楼主 # 2022-12-27 01:04:34
lq66work
V3S 用mplayer播放音频 导致CODEC异常死机
amixer -c 0 sset 'Headphone',0 100% unmute
amixer sset Headphone 31,31 (音量越大越快卡死)
mplayer /home/test.mp3
MPlayer interrupted by signal 11 in module: decode_audio
  • MPlayer crashed by bad usage of CPU/FPU/RAM.
    Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
    disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
  • MPlayer crashed. This shouldn't happen.
    It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
    gcc version. If you think it's MPlayer's fault, please read
    DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
    won't help unless you provide this information when reporting a possible bug.
如果不使用RTL8723,貌似就没这个问题,不知道大家是否遇到过
#1 2022-12-27 11:38:40
tianjjff
已发帖子: 129
Re: V3S 用mplayer播放音频 导致CODEC异常死机
是不是供电不足?
楼主 #2 2022-12-27 16:45:25
lq66work
tianjjff wrote:
是不是供电不足?
电源是5V1A的,发现使用WIFI会导致内存占用率较高,只剩余8M,不知道是不是这个原因
