请问这是为何?
Nor 版本
U-Boot 2020.07 (May 21 2021 - 17:23:32 +0800) Allwinner Technology
DRAM: 64 MiB
In: serial
Out: serial
Err: serial
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Boot Device: spi
Boot Slot 0: empty
Boot Slot 1: spi-nor
SF: 524288 bytes @ 0x80000 Read: OK
Unknown command 'bmp' - try 'help'
gpio: pin 134 (gpio 134) value is 1
DFU waiting on SPI-NOR...
musb-hdrc: peripheral reset irq lost!
Booting from SPI-NOR...
device 0 offset 0x100000, size 0x500000
SF: 5242880 bytes @ 0x100000 Read: OK
## Loading kernel from FIT Image at 81000000 ...
Using 'conf@0' configuration
Trying 'kernel@0' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x810000cc
Data Size: 4309824 Bytes = 4.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x80000000
Entry Point: 0x80000000
Hash algo: crc32
Hash value: a764633f
Verifying Hash Integrity ... crc32+ OK
f0
Data Size: 15666 Bytes = 15.3 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 61472816
Booting using the fdt blob at 0x8141c4f0
Loading Kernel Image
Loading Device Tree to 817f9000, end 817ffd31 ... OK
VT instruction cache
[ 0.000000] OF: fdt: Machine model: Widora MangoPi R3
[ 0.000000] cma: Reserved 16 MiB at 0x82c00000
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 15883
[ 0.000000] Kernel command line: console=ttyS0,115200 rootwait init=/preinit root=/dev/mtdblock2 rootfstype=squashfs overlayfsdev=/dev/mtdblock3 net.ifnames=0 vt.global_cursor_default=0
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 37232K/64036K available (6144K kernel code, 248K rwdata, 1676K rodata, 1024K init, 225K bss, 10420K reserved, 16384K cma-reserved)
[ 0.000000] random: get_random_byt[ 0.000906] Console: colour dummy device 80x30
[ 0.001012] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070270] pid_max: default: 32768 minimum: 301
[ 0.070797] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.070849] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.072808] CPU: Testing write buffer coherency: ok
[ 0.074982] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076288] devtmpfs: initial
[ 0.095194] NET: Registered protocol family 16
[ 0.098987] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.101289] cpuidle: using governor menu
[ 0.142124] SCSI subsystem initialized
[ 0.142533] usbcore: registered new interface driver usbfs
[ 0.142707] usbcore: registered new interface driver hub
[ 0.142859] usbcore: registered new device driver usb
[ 0.143302] mc: Linux media interface: v0.10
[ 0.143433] videodev: Linux video capture interface: v2.00
[ 0.143555] pps_core: LinuxPPS API ver. 1 registered
[ 0.143574] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.143635] PTP clock support registered
[ 0.144711] ion_parse_dt_heap_common: id 4 typped to 0x(ptrval)
[ 0.150046] simple-framebuffer 83e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 0.176992] Console: switching to colour frame buffer device 100x30
[ 0.202236] simple-framebuffer 83e89000.framebuffer: fb0: simplefb registered!
[ 0.232814] thermal_sys: Registered thermal governor 'step_wise'
[ 0.233573] NET: Registered protocol family 2
[ 0.235152] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.235241] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.235303] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.235360] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.235680] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.235752] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.236323] NET: Registered protocol family 1
[ 0.239190] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.241009] Initialise system trusted keyrings
[ 0.241647] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.263822] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.264450] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.378371] Key type asymmetric registered
[ 0.378408] Asymmetric key parser 'x509' registered
[ 0.378579] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.378605] io scheduler mq-deadline registered
[ 0.378623] io scheduler kyber registered
[ 0.393850] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.417516] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.423834] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[ 0.425176] printk: console [ttyS0] disabled
[ 0.445509] 1c25400.serial: ttyS0 at MMIO 0x1c25400 (irq = 26, base_baud = 6250000) is a 16550A
[ 0.912957] printk: console [ttyS0] enabled
[ 0.949378] random: fast init done
[ 1.344718] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.351374] ehci-platform: EHCI generic platform driver
[ 1.363281] ohci-platform: OHCI generic platform driver
[ 1.369083] usbcore: registered new interface driver usb-storage
[ 1.376047] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.390008] i2c /dev entries driver
[ 1.394113] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 1.408031] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.419112] sun4i-csi 1cb0000.csi: Packed (RAW) format enabled.
[ 1.427021] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.437105] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.475511] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.485097] usbcore: registered new interface driver usbhid
[ 1.490804] usbhid: USB HID core driver
[ 1.514368] debugfs: Directory '1c23c00.codec' with parent 'F1C100s Audio Codec' already present!
[ 1.529660] sun4i-codec 1c23c00.codec: Codec <-> 1c23c00.codec mapping ok
[ 1.546345] NET: Registered protocol family 17
[ 1.551068] Key type dns_resolver registered
[ 1.556560] Loading compiled-in X.509 certificates
[ 1.599605] ALSA device list:
[ 1.602594] #0: F1C100s Audio Codec
[ 1.606843] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.615600] cfg80211: failed to load regulatory.db
[ 1.621704] Waiting for root device /dev/mtdblock2...
[ 25.888280] random: crng init done
[ 31.848202] vcc3v0: disabling
[ 31.851202] vcc3v3: disabling
[ 31.854169] vcc5v0: disabling离线
谢谢
我用卡启动也是一样的问题,是需要修改bootargs 吗>
我的bootargs,使用SD卡可以正常启动
bootargs = "console=ttyS0,115200 earlyprintk rootwait init=/preinit root=/dev/mmcblk0p3 rw rootfstype=ext4";唯有爱与科技不可辜负。
知乎专栏:IAMLIUBO的神奇物联网之旅
博客园:IAMLIUBO
Gayhub: IAMLIUBO
哇酷小二 wrote:
Mr.Liu wrote:
谢谢
devicetree.dts 没记错就是这个文件
谢谢!
