看v3s的原理图,找不到按钮对应的引脚号.......
最近编辑记录 605364021 (2018-11-18 14:02:59)
有人可以告诉一下,v3s板子的按钮时是哪个引脚?
看了ilichee-zero的原理图。
四个按钮是adc按钮,通过电阻分压,接到了LRADC0管脚。
Gentlepig wrote:
看了ilichee-zero的原理图。
谢谢
v3s使用ADC按键,怎么用驱动实现检测按键按下?
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/drivers/input/keyboard/sun4i-lradc-keys.c
* Allwinner sun4i low res adc attached tablet keys driver
* Copyright (C) 2014 Hans de Goede <hdegoede@redhat.com>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* Allwinnner sunxi SoCs have a lradc which is specifically designed to have
* various (tablet) keys (ie home, back, search, etc). attached to it using
* a resistor network. This driver is for the keys on such boards.
* There are 2 channels, currently this driver only supports channel 0 since
* there are no boards known to use channel 1.
#include <linux/err.h>
#include <linux/init.h>
#include <linux/input.h>
#include <linux/interrupt.h>
#include <linux/io.h>
#include <linux/module.h>
#include <linux/of_platform.h>
#include <linux/platform_device.h>
#include <linux/regulator/consumer.h>
#include <linux/slab.h>
#define LRADC_CTRL 0x00
#define LRADC_INTC 0x04
#define LRADC_INTS 0x08
#define LRADC_DATA0 0x0c
#define LRADC_DATA1 0x10
/* LRADC_CTRL bits */
#define FIRST_CONVERT_DLY(x) ((x) << 24) /* 8 bits */
#define CHAN_SELECT(x) ((x) << 22) /* 2 bits */
#define CONTINUE_TIME_SEL(x) ((x) << 16) /* 4 bits */
#define KEY_MODE_SEL(x) ((x) << 12) /* 2 bits */
#define LEVELA_B_CNT(x) ((x) << 8) /* 4 bits */
#define HOLD_EN(x) ((x) << 6)
#define LEVELB_VOL(x) ((x) << 4) /* 2 bits */
#define SAMPLE_RATE(x) ((x) << 2) /* 2 bits */
#define ENABLE(x) ((x) << 0)
/* LRADC_INTC and LRADC_INTS bits */
#define CHAN1_KEYUP_IRQ BIT(12)
#define CHAN1_ALRDY_HOLD_IRQ BIT(11)
#define CHAN1_HOLD_IRQ BIT(10)
#define CHAN1_KEYDOWN_IRQ BIT(9)
#define CHAN1_DATA_IRQ BIT(8)
#define CHAN0_KEYUP_IRQ BIT(4)
#define CHAN0_ALRDY_HOLD_IRQ BIT(3)
#define CHAN0_HOLD_IRQ BIT(2)
#define CHAN0_KEYDOWN_IRQ BIT(1)
#define CHAN0_DATA_IRQ BIT(0)
struct sun4i_lradc_keymap {
u32 voltage;
u32 keycode;
struct sun4i_lradc_data {
struct device *dev;
struct input_dev *input;
void __iomem *base;
struct regulator *vref_supply;
struct sun4i_lradc_keymap *chan0_map;
u32 chan0_map_count;
u32 chan0_keycode;
u32 vref;
static irqreturn_t sun4i_lradc_irq(int irq, void *dev_id)
struct sun4i_lradc_data *lradc = dev_id;
u32 i, ints, val, voltage, diff, keycode = 0, closest = 0xffffffff;
ints = readl(lradc->base + LRADC_INTS);
* lradc supports only one keypress at a time, release does not give
* any info as to which key was released, so we cache the keycode.
if (ints & CHAN0_KEYUP_IRQ) {
input_report_key(lradc->input, lradc->chan0_keycode, 0);
lradc->chan0_keycode = 0;
if ((ints & CHAN0_KEYDOWN_IRQ) && lradc->chan0_keycode == 0) {
val = readl(lradc->base + LRADC_DATA0) & 0x3f;
voltage = val * lradc->vref / 63;
for (i = 0; i < lradc->chan0_map_count; i++) {
diff = abs(lradc->chan0_map[i].voltage - voltage);
if (diff < closest) {
closest = diff;
keycode = lradc->chan0_map[i].keycode;
lradc->chan0_keycode = keycode;
input_report_key(lradc->input, lradc->chan0_keycode, 1);
input_sync(lradc->input);
writel(ints, lradc->base + LRADC_INTS);
return IRQ_HANDLED;
static int sun4i_lradc_open(struct input_dev *dev)
struct sun4i_lradc_data *lradc = input_get_drvdata(dev);
int error;
error = regulator_enable(lradc->vref_supply);
if (error)
return error;
/* lradc Vref internally is divided by 2/3 */
lradc->vref = regulator_get_voltage(lradc->vref_supply) * 2 / 3;
* Set sample time to 4 ms / 250 Hz. Wait 2 * 4 ms for key to
* stabilize on press, wait (1 + 1) * 4 ms for key release
writel(FIRST_CONVERT_DLY(2) | LEVELA_B_CNT(1) | HOLD_EN(1) |
SAMPLE_RATE(0) | ENABLE(1), lradc->base + LRADC_CTRL);
writel(CHAN0_KEYUP_IRQ | CHAN0_KEYDOWN_IRQ, lradc->base + LRADC_INTC);
static void sun4i_lradc_close(struct input_dev *dev)
/* Disable lradc, leave other settings unchanged */
SAMPLE_RATE(2), lradc->base + LRADC_CTRL);
writel(0, lradc->base + LRADC_INTC);
regulator_disable(lradc->vref_supply);
static int sun4i_lradc_load_dt_keymap(struct device *dev,
struct sun4i_lradc_data *lradc)
struct device_node *np, *pp;
int i;
int error;
np = dev->of_node;
if (!np)
return -EINVAL;
lradc->chan0_map_count = of_get_child_count(np);
if (lradc->chan0_map_count == 0) {
dev_err(dev, "keymap is missing in device tree\n");
return -EINVAL;
lradc->chan0_map = devm_kmalloc_array(dev, lradc->chan0_map_count,
sizeof(struct sun4i_lradc_keymap),
GFP_KERNEL);
if (!lradc->chan0_map)
return -ENOMEM;
i = 0;
for_each_child_of_node(np, pp) {
struct sun4i_lradc_keymap *map = &lradc->chan0_map[i];
u32 channel;
error = of_property_read_u32(pp, "channel", &channel);
if (error || channel != 0) {
dev_err(dev, "%s: Inval channel prop\n", pp->name);
return -EINVAL;
error = of_property_read_u32(pp, "voltage", &map->voltage);
if (error) {
dev_err(dev, "%s: Inval voltage prop\n", pp->name);
return -EINVAL;
error = of_property_read_u32(pp, "linux,code", &map->keycode);
if (error) {
dev_err(dev, "%s: Inval linux,code prop\n", pp->name);
return -EINVAL;
i++;
static int sun4i_lradc_probe(struct platform_device *pdev)
struct sun4i_lradc_data *lradc;
struct device *dev = &pdev->dev;
int i;
int error;
lradc = devm_kzalloc(dev, sizeof(struct sun4i_lradc_data), GFP_KERNEL);
if (!lradc)
return -ENOMEM;
error = sun4i_lradc_load_dt_keymap(dev, lradc);
if (error)
return error;
lradc->vref_supply = devm_regulator_get(dev, "vref");
if (IS_ERR(lradc->vref_supply))
return PTR_ERR(lradc->vref_supply);
lradc->dev = dev;
lradc->input = devm_input_allocate_device(dev);
if (!lradc->input)
return -ENOMEM;
lradc->input->name = pdev->name;
lradc->input->phys = "sun4i_lradc/input0";
lradc->input->open = sun4i_lradc_open;
lradc->input->close = sun4i_lradc_close;
lradc->input->id.bustype = BUS_HOST;
lradc->input->id.vendor = 0x0001;
lradc->input->id.product = 0x0001;
lradc->input->id.version = 0x0100;
__set_bit(EV_KEY, lradc->input->evbit);
__set_bit(lradc->chan0_map[i].keycode, lradc->input->keybit);
input_set_drvdata(lradc->input, lradc);
lradc->base = devm_ioremap_resource(dev,
platform_get_resource(pdev, IORESOURCE_MEM, 0));
if (IS_ERR(lradc->base))
return PTR_ERR(lradc->base);
error = devm_request_irq(dev, platform_get_irq(pdev, 0),
sun4i_lradc_irq, 0,
"sun4i-a10-lradc-keys", lradc);
if (error)
return error;
error = input_register_device(lradc->input);
if (error)
return error;
static const struct of_device_id sun4i_lradc_of_match[] = {
{ .compatible = "allwinner,sun4i-a10-lradc-keys", },
{ /* sentinel */ }
MODULE_DEVICE_TABLE(of, sun4i_lradc_of_match);
static struct platform_driver sun4i_lradc_driver = {
.driver = {
.name = "sun4i-a10-lradc-keys",
.of_match_table = of_match_ptr(sun4i_lradc_of_match),
.probe = sun4i_lradc_probe,
module_platform_driver(sun4i_lradc_driver);
MODULE_DESCRIPTION("Allwinner sun4i low res adc attached tablet keys driver");
MODULE_AUTHOR("Hans de Goede <hdegoede@redhat.com>");
MODULE_LICENSE("GPL");离线
v3s自带sun4i-lradc-keys.c驱动,但是我想做一个简单点的adc按键检测驱动,是需要依据自带的lradc驱动来改?
完全可以
在已有sun4i-lradc-keys.c驱动情况下,怎么检测按键按下后出现了电压变化?
简单点就这样:
cat /dev/input/eventX
lilo wrote:
简单点就这样:
cat到的都是一串乱码
我现在想做一个没有中断的按键驱动,但是我不知道怎么实现电压的区分来判断哪个按键按下
bsp的没找到这个按键驱动
可能有,再仔细找找,实在没有就照着抄一次,有错改错。
谢谢,我发现BSP应该是sunxi-keyboard.c
