目前网上能找到的都是3.4 4.9 和5.4版本的驱动,自己尝试修改了4.9版本的xr829驱动到3.10内核版本中,发现运行不了,一直驱动不起来,有没有大佬做过,求一份驱动,我的硬件版本是F1C200s Tina sdk 3.5.1
有大佬做过么f1c200s 的tina sdk中添加xr829网卡么,有偿求一份
从 linux3.4 里面复制过去试一试:
lichee/linux-3.4/drivers/net/wireless/xr829
试过了,直接复制到c200s的板子中好多编译报错,接口需要改动
现在我这边改了一下接口,目前能够成功编译出来.ko文件了也能够加载,但是调用wifi的时候显示接口报错
目前insmod xr829可以正常加载了,再系统中也能正常的看到网卡设备了,但是wifi还是不能正常使用,也不知道问题出在哪里了,有大佬知道的么
下面是加载驱动打样的信息
[ 114.160762] ======== XRADIO WIFI OPEN ========
[ 114.175860] [XRADIO_ERR] <try_create_hwinfo_buffer : 1513>read hwinfo file:/tmp/hwinfo.bin failed!
[ 114.186041] [XRADIO] Driver Label:XR_V02.16.77_HT40_01.31 Jun 30 2024 09:33:05
[ 114.197532] [XRADIO] Allocated hw_priv @ c1b90fa0
[ 114.206299] sunxi-wlan wlan: bus_index: 0
[ 114.320923] [XRADIO] Detect SDIO card 0
[ 114.336079] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 114.365446] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 114.394618] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 114.408681] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 114.422091] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 114.443349] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 114.454933] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 114.466830] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 114.479751] mmc0: new high speed SDIO card at address 0001
[ 114.495005] [SBUS] XRadio Device:sdio clk=50000000
[ 114.525035] [XRADIO] XRADIO_HW_REV 1.0 detected.
[ 114.624683] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
[ 114.739374] [XRADIO] Bootloader complete
[ 114.861895] [XRADIO] Firmware completed.
[ 114.877836] [WSM] Firmware Label:XR_C09.08.52.64_DBG_02.85 2GHZ HT40 Apr 9 2019 11:15:08
[ 114.888069] [XRADIO] Firmware Startup Done.
[ 114.894755] [XRADIO_WRN] enable Multi-Rx!
[ 114.901150] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
[ 114.910123] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 114.918481] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
[ 114.927300] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 114.935641] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
[ 114.944452] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 114.952750] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
[ 114.961566] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 114.969890] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
[ 114.978705] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 114.987029] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
[ 114.995840] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.004177] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
[ 115.012957] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.021297] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
[ 115.030121] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.038452] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
[ 115.047259] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.055592] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
[ 115.064399] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.072694] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
[ 115.081508] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.089831] cfg80211: Updating information on frequency 2467 MHz with regulatory rule:
[ 115.098638] cfg80211: 2457000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.106967] cfg80211: Updating information on frequency 2472 MHz with regulatory rule:
[ 115.115774] cfg80211: 2457000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 115.124096] cfg80211: Updating information on frequency 2484 MHz with regulatory rule:
[ 115.132884] cfg80211: 2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[ 115.159424] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'离线
目前好像调试成功了,能够扫描到wifi网络了,但是硬件设计的天线好像有点问题,扫描到的wifi比较少
root@TinaLinux:/etc/init.d# wifi_scan_results_test ?[J
***Start scan!***
bssid / frequency / signal level / flags / ssid
60:fa:9d:0b:83:70 2437 -63 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS] ChinaNet-wQLp
80:b5:75:16:07:e8 2437 -79 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS] ChinaNet-YejT
Wifi get_scan_results: Success!
******************************离线
