楼主 #1 2020-11-08 22:36:24
小果果
已发帖子: 61
buildroot制作的文件系统netstat用不了
路过的大佬帮忙看看是什么问题,日志如下
Freeing unused kernel memory: 128K
devpts: called with bogus options
Starting logging: OK
Welcome to Buildroot
buildroot login: root
netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
netstat: /proc/net/tcp6: No such file or directory
netstat: /proc/net/udp6: No such file or directory
netstat: /proc/net/raw6: No such file or directory
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 3 [ ] DGRAM 1401 /dev/log
unix 2 [ ] DGRAM 1405
楼主 #2 2020-11-08 23:17:50
小果果
已发帖子: 61
Re: buildroot制作的文件系统netstat用不了
kernel里面选上ipv6就好了
