] ubi0: attaching mtd3
[ 2339.932799] ubi0: scanning is finished
[ 2339.996910] ubi0: volume 0 ("rootfs") re-sized from 420 to 872 LEBs
[ 2340.021735] ubi0: attached mtd3 (name "rootfs", size 112 MiB)
[ 2340.027648] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2340.034519] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2340.041381] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2340.048382] ubi0: good PEBs: 894, bad PEBs: 2, corrupted PEBs: 0
[ 2340.054382] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2340.061631] ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 1797218344
[ 2340.070778] ubi0: available PEBs: 0, total reserved PEBs: 894, PEBs reserved for bad PEB handling: 18
[ 2340.082502] ubi0: background thread "ubi_bgt0d" started, PID 242
UBI device number 0, total 894 LEBs (113516544 bytes, 108.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
# mkdir -p /mnt/rootfs/; mount -t ubifs ubi0:rootfs /mnt/rootfs
[ 2424.798470] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 2424.815509] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 247
[ 2425.061164] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2425.068703] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2425.078691] UBIFS (ubi0:0): FS size: 109326336 bytes (104 MiB, 861 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 2425.089322] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 2425.095205] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID C2613C70-55A8-4922-BAD7-FC87B64728E0, small LPT model
[ 2425.122645] UBIFS (ubi0:0): full atime support is enabled.
# df
/dev/root               114901     92109     14191  87% /
tmpfs                    27556       356     27200   1% /tmp
tmpfs                    27556        88     27468   0% /run
/dev/sda               1920768     54048   1866720   3% /mnt/udisk
ubi0:rootfs              98056     47932     50124  49% /mnt/rootfs
# ls /mnt/rootfs/
bin/      lib/      media/    overlay/  root/     sys/      var/
dev/      lib32/    mnt/      proc/     run/      tmp/
etc/      linuxrc   opt/      rom/      sbin/     usr/
# md5sum  /mnt/rootfs/bin/busybox
cdb44d81c489bc9d4f82e4a27253433f  /mnt/rootfs/bin/busybox
至此, 我们用ubifs 作为根文件系统的任务已经完成一大半了。
楼主 #11 2021-02-20 10:19:54
raspberryman
已发帖子: 503
使用aodzip的sd卡镜像启动,敲回车进入uboot命令行, 手动输入下面三行命令可以从sd卡引脚:
setenv bootargs "console=ttyS0,115200 earlyprintk rootwait consoleblank=0 net.ifnames=0 biosdevname=0 root=/dev/mmcblk0p3"
setenv bootcmd  "load mmc 0:2 0x80000000 zImage; load mmc 0:2 0x80700000 devicetree.dtb;bootz 0x80000000 - 0x80700000;"
boot
手动输入这几行命令, 也可以sd卡引导,但是根文件系统已经是ubifs了:
sf probe 1000000
sf probe 10000000
setenv bootargs "console=ttyS0,115200 earlyprintk rootwait consoleblank=0 net.ifnames=0 biosdevname=0 root=ubi0:rootfs rw rootflags=sync rootfstype=ubifs ubi.mtd=3"
boot
这是启动log:
U-Boot SPL 2020.07 (Feb 19 2021 - 12:13:05 +0800)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2020.07 (Feb 19 2021 - 12:13:05 +0800) Allwinner Technology
DRAM:  64 MiB
In:    serial
Out:   vga
Err:   vga
=> sf probe
unrecognized JEDEC id bytes: ff, c8, f1
=> sf probe 1000000
unrecognized JEDEC id bytes: 00, c8, f1
Failed to initialize SPI flash at 0:1000000 (error -2)
=> sf probe 10000000
Failed to initialize SPI flash at 0:10000000 (error -2)
=> setenv bootargs "console=ttyS0,115200 earlyprintk rootwait consoleblank=0 net.ifnames=0 biosdevname=0 root=ubi0:rootfs rw rootflags=sync rootfstype=ubifs ubi.mtd=3"
=> setenv bootcmd  "load mmc 0:2 0x80000000 zImage; load mmc 0:2 0x80700000 devicetree.dtb;bootz 0x80000000 - 0x80700000;"
=> boot
4613080 bytes read in 750 ms (5.9 MiB/s)
14901 bytes read in 7 ms (2 MiB/s)
## Flattened Device Tree blob at 80700000
   Booting using the fdt blob at 0x80700000
   Loading Device Tree to 816f9000, end 816ffa34 ... OK
[    0.000000] Linux version 5.4.66 (cube@ubuntu) (gcc version 8.4.0 (Buildroot 2020.02.4-00005-g9d84975a2d)) #2 Fri Feb 19 14:15:21 CST 2021
[    0.000000] OF: fdt: Machine model: Widora MangoPi R3
[    0.000000] cma: Reserved 16 MiB at 0x83000000
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk rootwait consoleblank=0 net.ifnames=0 biosdevname=0 root=ubi0:rootfs rw rootflags=sync rootfstype=ubifs ubi.mtd=3
[    0.000000] Memory: 37708K/65536K available (7168K kernel code, 253K rwdata, 1752K rodata, 1024K init, 228K bss, 11444K reserved, 16384K cma-reserved)
[    0.000051] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000146] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000897] Console: colour dummy device 80x30
[    0.001006] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070269] pid_max: default: 32768 minimum: 301
[    0.070774] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.070816] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.072732] CPU: Testing write buffer coherency: ok
[    0.074840] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076158] devtmpfs: initialized
[    0.087670] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.087741] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.091985] pinctrl core: initialized pinctrl subsystem
[    0.094714] NET: Registered protocol family 16
[    0.098625] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.100968] cpuidle: using governor menu
[    0.149556] SCSI subsystem initialized
[    0.149974] usbcore: registered new interface driver usbfs
[    0.150151] usbcore: registered new interface driver hub
[    0.150482] usbcore: registered new device driver usb
[    0.151020] mc: Linux media interface: v0.10
[    0.151148] videodev: Linux video capture interface: v2.00
[    0.151274] pps_core: LinuxPPS API ver. 1 registered
[    0.151294] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.151361] PTP clock support registered
[    0.152448] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[    0.153474] Advanced Linux Sound Architecture Driver Initialized.
[    0.156033] clocksource: Switched to clocksource timer
[    0.187887] thermal_sys: Registered thermal governor 'step_wise'
[    0.188647] NET: Registered protocol family 2
[    0.190251] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.190356] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.190417] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.190472] TCP: Hash tables configured (established 1024 bind 1024)
[    0.190797] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.190861] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.191377] NET: Registered protocol family 1
[    0.194196] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.196142] Initialise system trusted keyrings
[    0.196785] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.218403] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.219017] jffs2: version 2.2. (NAND) (SUMMARY)  ? 2001-2006 Red Hat, Inc.
[    0.333754] Key type asymmetric registered
[    0.333797] Asymmetric key parser 'x509' registered
[    0.333976] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.334006] io scheduler mq-deadline registered
[    0.334024] io scheduler kyber registered
[    0.349792] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.374405] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.380689] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[    0.382050] printk: console [ttyS0] disabled
[    0.402366] 1c25400.serial: ttyS0 at MMIO 0x1c25400 (irq = 28, base_baud = 6250000) is a 16550A
[    0.836213] printk: console [ttyS0] enabled
[    0.846141] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    0.867399] panel-simple panel: panel supply power not found, using dummy regulator
[    0.877103] SCSI Media Changer driver v0.25
[    0.882889] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.895727] spi-nand spi0.0: GigaDevice SPI NAND was found.
[    0.901430] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    0.911035] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.917508] Creating 4 MTD partitions on "spi0.0":
[    0.922319] 0x000000000000-0x000000080000 : "u-boot"
[    0.932832] 0x000000080000-0x0000000a0000 : "dtb"
[    0.941783] 0x000000100000-0x000000800000 : "kernel"
[    0.950003] random: fast init done
[    0.980009] 0x000000800000-0x000007800000 : "rootfs"
[    1.402173] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.408827] ehci-platform: EHCI generic platform driver
[    1.414476] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.420788] ohci-platform: OHCI generic platform driver
[    1.426594] usbcore: registered new interface driver usb-storage
[    1.433571] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.445500] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.451503] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.461545] hub 1-0:1.0: USB hub found
[    1.465450] hub 1-0:1.0: 1 port detected
[    1.472619] i2c /dev entries driver
[    1.476904] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    1.490501] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    1.501522] sun4i-csi 1cb0000.csi: Packed (RAW) format enabled.
[    1.509439] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.519519] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.557652] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.567195] usbcore: registered new interface driver usbhid
[    1.572769] usbhid: USB HID core driver
[    1.577049] sunxi-cedar 1c0e000.video-codec: sunxi cedar version 0.01alpha
[    1.584253] sunxi-cedar 1c0e000.video-codec: cedar-ve the get irq is 20
[    1.596530] debugfs: Directory '1c23c00.codec' with parent 'F1C100s Audio Codec' already present!
[    1.610346] sun4i-codec 1c23c00.codec: Codec <-> 1c23c00.codec mapping ok
[    1.626408] NET: Registered protocol family 17
[    1.630974] Key type dns_resolver registered
[    1.636695] Loading compiled-in X.509 certificates
[    1.660968] sun4i-drm soc:display-engine: bound 1e00000.display-frontend (ops 0xc083d0a0)
[    1.670060] sun4i-drm soc:display-engine: bound 1e60000.display-backend (ops 0xc083c8e0)
[    1.679651] sun4i-drm soc:display-engine: bound 1c0c000.lcd-controller (ops 0xc083b480)
[    1.688224] sun4i-drm soc:display-engine: bound 1c0a000.tv-encoder (ops 0xc083c1a0)
[    1.695886] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.702599] [drm] No driver support for vblank timestamp query.
[    1.710256] [drm] Initialized sun4i-drm 1.0.0 20150629 for soc:display-engine on minor 0
[    1.719318] [drm] kms: can't enable cloning when we probably wanted to.
[    1.791243] Console: switching to colour frame buffer device 100x30
[    1.793879] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.796674] mmc0: new high speed SD card at address 0001
[    1.798984] mmcblk0: mmc0:0001 00000 1.83 GiB
[    1.830776]  mmcblk0: p1 p2 p3
[    1.855478] sun4i-drm soc:display-engine: fb0: sun4i-drmdrmfb frame buffer device
[    1.864055] ubi0: attaching mtd3
[    1.878025] random: crng init done
[    3.423082] ubi0: scanning is finished
[    3.453782] ubi0: attached mtd3 (name "rootfs", size 112 MiB)
[    3.459706] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    3.466645] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    3.473421] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    3.480441] ubi0: good PEBs: 894, bad PEBs: 2, corrupted PEBs: 0
[    3.486491] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[    3.493730] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1797218344
[    3.502884] ubi0: available PEBs: 0, total reserved PEBs: 894, PEBs reserved for bad PEB handling: 18
[    3.512774] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.521005] ubi0: background thread "ubi_bgt0d" started, PID 60
[    3.536715] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.543541] ALSA device list:
[    3.546645]   #0: F1C100s Audio Codec
[    3.550867] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.559634] cfg80211: failed to load regulatory.db
[    3.566817] UBIFS: parse sync
[    3.572891] UBIFS (ubi0:0): Mounting in unauthenticated mode
[    3.582724] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 65
[    3.851755] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    3.859311] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    3.869328] UBIFS (ubi0:0): FS size: 109326336 bytes (104 MiB, 861 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[    3.879963] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[    3.885832] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID C2613C70-55A8-4922-BAD7-FC87B64728E0, small LPT model
[    3.903107] UBIFS (ubi0:0): full atime support is enabled.
[    3.908873] VFS: Mounted root (ubifs filesystem) on device 0:16.
[    3.918242] devtmpfs: mounted
[    3.927799] Freeing unused kernel memory: 1024K
[    3.932838] Run /sbin/init as init process
Mounting OverlayFS: Skip
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [    5.675841] udevd[97]: starting version 3.2.9
[    5.967378] udevd[98]: starting eudev-3.2.9
[    8.152908] Goodix-TS 0-005d: 0-005d supply AVDD28 not found, using dummy regulator
[    8.161063] Goodix-TS 0-005d: 0-005d supply VDDIO not found, using dummy regulator
[    8.178104] ov2640 0-0030: Product ID error fa:fa
[    8.329337] Goodix-TS 0-005d: i2c test failed attempt 1: -6
[    8.369858] Goodix-TS 0-005d: i2c test failed attempt 2: -6
[    8.406275] Goodix-TS 0-005d: I2C communication failure: -6
# df
ubi0:rootfs              98056     47964     50092  49% /
tmpfs                    27556        76     27480   0% /run
# md5sum /bin/busybox
cdb44d81c489bc9d4f82e4a27253433f  /bin/busybox
从日志看,ubifs根文件系统已经完全正常:
# df
参考: https://www.cnblogs.com/zxc2man/p/7568731.html
