[ 1.038070] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.055979] NET: Registered protocol family 17
[ 1.060535] Key type dns_resolver registered
[ 1.065072] Registering SWP/SWPB emulation handler
[ 1.070430] mmc0: new high speed SD card at address 0001
[ 1.085725] mmcblk0: mmc0:0001 MS 1.83 GiB
[ 1.095358] mmcblk0: p1 p2
[ 2.804745] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 3.554728] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 4.304727] sunxi-mmc 1c10000.mmc: fatal err update clk timeoutWelcome to Buildroot
buildroot login: [ 6.144748] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 6.626982] musb_g_ep0_irq 712: SetupEnd came in a wrong ep0stage idle
[ 7.924742] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 8.674729] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 9.424742] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 11.264747] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 13.034745] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 13.784728] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 14.534743] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 17.404745] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 18.154729] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 18.904745] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 21.724747] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 22.474729] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
这样一直显示下去
请问大神们同样的TF卡软件, 在荔枝派zero开发板用得好好的,在我自己的V3s板子上就提示mmc错误?
这个问题, 你看提示 1c10000, 然后打开全志Allwinner V3s的手册 跟进去会有发现的。
感谢提醒, 我看了这个1c10000是地址, 而且是SD/EMMC1的地址, 而我刚好第二个TF卡挪作他用。
估计是这个问题了。
這个最后怎么解决呢
这个在ESP8089使用中也出现过 配置好网络连接上后 驱动会随机的崩溃 然后出现上面那种提示 短的时间几分钟 长的几小时 这个怎么处理呢
[ 333.847745] wlan0: deauthenticating from c8:3a:35:2a:72:a1 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 333.956612] mmc1: card 0001 removed
[ 334.050921] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 334.067805] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 334.076720] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 334.083982] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 334.090119] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 334.095668] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 334.101594] mmc1: new high speed SDIO card at address 0001
[ 334.843195] sip_write_memory send buffer failed
[ 334.847793] esp_download_fw Failed to write fw, err: -16
[ 334.853106] download firmware failed
[ 334.856712] esp_init_all failed: -16
[ 334.860281] first error exit
[ 352.235729] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 352.985745] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 354.785744] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 356.565745] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 357.315730] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 358.065743] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 359.905744] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 361.685743] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 362.435729] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 363.185744] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 365.025743] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 366.805742] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 367.555730] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 463.060374] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 463.072949] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 463.081885] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 463.089244] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 463.094782] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 463.100814] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 463.106444] mmc1: new high speed SDIO card at address 0001
[ 463.112451] Unable to handle kernel paging request at virtual address c0561654
[ 463.119672] pgd = c3bf0000
[ 463.122376] [c0561654] *pgd=4041940e(bad)
[ 463.126391] Internal error: Oops: 80d [#1] SMP ARM
[ 463.131174] Modules linked in: esp8089
[ 463.134928] CPU: 0 PID: 59 Comm: kworker/0:2 Not tainted 4.10.15-mangopi #4
[ 463.141877] Hardware name: Allwinner sun8i Family
[ 463.146591] Workqueue: events_freezable mmc_rescan
[ 463.151376] task: c3a4c000 task.stack: c3ba8000
[ 463.155933] PC is at esp_sdio_probe+0x58/0x3f0 [esp8089]
[ 463.161241] LR is at sdio_bus_probe+0x100/0x118
[ 463.165767] pc : [<bf000c40>] lr : [<c04e9fa4>] psr: a00b0013
[ 463.165767] sp : c3ba9de8 ip : 00000000 fp : 00000344
[ 463.177226] r10: bf007d10 r9 : c3b98800 r8 : bf00a480
[ 463.182443] r7 : bf009b14 r6 : c3223200 r5 : c0561640 r4 : c32fc700
[ 463.188960] r3 : c3223208 r2 : ebffff28 r1 : 00000003 r0 : c3223200
[ 463.195479] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 463.202602] Control: 10c5387d Table: 43bf006a DAC: 00000051
[ 463.208338] Process kworker/0:2 (pid: 59, stack limit = 0xc3ba8210)
[ 463.214595] Stack: (0xc3ba9de8 to 0xc3baa000)
[ 463.218950] 9de0: 600b0013 bf007d10 0000000c c3223208 c3223200 00000000
[ 463.227117] 9e00: bf009b28 bf007d10 0000000c 00000000 00000344 c04e9fa4 c3223208 c0a6f9c0
[ 463.235285] 9e20: 00000000 00000000 bf009b28 c040b398 00000000 00000000 c3ba9e68 c040b51c
[ 463.243452] 9e40: 00000001 c0a6f99c 00000000 c0409848 c3916d6c c32b56b8 c3223208 c3223208
[ 463.251619] 9e60: c322323c c040b07c c3223208 00000001 00000000 c3223210 c3223208 c0a2b698
[ 463.259787] 9e80: c31e9808 c040a704 c3223210 c3223208 00000000 c0408b90 c3b98800 c04e09b0
[ 463.267954] 9ea0: c3223200 c3223208 c3223200 c3223208 c3b98800 c31e9804 c31e9800 00000001
[ 463.276121] 9ec0: c31e9800 c04ea210 c31e9800 00000001 00000001 c04e9658 00000000 c3ba9eeb
[ 463.284289] 9ee0: 000001aa 00000000 00000000 10ffff00 00000000 c3b98a54 00061a80 c3b98800
[ 463.292456] 9f00: c0750210 c075021c 00000000 c3ee6200 c3ee6200 c04e15c8 c3ba4600 c3b98a54
[ 463.300624] 9f20: c3ee6200 c3ee9500 00000000 c0130a5c c0a02d00 c3ba4618 c3ba4600 c3ee6218
[ 463.308791] 9f40: c3ba8000 c0a02d00 c3ba4618 00000008 c3ee6200 c0130cc4 c3bab35c c0a0e46e
[ 463.316958] 9f60: 00000000 c0a02d00 c3bab35c c3bab340 00000000 c3b8fdc0 c3bab35c c3ba4600
[ 463.325126] 9f80: c0130c70 c3841ee0 00000000 c01361ac c3b8fdc0 c0136084 00000000 00000000
[ 463.333292] 9fa0: 00000000 00000000 00000000 c0107378 00000000 00000000 00000000 00000000
[ 463.341459] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 463.349625] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 463.357818] [<bf000c40>] (esp_sdio_probe [esp8089]) from [<c04e9fa4>] (sdio_bus_probe+0x100/0x118)
[ 463.366780] [<c04e9fa4>] (sdio_bus_probe) from [<c040b398>] (driver_probe_device+0x240/0x2e0)
[ 463.375290] [<c040b398>] (driver_probe_device) from [<c0409848>] (bus_for_each_drv+0x58/0x8c)
[ 463.383806] [<c0409848>] (bus_for_each_drv) from [<c040b07c>] (__device_attach+0xb0/0x110)
[ 463.392060] [<c040b07c>] (__device_attach) from [<c040a704>] (bus_probe_device+0x84/0x8c)
[ 463.400232] [<c040a704>] (bus_probe_device) from [<c0408b90>] (device_add+0x3e4/0x564)
[ 463.408142] [<c0408b90>] (device_add) from [<c04ea210>] (sdio_add_func+0x5c/0x70)
[ 463.415620] [<c04ea210>] (sdio_add_func) from [<c04e9658>] (mmc_attach_sdio+0x268/0x358)
[ 463.423703] [<c04e9658>] (mmc_attach_sdio) from [<c04e15c8>] (mmc_rescan+0x2bc/0x37c)
[ 463.431531] [<c04e15c8>] (mmc_rescan) from [<c0130a5c>] (process_one_work+0x138/0x34c)
[ 463.439444] [<c0130a5c>] (process_one_work) from [<c0130cc4>] (worker_thread+0x54/0x524)
[ 463.447529] [<c0130cc4>] (worker_thread) from [<c01361ac>] (kthread+0x128/0x158)
[ 463.454920] [<c01361ac>] (kthread) from [<c0107378>] (ret_from_fork+0x14/0x3c)
[ 463.462137] Code: e5882000 e3a01003 e2863008 e5952004 (e5851014)
[ 463.468224] ---[ end trace 1b8bb0041ad52003 ]---离线
估计是 mmc1 与的 GPIO 功能复用冲突了,
PG2 被我用作 GPIO了, 结果 装上 r8723bs 不停报 sunxi-mmc 1c10000.mmc: fatal err update clk timeout
把 PG2 的GPIO 功能关掉就消停了.
刚刚把设备树里面的 PGx 全部屏蔽, 仍然是上面的错误, 我估计是这组口的上拉或者下拉引起了.
算了, 不折腾了, 反正这个产品不用这组口做 SDIO
我也遇到这种情况了
怎么屏蔽PGx呢?在源码或者menuconfig的哪个位置?
我的第二个TF卡槽上什么都没有,荔枝zero的板子
U-Boot SPL 2017.01-rc2-g32ab180-dirty (Dec 27 2019 - 15:12:57)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-g32ab180-dirty (Dec 27 2019 - 15:12:57 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
reading zImage
3925752 bytes read in 211 ms (17.7 MiB/s)
11856 bytes read in 27 ms (428.7 KiB/s)
Loading Device Tree to 42dfa000, end 42dffe4f ... OK
[ 0.000000] Linux version 4.13.16-licheepi-zero+ (mjc@mjc-VirtualBox) (gcc version 9.2.1 20191008 (Ubuntu 9.2.1-9ubuntu2)) #1 SMP Fri Dec 27 15:48:03 CST 2019
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu @c3f5f000 s33868 r8192 d23476 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Memory: 55096K/65536K available (6144K kernel code, 217K rwdata, 1436K rodata, 1024K init, 261K bss, 10440K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a366c0 ( 218 kB)
[ 0.000000] .bss : 0xc0a3d79c - 0xc0a7ec9c ( 262 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000177] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000401] Console: colour dummy device 80x30
[ 0.000436] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000452] pid_max: default: 32768 minimum: 301
[ 0.000579] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000594] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001176] CPU: Testing write buffer coherency: ok
[ 0.001534] /cpus/cpu@0 missing clock-frequency property
[ 0.001558] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001986] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002159] Hierarchical SRCU implementation.
[ 0.002637] smp: Bringing up secondary CPUs ...
[ 0.002652] smp: Brought up 1 node, 1 CPU
[ 0.002661] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002668] CPU: All CPU(s) started in SVC mode.
[ 0.003430] devtmpfs: initialized
[ 0.006467] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006754] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006779] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.006934] pinctrl core: initialized pinctrl subsystem
[ 0.007779] random: get_random_u32 called from bucket_table_alloc+0xfc/0x228 with crng_init=0
[ 0.007908] NET: Registered protocol family 16
[ 0.008342] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009402] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009420] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.022493] SCSI subsystem initialized
[ 0.022790] usbcore: registered new interface driver usbfs
[ 0.022857] usbcore: registered new interface driver hub
[ 0.022950] usbcore: registered new device driver usb
[ 0.023213] pps_core: LinuxPPS API ver. 1 registered
[ 0.023223] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.023243] PTP clock support registered
[ 0.023450] Advanced Linux Sound Architecture Driver Initialized.
[ 0.025237] clocksource: Switched to clocksource arch_sys_counter
[ 0.035535] NET: Registered protocol family 2
[ 0.036113] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.036145] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.036168] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.036295] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.036342] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.036550] NET: Registered protocol family 1
[ 0.037120] RPC: Registered named UNIX socket transport module.
[ 0.037140] RPC: Registered udp transport module.
[ 0.037145] RPC: Registered tcp transport module.
[ 0.037151] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.039176] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.048079] NFS: Registering the id_resolver key type
[ 0.048129] Key type id_resolver registered
[ 0.048137] Key type id_legacy registered
[ 0.049142] random: fast init done
[ 0.052009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.052030] io scheduler noop registered
[ 0.052037] io scheduler deadline registered
[ 0.052288] io scheduler cfq registered (default)
[ 0.052300] io scheduler mq-deadline registered
[ 0.052306] io scheduler kyber registered
[ 0.056696] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.125066] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.128503] console [ttyS0] disabled
[ 0.148768] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.728067] console [ttyS0] enabled
[ 0.734807] libphy: Fixed MDIO Bus: probed
[ 0.739471] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.745341] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.751045] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.757252] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.762915] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.770168] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.775838] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.783051] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.788024] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.794976] libphy: stmmac: probed
[ 0.800216] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.806874] ehci-platform: EHCI generic platform driver
[ 0.812374] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.818053] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.825997] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.855254] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.862385] hub 1-0:1.0: USB hub found
[ 0.866353] hub 1-0:1.0: 1 port detected
[ 0.870832] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.877126] ohci-platform: OHCI generic platform driver
[ 0.882657] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.889380] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.897334] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.970309] hub 2-0:1.0: USB hub found
[ 0.974127] hub 2-0:1.0: 1 port detected
[ 0.981643] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.991211] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.000161] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.007069] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.011607] i2c /dev entries driver
[ 1.016574] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.026065] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.095291] sunxi-mmc 1c0f000.mmc: base:0xc4981000 irq:23
[ 1.146279] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.155270] sunxi-mmc 1c10000.mmc: base:0xc4985000 irq:24
[ 1.161773] usbcore: registered new interface driver usbhid
[ 1.167429] usbhid: USB HID core driver
[ 1.171979] mmc0: new high speed SD card at address e624
[ 1.178081] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[ 1.184535] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.192578] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.200121] mmcblk0: p1 p2
[ 1.207160] NET: Registered protocol family 17
[ 1.211728] Key type dns_resolver registered
[ 1.216245] Registering SWP/SWPB emulation handler
[ 1.226580] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.237959] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.243726] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.252840] hub 3-0:1.0: USB hub found
[ 1.256844] hub 3-0:1.0: 1 port detected
[ 1.261966] using random self ethernet address
[ 1.266521] using random host ethernet address
[ 1.271991] usb0: HOST MAC d2:7e:b3:06:f9:62
[ 1.276410] usb0: MAC 46:0a:9c:21:b1:5d
[ 1.280288] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.287798] g_cdc gadget: g_cdc ready
[ 1.293927] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.303592] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:04 UTC (4)
[ 1.311785] vcc5v0: disabling
[ 1.314760] ALSA device list:
[ 1.317779] #0: V3s Audio Codec
[ 1.329488] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 1.435607] EXT4-fs (mmcblk0p2): recovery complete
[ 1.442060] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.450279] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 1.464948] devtmpfs: mounted
[ 1.469422] Freeing unused kernel memory: 1024K
[ 1.610106] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting logging: OK
Starting network: OK
buildroot login: [ 3.075222] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 3.855227] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 4.635223] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 5.385209] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 6.135221] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 9.075228] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 9.855224] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 10.635225] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 11.385210] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 12.135222] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 13.955225] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 14.735222] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 15.515220] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 16.265218] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 17.015227] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 19.955223] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 20.735222] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 21.515219] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 22.265209] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 23.015223] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 25.955222] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 26.735222] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 27.515220] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 28.265210] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 29.015226] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 30.835227] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 31.615223] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 32.395220] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[ 33.145210] sunxi-mmc 1c10000.mmc: fatal err update clk timeout最近编辑记录 ma6254 (2019-12-27 20:42:28)
没有用到mmc1, 再设备树里面屏蔽mmc1 。是否能解决呢
@木子猫
老哥,这个问题后来怎么解决的?
