楼主 #1 2019-11-04 13:00:27
wupaul2001
已发帖子: 307
新版buildroot去掉了mplayer,请问大家,用那个播放器代替???
如题
#2 2019-11-04 13:26:06
已发帖子: 856
Re: 新版buildroot去掉了mplayer,请问大家,用那个播放器代替???
wupaul2001 wrote:
如题
要播放视频吗?那还是用mplayer比较合适。音频用mpg123。buildroot没有可以用debian系统,想安装什么都可以,apt一键搞定
最近编辑记录 kekemuyu (2019-11-04 13:26:23)
#3 2019-11-04 13:56:24
xgui
已发帖子: 224
果然过期了, 2018.05版本就过期了, 不说我还不知道呢。
这么好用的软件包为什么要踢出去呢?难道只能用回旧版本buildroot?
# Legacy options removed in 2018.05
# BR2_PACKAGE_MEDIAART_BACKEND_NONE is not set
# BR2_PACKAGE_MEDIAART_BACKEND_GDK_PIXBUF is not set
# BR2_PACKAGE_TI_SGX_AM335X is not set
# BR2_PACKAGE_TI_SGX_AM437X is not set
# BR2_PACKAGE_TI_SGX_AM4430 is not set
# BR2_PACKAGE_TI_SGX_AM5430 is not set
# BR2_PACKAGE_JANUS_AUDIO_BRIDGE is not set
# BR2_PACKAGE_JANUS_ECHO_TEST is not set
# BR2_PACKAGE_JANUS_RECORDPLAY is not set
# BR2_PACKAGE_JANUS_SIP_GATEWAY is not set
# BR2_PACKAGE_JANUS_STREAMING is not set
# BR2_PACKAGE_JANUS_TEXT_ROOM is not set
# BR2_PACKAGE_JANUS_VIDEO_CALL is not set
# BR2_PACKAGE_JANUS_VIDEO_ROOM is not set
# BR2_PACKAGE_JANUS_MQTT is not set
# BR2_PACKAGE_JANUS_RABBITMQ is not set
# BR2_PACKAGE_JANUS_REST is not set
# BR2_PACKAGE_JANUS_UNIX_SOCKETS is not set
# BR2_PACKAGE_JANUS_WEBSOCKETS is not set
# BR2_PACKAGE_IPSEC_SECCTX_DISABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_ENABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_KERNEL is not set
# BR2_PACKAGE_LIBTFDI_CPP is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLACK_TIE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLITZER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_CUPERTINO is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DARK_HIVE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DOT_LUV is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EGGPLANT is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EXCITE_BIKE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_FLICK is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HOT_SNEAKS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HUMANITY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_LE_FROG is not set
# BR2_PACKAGE_JQUERY_UI_THEME_MINT_CHOC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_OVERCAST is not set
# BR2_PACKAGE_JQUERY_UI_THEME_PEPPER_GRINDER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_REDMOND is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SMOOTHNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SOUTH_STREET is not set
# BR2_PACKAGE_JQUERY_UI_THEME_START is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SUNNY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SWANKY_PURSE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_TRONTASTIC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_DARKNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_LIGHTNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_VADER is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_HEALTH is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_MIDI is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_NFC is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SAP is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SIXAXIS is not set
# BR2_PACKAGE_TRANSMISSION_REMOTE is not set
# BR2_PACKAGE_LIBKCAPI_APPS is not set
# BR2_PACKAGE_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MENCODER is not set
# BR2_PACKAGE_LIBPLAYER_MPLAYER is not set
#4 2019-11-04 14:22:09
checkout
已发帖子: 173
用MPV
#5 2019-11-04 14:25:11
xgui
已发帖子: 224
# miraclecast needs systemd and a glibc toolchain w/ threads and wchar
# BR2_PACKAGE_MJPEGTOOLS is not set
# BR2_PACKAGE_MODPLUGTOOLS is not set
# BR2_PACKAGE_MOTION is not set
# BR2_PACKAGE_MPD is not set
# BR2_PACKAGE_MPD_MPC is not set
# BR2_PACKAGE_MPG123 is not set
# BR2_PACKAGE_MPV is not set
# BR2_PACKAGE_MULTICAT is not set
# BR2_PACKAGE_MUSEPACK is not set
# BR2_PACKAGE_NCMPC is not set
# BR2_PACKAGE_OPUS_TOOLS is not set
BR2_PACKAGE_PULSEAUDIO_HAS_ATOMIC=y
# BR2_PACKAGE_PULSEAUDIO is not set
# BR2_PACKAGE_SOX is not set
# BR2_PACKAGE_SQUEEZELITE is not set
# BR2_PACKAGE_TSTOOLS is not set
# BR2_PACKAGE_TWOLAME is not set
# BR2_PACKAGE_UDPXY is not set
# BR2_PACKAGE_UPMPDCLI is not set
# BR2_PACKAGE_V4L2GRAB is not set
果然有 BR2_PACKAGE_MPV , 但是我还没有玩过这个.
楼主 #6 2019-11-04 14:47:21
wupaul2001
已发帖子: 307
@checkout 谢谢了
#7 2019-11-04 15:37:42
Jmhh247
已发帖子: 262
或者,换回2017版
楼主 #8 2019-11-04 16:42:11
wupaul2001
已发帖子: 307
换回2017, 不是QT5.12.4, 低版本QT不支持Mqtt, 一连串的不支持
#9 2022-04-27 22:05:01
begin
已发帖子: 32
换回2017可行吗,比如什么兼容性的之类,小白问题0.0
#10 2022-04-27 22:08:55
已发帖子: 3,403
也可以。还有一个好办法,把2017版本里面mplayer的package移到新版本,也不是不可以。
#11 2022-04-28 20:40:21
begin
已发帖子: 32
好的感谢晕哥
#12 2022-04-29 08:28:23
baidxi
自己搬一个进去
#13 2022-05-23 00:22:57
liefyuan
已发帖子: 70
晕哥,如建议我就从buildroot2017拷贝了一个mplayer文件夹进buildroot2020然后编译的时候报错了:
liefyuan@ubuntu:~/Liefyuan/cherry-pi/buildroot-2020.02.4$ sudo time make -j16Makefile.legacy:9: *** "You have legacy configuration in your .config! Please check your configuration.".  Stop.
Command exited with non-zero status 2
0.03user 0.01system 0:00.04elapsed 111%CPU (0avgtext+0avgdata 12280maxresident)k
0inputs+80outputs (0major+11530minor)pagefaults 0swaps
最近编辑记录 liefyuan (2022-05-23 00:24:18)
#14 2022-05-23 12:33:48
forever_rainy
已发帖子: 21
咱觉得其实也可以交叉编译过去,,,不一定非要使用buildroot,虽然手动交叉编译是很麻烦就是了
#15 2022-05-23 12:46:25
已发帖子: 3,403
@liefyuan
Config.in.legacy 移除 MPLAYER 试一试。
#16 2022-05-23 22:56:04
liefyuan
已发帖子: 70
buildroot-2020.02.4$ vim Config.in.legacy
(1814行) 如下都注释掉了
#config BR2_PACKAGE_MPLAYER
#       bool "mplayer package removed"
#       select BR2_LEGACY
#       help
#         The mplayer package was removed.
#config BR2_PACKAGE_MPLAYER_MPLAYER
#       select BR2_LEGACY
#       help
#config BR2_PACKAGE_MPLAYER_MENCODER
#       select BR2_LEGACY
#       help
#config BR2_PACKAGE_LIBPLAYER_MPLAYER
#       bool "mplayer support in libplayer removed"
#       select BR2_LEGACY
#       help
不过编译的时候还是不行啊!
[sudo] password for liefyuan:
0.04user 0.00system 0:00.04elapsed 112%CPU (0avgtext+0avgdata 12580maxresident)k
0inputs+80outputs (0major+11500minor)pagefaults 0swaps
#17 2022-05-23 23:05:31
已发帖子: 3,403
make menuconfig
save
#18 2022-05-23 23:23:56
liefyuan
已发帖子: 70
哇酷小二 wrote:
make menuconfig
save
可以啦!谢谢啦!
#19 2022-05-23 23:31:12
f_Endman
已发帖子: 59
mpv播放器是mplayer官方的下一代播放器,新版buildroot改成这个了,功能一样
#20 2022-05-27 13:12:36
forever_rainy
已发帖子: 21
wupaul2001 wrote:
如题
确实如 楼上所说,下载了最新的buildroot2022看了,mpv 是 mplayer2,使用新版本可以使用在这个,使用旧版本的话(buildroot2017),因为我一直是下载的qt的源码手动交叉编译的,试过5.9.3 , 5.12.7, 都可以使用。
