楼主 #1 2020-06-15 16:54:17
起个名字好难
insmod r8723bs.ko 之后 ifconfig wlan0 up 出现 SIOCSIFFLAGS 错误,请问这是为什么?
# insmod r8723bs.ko
[  868.369355] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[  868.391839] RTL8723BS: module init start
[  868.395807] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[  868.403026] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[  868.425505] pnetdev = c1e16000
[  870.760887] RTL8723BS: rtw_ndev_init(wlan0)
[  870.819860] RTL8723BS: module init ret =0
# ifconfig wlan0 up
ifconfig: SIOCSIFFLAGS: Operation not permitted
#3 2025-04-27 15:35:36
帝国炮灰
已发帖子: 23
Re: insmod r8723bs.ko 之后 ifconfig wlan0 up 出现 SIOCSIFFLAGS 错误,请问这是为什么?
@起个名字好难
请问楼主解决了吗?
#4 2025-04-27 15:46:48
memory
已发帖子: 712
帝国炮灰 wrote:
@起个名字好难
请问楼主解决了吗?
没有加载驱动吧
#5 2025-04-27 16:27:26
zzm24
已发帖子: 127
rtl8723bs已经很旧了,而且一直在staging目录躺着,这个问题是/fireware下没有8723的bin导致的,8723蓝牙和wifi都需要加载bin
#6 2025-04-28 00:13:30
帝国炮灰
已发帖子: 23
可是我的固件也在,
smc 1 p1 err, cmd 53, WR RTO !!
[ 2012.058703] sunxi-mmc 4021000.sdmmc: retry:start
[ 2012.063853] sunxi-mmc 4021000.sdmmc: retry:stop
[ 2012.068944] sunxi-mmc 4021000.sdmmc: retry:stop recover
[ 2012.074781] sunxi-mmc 4021000.sdmmc: send manual stop command failed 100
[ 2012.082379] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[ 2012.088610] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710330
[ 2012.094922] sunxi-mmc 4021000.sdmmc: REG_NTDL_HS400: 0x20000010
[ 2012.101538] sunxi-mmc 4021000.sdmmc: retry:re-send cmd
[ 2012.108255] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 2012.115369] sunxi-mmc 4021000.sdmmc: retry:start
[ 2012.120525] sunxi-mmc 4021000.sdmmc: retry:stop
[ 2012.125604] sunxi-mmc 4021000.sdmmc: retry:stop recover
[ 2012.131440] sunxi-mmc 4021000.sdmmc: send manual stop command failed 100
[ 2012.139056] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[ 2012.145281] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710330
[ 2012.151594] sunxi-mmc 4021000.sdmmc: REG_NTDL_HS400: 0x20000010
[ 2012.158223] sunxi-mmc 4021000.sdmmc: retry:re-send cmd
[ 2012.164932] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 2012.172048] sunxi-mmc 4021000.sdmmc: retry:start
[ 2012.177205] sunxi-mmc 4021000.sdmmc: retry:stop
[ 2012.182274] sunxi-mmc 4021000.sdmmc: retry:stop recover
[ 2012.188127] sunxi-mmc 4021000.sdmmc: send manual stop command failed 100
[ 2012.195722] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[ 2012.201937] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710330
[ 2012.208265] sunxi-mmc 4021000.sdmmc: REG_NTDL_HS400: 0x20000010
[ 2012.214868] sunxi-mmc 4021000.sdmmc: sunxi v5p3x retry give up
[ 2012.221393] sunxi-mmc 4021000.sdmmc: retry:set phase failed or over retry times
[ 2012.229557] sunxi-mmc 4021000.sdmmc: retry:give up
[ 2012.234967] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
