楼主 # 2024-01-10 22:36:26
nTliang
已发帖子: 35
请教关于F1C100S的声卡使用speaker-test播放无声音问题
使用的linux6.1.54版本内核,移植论坛大佬提供的驱动。
目前现象是驱动加载后引脚上能有1.5V电压,声卡也能正常的显示出来。
内核启动时有以下输出:
[    1.191964] ALSA device list:
[    1.195021]   #0: Loopback 1
[    1.197913]   #1: suniv Audio Codec
然后使用speaker-test播放时喇叭只有一个上电的吧嗒声。
在DMA和声卡驱动中加上日志输出,从日志看DMA和声卡都有正常工作。
按理speaker-test播放应该会输出噪音,不知道有没有哪位大佬知道什么情况?
附播放时DMA驱动和声卡驱动日志:
[  491.569777] !!!sun4i_dma_prep_dma_cyclic,len:524288,per:131072, dir:1!!!
[  491.577985]
[  491.577985] !!!generate_ndma_promise,len:131072,src:-2118123520,dest:29506572!!!
[  491.586836]
[  491.586836] !!!sanitize_config!!!
[  491.591623] dma dma0chan0: src burst 4, dst burst 4, src buswidth 2, dst buswidth 2
[  491.599265]
[  491.599265] !!!convert_burst_f1c100s!!!
[  491.604553]
[  491.604553] !!!convert_burst_f1c100s!!!
[  491.609846]
[  491.609846] !!!convert_buswidth!!!
[  491.614707]
[  491.614707] !!!set_src_data_width_f1c100s, w:1!!!
[  491.620866]
[  491.620866] !!!convert_buswidth!!!
[  491.625727]
[  491.625727] !!!set_dst_data_width_f1c100s, w:1!!!
[  491.631888]
[  491.631888] !!!generate_ndma_promise,len:131072,src:-2117992448,dest:29506572!!!
[  491.640730]
[  491.640730] !!!sanitize_config!!!
[  491.645509] dma dma0chan0: src burst 4, dst burst 4, src buswidth 2, dst buswidth 2
[  491.653145]
[  491.653145] !!!convert_burst_f1c100s!!!
[  491.658439]
[  491.658439] !!!convert_burst_f1c100s!!!
[  491.663732]
[  491.663732] !!!convert_buswidth!!!
[  491.668593]
[  491.668593] !!!set_src_data_width_f1c100s, w:1!!!
[  491.674753]
[  491.674753] !!!convert_buswidth!!!
[  491.679614]
[  491.679614] !!!set_dst_data_width_f1c100s, w:1!!!
[  491.685773]
[  491.685773] !!!generate_ndma_promise,len:131072,src:-2117861376,dest:29506572!!!
[  491.694615]
[  491.694615] !!!sanitize_config!!!
[  491.699393] dma dma0chan0: src burst 4, dst burst 4, src buswidth 2, dst buswidth 2
[  491.707030]
[  491.707030] !!!convert_burst_f1c100s!!!
[  491.712324]
[  491.712324] !!!convert_burst_f1c100s!!!
[  491.717618]
[  491.717618] !!!convert_buswidth!!!
[  491.722478]
[  491.722478] !!!set_src_data_width_f1c100s, w:1!!!
[  491.728637]
[  491.728637] !!!convert_buswidth!!!
[  491.733497]
[  491.733497] !!!set_dst_data_width_f1c100s, w:1!!!
[  491.739657]
[  491.739657] !!!generate_ndma_promise,len:131072,src:-2117730304,dest:29506572!!!
[  491.748499]
[  491.748499] !!!sanitize_config!!!
[  491.753278] dma dma0chan0: src burst 4, dst burst 4, src buswidth 2, dst buswidth 2
[  491.760915]
[  491.760915] !!!convert_burst_f1c100s!!!
[  491.766210]
[  491.766210] !!!convert_burst_f1c100s!!!
[  491.771504]
[  491.771504] !!!convert_buswidth!!!
[  491.776364]
[  491.776364] !!!set_src_data_width_f1c100s, w:1!!!
[  491.782523]
[  491.782523] !!!convert_buswidth!!!
[  491.787384]
[  491.787384] !!!set_dst_data_width_f1c100s, w:1!!!
[  491.793546]
[  491.793546] !!!sun4i_dma_issue_pending!!!
[  491.799013]
[  491.799013] !!!__execute_vchan_pending!!!
[  491.804480]
[  491.804480] !!!find_and_use_pchan!!!
[  491.809516]
[  491.809516] !!!to_sun4i_dma_contract!!!
[  491.814812]
[  491.814812] !!!set_pchan_interrupt,half:1,num:0!!!
[  491.821060]
[  491.821060] !!!configure_pchan,-2118123520,29506572,131072,-2119401071!!!
[  491.829307]
[  491.829307] !!!sun4i_codec_start_playback!!!
[  492.516437]
[  492.516437] !!!sun4i_dma_interrupt!!!
[  492.521605]
[  492.521605] !!!half done interrupt, 1!!!
[  492.527012]
[  492.527012] !!!sun4i_dma_tx_status,ret:1,state!!!-1060102820
[  492.534135]
[  492.534135] !!!to_sun4i_dma_contract!!!
[  492.539431]
[  492.539431] !!!bytes:524288!!!
[  493.199899]
[  493.199899] !!!sun4i_dma_interrupt!!!
[  493.205069]
[  493.205069] !!!get_next_cyclic_promise!!!
[  493.210544]
[  493.210544] !!!configure_pchan,-2117992448,29506572,131072,-2119401071!!!
[  493.218811]
[  493.218811] !!!sun4i_dma_tx_status,ret:1,state!!!-1060102820
[  493.225933]
[  493.225933] !!!to_sun4i_dma_contract!!!
[  493.231227]
[  493.231227] !!!bytes:393216!!!
[  493.900203]
[  493.900203] !!!sun4i_dma_interrupt!!!
[  493.905368]
[  493.905368] !!!half done interrupt, 1!!!
[  493.910776]
[  493.910776] !!!sun4i_dma_tx_status,ret:1,state!!!-1060102820
[  493.917901]
[  493.917901] !!!to_sun4i_dma_contract!!!
[  493.923199]
[  493.923199] !!!bytes:393216!!!
[  494.583653]
[  494.583653] !!!sun4i_dma_interrupt!!!
[  494.588824]
[  494.588824] !!!get_next_cyclic_promise!!!
[  494.594296]
[  494.594296] !!!configure_pchan,-2117861376,29506572,131072,-2119401071!!!
[  494.602562]
[  494.602562] !!!sun4i_dma_tx_status,ret:1,state!!!-1060102820
[  494.609684]
[  494.609684] !!!to_sun4i_dma_contract!!!
[  494.614979]
[  494.614979] !!!bytes:262144!!!
[  494.619511]
[  494.619511] !!!sun4i_codec_stop_playback!!!
[  494.625168]
[  494.625168] !!!sun4i_dma_terminate_all!!!
[  494.630641]
[  494.630641] !!!set_pchan_interrupt,half:0,num:0!!!
[  494.636892]
[  494.636892] !!!release_pchan!!!
[  494.641496]
[  494.641496] !!!to_sun4i_dma_contract!!!
[  494.646791]
[  494.646791] !!!sun4i_dma_free_contract!!!
[  494.652408]
[  494.652408] !!!sun4i_codec_prepare!!!
[  494.657576]
[  494.657576] !!!sun4i_codec_prepare_playback!!!
楼主 #1 2024-01-12 22:52:26
nTliang
已发帖子: 35
Re: 请教关于F1C100S的声卡使用speaker-test播放无声音问题
已经解决,使用alsamixer把音量设大没有什么用,我以为把音量开启就可以了。
使用tinymix -D 1 contents 发现switch并没有开启。
使用tinymix -D 1 set 2 1开启switch后再使用speaker-test就有噪音输出了。
#2 2024-09-18 22:09:40
bqd199709
有内核参考吗?声卡出来了就是一直播放失败,不知道哪里少改还是什么
楼主 #4 2024-11-04 09:02:58
nTliang
已发帖子: 35
https://www.bilibili.com/video/BV1pi421a7iZ/?spm_id_from=333.999.0.0
这个视频有教程
