楼主 # 2021-11-03 22:43:52
ArduinoTM
关于F1C200s在U-boot中实现LCD-swap_r_b交换蓝色与红色的方法
最近在调试kmakise大佬画的黑猫F1C200s板时发现lcd的红色与绿色io口互换了,导致u-boot显示logo色彩出现错误
nono_swap
经过多番查证,发现了这么一个寄存器
7.2.5.7. TCON0_CTL_REG (Default Value: 0x00000000)
Offset: 0x040
Register Name: TCON0_CTL_REG
R/W Default/Hex Description
31 R/W 0 TCON0_En
0: disable
1: enable
Note: It executes at the beginning of the first blank line of TCON0 timing.
30:29 / / /
28 R/W 0 TCON0_Work_Mode
0: normal
1: dynamic freq
27:26 / / /
25:24 R/W 0 TCON0_IF
00: HV(Sync+DE)
01: 8080 I/F
1x:reserved
23 R/W 0 TCON0_RB_Swap
0: default
1: swap RED and BLUE data at FIFO1
22 / / 21 R/W 0 20 / 19:9 / 8:4
在u-boot中通过内存操作命令验证:
=> md 0x01c0c040
01c0c040: 80000100 f000000a 01df010f 02140030    ............0...
01c0c050: 0240000b 00280009 00000000 00000000    ..@...(.........
01c0c060: 00000000 00000000 00000000 00000000    ................
01c0c070: 00000000 00000000 00000000 00000000    ................
01c0c080: 00000000 00000000 13000000 00000000    ................
01c0c090: 00000000 00000000 00000000 00000000    ................
01c0c0a0: 00000000 00000000 00000000 00000000    ................
01c0c0b0: 00000000 00000000 00000000 00000000    ................
01c0c0c0: 00000000 00000000 00000000 00000000    ................
01c0c0d0: 00000000 00000000 00000000 00000000    ................
01c0c0e0: 00000000 00000000 00000000 00000000    ................
01c0c0f0: 00000000 ffffffff 00000000 30030000    ...............0
01c0c100: 30030000 30030000 30030000 30030000    ...0...0...0...0
01c0c110: 30030000 30030000 30030000 30030000    ...0...0...0...0
01c0c120: 30030000 30030000 30030000 30030000    ...0...0...0...0
01c0c130: 30030000 30030000 30030000 30030000    ...0...0...0...0
修改内存值80800100
=> mw.l 0x01c0c040 80800100
01c0c040: 80800100 f000000a 01df010f 02140030    ............0...
查找uboot源码,发现了lcd初始化部分的内存操作代码,按照格式写测试代码
swap_r_bcode
插电,开机电流轻松跑上去,问题解决
r_b_swap
#1 2021-11-03 22:51:21
已发帖子: 3,403
Re: 关于F1C200s在U-boot中实现LCD-swap_r_b交换蓝色与红色的方法
感谢楼主分享,就是配置这个TCON寄存器就可以了,能交换 R B 两组线。
#2 2021-11-04 13:21:01
HongSang
  • 不通过:其他
#3 2021-11-04 18:32:59
geekchun
已发帖子: 80
之前我也遇到过,感谢楼主分享
“插电,开机电流轻松跑上去,问题解决”
哈哈,看到这句似曾相识,楼主是不是看维修厮的视频了
楼主 #4 2021-11-05 07:55:52
ArduinoTM
geekchun wrote:
之前我也遇到过,感谢楼主分享
“插电,开机电流轻松跑上去,问题解决”
没错,老维修厮了,hhhhhhh
午安大电牛警告⚠️
#5 2021-12-22 15:18:32
CHSHIQING
已发帖子: 47
大佬NB,刚好自己画的一块板需要交换,感谢分享!
#6 2022-10-17 20:22:00
5761193jia
已发帖子: 30
uboot中修改好了,到进入linux后又复原了,咋整?linux中如何设置这个R B的交换?
#7 2023-02-27 17:42:22
pldjn_V3S
已发帖子: 110
@ArduinoTM
lcd初始化部分在哪个文件里面。
