IPL_CUST g5da0ceb
runUBOOT()
runUBOOT()
[SPINAND]
SPI 54M
Load UBOOT from SPINAND
-Verify UBOOT CRC32 passed!
-Decompress UBOOT XZ
decomp_size=0x000a12a4
Disable MMU and D-cache before jump to UBOOT▒
U-Boot 2015.01 (Mar 24 2021 - 16:10:59)
Version: I2g#######
Watchdog enabled
I2C: ready
DRAM:
WARNING: Caches not enabled
SPINAND: _MDrv_SPINAND_GET_INFO: Found SPINAND INFO
(0xCD) (0xEA) (0x11)
SPINAND: board_nand_init: CIS contains part info
128 MiB
MMC: MStar SD/MMC: 0
In: serial
Out: serial
Err: serial
Net: MAC Address 00:30:1B:BA:02:DB
Auto-Negotiation...
Link Status Speed:10 Full-duplex:0
Status Error!
sstar_emac
bootcheck start
fore uup u8KeyPad_KeyVal [0x7]
BootMode 0
NAND read: device 0 offset 0x4c0000, size 0x60000
Time:43995 us, speed:8937 KB/s
393216 bytes read: OK
gpio debug MHal_GPIO_Pad_Set: pin=8
gpio[8] is 0
NAND read: device 0 offset 0x520000, size 0x500000
Time:569940 us, speed:9199 KB/s
5242880 bytes read: OK
gpio[8] is 1
## Booting kernel from Legacy Image at 22000000 ...
Image Name: MVX4##I2M#g#######KL_LX409##[BR:
Image Type: ARM Linux Kernel Image (lzma compressed)
Data Size: 2437304 Bytes = 2.3 MiB
Load Address: 20008000
Entry Point: 20008000
Verifying Checksum ... OK
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
Uncompressing Kernel Image ...
[XZ] !!!reserved 0x21000000 length=0x 1000000 for xz!!
XZ: uncompressed size=0x4da000, ret=7
OK
atags:0x20000000
Booting Linux on physical CPU 0x0
Linux version 4.9.84 (som201@som201-virtual-machine) (gcc version 8.2.1 20180802 (GNU Toolchain for the A-profile Architecture 8.2-2018-08 (arm-rel-8.23)) ) #60 SMP PREEMPT Wed Mar 24 16:11:05 CST 2021
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
CPU: div instructions available: patching division code
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
early_atags_to_fdt() success
OF: fdt:Machine model: INFINITY2M SSC011A-S01A-S
LXmem is 0x7f00000 PHYS_OFFSET is 0x20000000
Add mem start 0x20000000 size 0x7f00000!!!!
LX_MEM = 0x20000000, 0x7f00000
LX_MEM2 = 0x0, 0x0
LX_MEM3 = 0x0, 0x0
EMAC_LEN= 0x0
DRAM_LEN= 0x0
deal_with_reserved_mmap memblock_reserve success mmap_reserved_config[0].reserved_start=
0x27c00000
deal_with_reserve_mma_heap memblock_reserve success mma_config[0].reserved_start=
0x25c00000
cma: Reserved 2 MiB at 0x25a00000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @c58bc000 s25112 r8192 d24040 u57344
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 24066
Kernel command line: console=ttyS0,115200 ubi.mtd=UBI,2048 root=ubi:rootfs rw rootfstype=ubifs init=/linuxrc rootwait=1 LX_MEM=0x7f00000 mma_heap=mma_heap_name0,miu=0,sz=0x2000000 mma_memblock_remove=1 highres=off mmap_reserved=fb,miu=0,sz=0x300000,max_start_off=0x7C00000,max_end_off=0x7F00000 mtdparts=nand0:384k@1280k(IPL0),384k(IPL1),384k(IPL_CUST0),384k(IPL_CUST1),768k(UBOOT0),768k(UBOOT1),384k(ENV0),0x20000(KEY_CUST),0x60000(LOGO),0x500000(KERNEL),0x500000(RECOVERY),-(UBI)
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 85876K/97280K available (2894K kernel code, 249K rwdata, 1488K rodata, 172K init, 171K bss, 9356K reserved, 2048K cma-reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xc8000000 - 0xff800000 ( 888 MB)
lowmem : 0xc0000000 - 0xc7f00000 ( 127 MB)
modules : 0xbf800000 - 0xc0000000 ( 8 MB)
.text : 0xc0008000 - 0xc02dba90 (2895 kB)
.init : 0xc0477000 - 0xc04a2000 ( 172 kB)
.data : 0xc04a2000 - 0xc04e05e8 ( 250 kB)
.bss : 0xc04e2000 - 0xc050cc98 ( 172 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
ms_init_main_intc: np->name=ms_main_intc, parent=gic
ms_init_pm_intc: np->name=ms_pm_intc, parent=ms_main_intc
ss_init_gpi_intc: np->name=ms_gpi_intc, parent=ms_main_intc
Find CLK_cpupll_clk, hook ms_cpuclk_ops
arm_arch_timer: Architected cp15 timer(s) running at 6.00MHz (virt).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1623fa770, max_idle_ns: 440795202238 ns
sched_clock: 56 bits at 6MHz, resolution 166ns, wraps every 4398046511055ns
Switching to timer-based delay loop, resolution 166ns
Console: colour dummy device 80x30
console [ttyS0] enabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 12.00 BogoMIPS (lpj=60000)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
CPU0: update cpu_capacity 1024
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x20008240 - 0x20008270
CPU1: update cpu_capacity 1024
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (24.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 16 (order: -2, 1024 bytes)
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Version : MVX4##I2M#g#######KL_LX409##[BR:g]#XVM
GPIO: probe end[ss_gpi_intc_domain_alloc] hw:42 -> v:43
[MS_PM_INTC] hw:20 -> v:51
[Padmux]reset Pad_87(reg 0x101e09; mask0x7) to DMIC_MODE_2(org: I2C0_MODE_1)
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux video capture interface: v2.00
clocksource: Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 128 (order: 0, 6144 bytes)
UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
workingset: timestamp_bits=30 max_order=15 bucket_order=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered (default)
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-bz0
[Padmux]reset Pad_47(reg 0x101e03; mask0x70) to GPIO(org: UART0_MODE_1)
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-usb-en
sd_pwr init ok
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-rs485-ctrl
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-y1
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-y2
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-zero
cust-io-ctrl soc:ido_io_ctrl: Device tree not define of gpio-wifi-reset
cust_io_ctrl complete!
libphy: Fixed MDIO Bus: probed
CAN device driver interface
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
mousedev: PS/2 mouse device common for all mice
[ss_gpi_intc_domain_alloc] hw:58 -> v:58
i2c /dev entries driver
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
1f221000.uart0: ttyS0 at MMIO 0x0 (irq = 30, base_baud = 10800000) is a unknown
1f221200.uart1: ttyS1 at MMIO 0x0 (irq = 31, base_baud = 10800000) is a unknown
1f220400.uart2: ttyS2 at MMIO 0x0 (irq = 32, base_baud = 10800000) is a unknown
1f221400.uart2: ttyS3 at MMIO 0x0 (irq = 33, base_baud = 10800000) is a unknown
[Core Voltage] check_voltage_valid: Not support 0mV, use 900mV
>> [sdmmc] ms_sdmmc_probe
[Padmux]reset Pad_51(reg 0x101e08; mask0x300) to GPIO(org: SDIO_MODE_1)
>> [sdmmc_0] Probe Platform Devices
MSYS: DMEM request: [emac0_buff]:0x00000812
MSYS: DMEM request: [emac0_buff]:0x00000812 success, CPU phy:@0x25A43000, virt:@0xC5A43000
libphy: mdio: probed
mdio_bus mdio-bus@emac0: /soc/emac0/mdio-bus@emac0/ethernet-phy@0 has invalid PHY address
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 0
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 1
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 2
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 3
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 4
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 5
Goodix-TS 1-005d: ID 911, version: 1060
Goodix-TS 1-005d: Direct firmware load for goodix_911_cfg.bin failed with error -2
input: Goodix Capacitive TouchScreen as /devices/soc0/soc/1f223200.i2c1/i2c-1/1-005d/input/input0
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 6
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 7
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 8
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 9
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 10
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 11
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 12
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 13
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 14
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 15
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 16
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 17
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 18
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 19
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 20
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 21
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 22
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 23
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 24
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 25
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 26
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 27
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 28
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 29
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 30
mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 31
[emac_phy_connect][3204] connected mac emac0 to PHY at mdio-bus@emac0:00 [uid=11112222, driver=SStar 10/100 Ethernet Phy]
MSYS: DMEM request: [emac1_buff]:0x00060812
MSYS: DMEM request: [emac1_buff]:0x00060812 success, CPU phy:@0x25A50000, virt:@0xC5A50000
mdio_bus mdio-bus@emac1: /soc/emac1/mdio-bus@emac1/ethernet-phy@1 has invalid PHY address
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 0
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 1
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 2
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 3
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 4
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 5
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 6
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 7
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 8
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 9
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 10
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 11
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 12
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 13
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 14
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 15
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 16
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 17
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 18
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 19
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 20
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 21
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 22
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 23
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 24
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 25
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 26
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 27
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 28
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 29
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 30
mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 31
[emac_phy_connect][3204] connected mac emac1 to PHY at mdio-bus@emac1:00 [uid=00000000, driver=Generic PHY]
ms_rtcpwc 1f006800.rtcpwc: rtc core: registered 1f006800.rtcpwc as rtc0
[ms_cpufreq_init] Current clk=1005326304
mstar_spinand_probe: mstar_spinand enableClock
MSYS: DMEM request: [BDMA]:0x00000840
MSYS: DMEM request: [BDMA]:0x00000840 success, CPU phy:@0x25A44000, virt:@0xC5A44000
MDrv_SPINAND_Init: Detected ID: MID =cd, DID =ea
_dumpNandInformation:warning, Bytes / Page : 2048
_dumpNandInformation:warning, Pages / Block: 64
_dumpNandInformation:warning, Sector/ Page : 512
_dumpNandInformation:warning, Spare / Page : 64
_dumpNandInformation:warning, Current config r:4 w:4 drv:1
mstar_spinand_probe: Magic memcmp pass
mstar_spinand_probe: Get partition (Block 0 : page 1)
mstar_spinand_probe: CIS contains part info
mstar_spinand_probe: Before nand_scan()...
12 cmdlinepart partitions found on MTD device nand0
mstar_spinand_probe: Mtd parts parse
Creating 12 MTD partitions on "nand0":
0x000000140000-0x0000001a0000 : "IPL0"
0x0000001a0000-0x000000200000 : "IPL1"
0x000000200000-0x000000260000 : "IPL_CUST0"
0x000000260000-0x0000002c0000 : "IPL_CUST1"
0x0000002c0000-0x000000380000 : "UBOOT0"
0x000000380000-0x000000440000 : "UBOOT1"
0x000000440000-0x0000004a0000 : "ENV0"
0x0000004a0000-0x0000004c0000 : "KEY_CUST"
0x0000004c0000-0x000000520000 : "LOGO"
0x000000520000-0x000000a20000 : "KERNEL"
0x000000a20000-0x000000f20000 : "RECOVERY"
0x000000f20000-0x000008000000 : "UBI"
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
ThumbEE CPU extension supported.
Registering SWP/SWPB emulation handler
ubi0: attaching mtd11
ubi0: scanning is finished
ubi0: attached mtd11 (name "UBI", size 112 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 897, bad PEBs: 6, corrupted PEBs: 0
ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
ubi0: available PEBs: 712, total reserved PEBs: 185, PEBs reserved for bad PEB handling: 14
ubi0: background thread "ubi_bgt0d" started, PID 684
ms_rtcpwc 1f006800.rtcpwc: setting system clock to 2021-03-26 16:39:10 UTC (1616776750)
OF: fdt:not creating '/sys/firmware/fdt': CRC check failed
VFS: Cannot open root device "ubi:rootfs" or unknown-block(0,0): error -19
Please append a correct "root=" boot option; here are the available partitions:
1f00 384 mtdblock0 (driver?)
1f01 384 mtdblock1 (driver?)
1f02 384 mtdblock2 (driver?)
1f03 384 mtdblock3 (driver?)
1f04 768 mtdblock4 (driver?)
1f05 768 mtdblock5 (driver?)
1f06 384 mtdblock6 (driver?)
1f07 128 mtdblock7 (driver?)
1f08 384 mtdblock8 (driver?)
1f09 5120 mtdblock9 (driver?)
1f0a 5120 mtdblock10 (driver?)
1f0b 115584 mtdblock11 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
CPU0: stopping
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.84 #60
Hardware name: SStar Soc (Flattened Device Tree)
[<c00120f9>] (unwind_backtrace) from [<c000feeb>] (show_stack+0xb/0xc)
[<c000feeb>] (show_stack) from [<c0127b23>] (dump_stack+0x57/0x70)
[<c0127b23>] (dump_stack) from [<c00116e1>] (handle_IPI+0x8d/0x104)
[<c00116e1>] (handle_IPI) from [<c00092d9>] (gic_handle_irq+0x59/0x64)
[<c00092d9>] (gic_handle_irq) from [<c00105a5>] (__irq_svc+0x65/0xac)
Exception stack(0xc04a3f60 to 0xc04a3fa8)
3f60: 00000000 0000075e c58be354 c0017961 c04a5bf4 00000001 ffffe000 c04e0153
3f80: c04a5c44 c04908cc 00000000 00000000 0021f982 c04a3fb0 c000ddb7 c000ddae
3fa0: 40000133 ffffffff
[<c00105a5>] (__irq_svc) from [<c000ddae>] (arch_cpu_idle+0xc/0x1e)
[<c000ddae>] (arch_cpu_idle) from [<c003e04b>] (cpu_startup_entry+0xa3/0xd8)
[<c003e04b>] (cpu_startup_entry) from [<c04778e5>] (start_kernel+0x239/0x294)
[<c04778e5>] (start_kernel) from [<2000807f>] (0x2000807f)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)自己做SSD201内核和文件系统的时候,打包了一个USB升级固件的bin文件,不过一直进不去系统,上面是启动内容,好像是文件系统的问题。
自己是按照开发手册来的,有没有大佬知道问题。
看一下bootargs里的rootfs设置的分区对不对,再或者是kernel里有没有打开SPI NAND 的UBI文件系统支持
Please append a correct "root=" boot option; here are the available partitions:看一下bootargs里的rootfs设置的分区对不对,再或者是kernel里有没有打开SPI NAND 的UBI文件系统支持
这样算内核使能了吧
已经生成分区了,应该是文件系统制作或者烧录有问题
本站右上角搜一下 ubi 或 ubifs
@liuxingkeji
楼主解决该问题了吗?
重新刷uboot
我也遇到这个问题, 楼主有解决吗?
