ns2009触摸芯片太蛋疼了,出来的原始数据偶尔经常出现大偏差
戳东出西,TI的I2C触摸芯片TSC2007价格吓人,只好用新唐单片机N76E003模拟.
英文手册: DS_N76E003_EN_Rev0_04.pdf
中文手册: DS_N76E003_SC_Rev0_04.pdf
keil c51: c51v957.exe
破解补丁: KEIL_Lic.rar
开发板资料下载 QQ群附件: 623495321
开发板资料下载 链接: http://pan.baidu.com/s/1cCeT7g 密码:1n7f
开发板原理图: n76e003_sch.pdf
NU Link仿真器:
https://item.taobao.com/item.htm?id=562773467355
N76E003AT20开发板:
https://item.taobao.com/item.htm?id=562773539677
一开始我用荔枝派zero提供的 ns2009芯片和轮询驱动,出现触摸乱跳问题。
然后用TSC2007 + 中断驱动, 然而还是没x用。
我板子上叠了两个芯片的位置。
找到兼容芯片了, 封装一模一样,手册也基本是照抄的:
AK4183KT手册: AK4183KT.pdf
NS2009中文手册: ns2009_ds_chinese.pdf
ZT2083手册: ZT2083.pdf
&i2c0 {
status = "okay";tsc2007: tsc2007@48 {
compatible = "ti,tsc2007";
reg = <0x48>;
gpios = <&pio 6 0 GPIO_ACTIVE_LOW>;
ti,x-plate-ohms = <500>;
};rtc@51 {
compatible = "nxp,pcf8563";
reg = <0x51>;
tsc2007_core.c:
* drivers/input/touchscreen/tsc2007.c
* Copyright (c) 2008 MtekVision Co., Ltd.
* Kwangwoo Lee <kwlee@mtekvision.com>
* Using code from:
* - ads7846.c
* Copyright (c) 2005 David Brownell
* Copyright (c) 2006 Nokia Corporation
* - corgi_ts.c
* Copyright (C) 2004-2005 Richard Purdie
* - omap_ts.[hc], ads7846.h, ts_osk.c
* Copyright (C) 2002 MontaVista Software
* Copyright (C) 2004 Texas Instruments
* Copyright (C) 2005 Dirk Behme
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/input.h>
#include <linux/interrupt.h>
#include <linux/i2c.h>
#include "tsc2007.h"
#include <linux/of_device.h>
#include <linux/of.h>
#include <linux/of_gpio.h>
#include <linux/platform_data/tsc2007.h>
#define TSC2007_MEASURE_TEMP0 (0x0 << 4)
#define TSC2007_MEASURE_AUX (0x2 << 4)
#define TSC2007_MEASURE_TEMP1 (0x4 << 4)
#define TSC2007_ACTIVATE_XN (0x8 << 4)
#define TSC2007_ACTIVATE_YN (0x9 << 4)
#define TSC2007_ACTIVATE_YP_XN (0xa << 4)
#define TSC2007_SETUP (0xb << 4)
#define TSC2007_MEASURE_X (0xc << 4)
#define TSC2007_MEASURE_Y (0xd << 4)
#define TSC2007_MEASURE_Z1 (0xe << 4)
#define TSC2007_MEASURE_Z2 (0xf << 4)
#define TSC2007_POWER_OFF_IRQ_EN (0x0 << 2)
#define TSC2007_ADC_ON_IRQ_DIS0 (0x1 << 2)
#define TSC2007_ADC_OFF_IRQ_EN (0x2 << 2)
#define TSC2007_ADC_ON_IRQ_DIS1 (0x3 << 2)
#define TSC2007_12BIT (0x0 << 1)
#define TSC2007_8BIT (0x1 << 1)
#define MAX_12BIT ((1 << 12) - 1)
#define ADC_ON_12BIT (TSC2007_12BIT | TSC2007_ADC_ON_IRQ_DIS0)
#define READ_Y (ADC_ON_12BIT | TSC2007_MEASURE_Y)
#define READ_Z1 (ADC_ON_12BIT | TSC2007_MEASURE_Z1)
#define READ_Z2 (ADC_ON_12BIT | TSC2007_MEASURE_Z2)
#define READ_X (ADC_ON_12BIT | TSC2007_MEASURE_X)
#define PWRDOWN (TSC2007_12BIT | TSC2007_POWER_OFF_IRQ_EN)
* This define forces debug prints during development
#define DEBUG_PRINT (1)
#if(DEBUG_PRINT == 1)
#define SR_DEBUG dev_err
#else
#define SR_DEBUG dev_dbg
static inline int tsc2007_xfer(struct tsc2007 *tsc, u8 cmd)
s32 data;
u16 val;
data = i2c_smbus_read_word_data(tsc->client, cmd);
if (data < 0) {
dev_err(&tsc->client->dev, "i2c io error: %d\n", data);
return data;
/* The protocol and raw data format from i2c interface:
* S Addr Wr [A] Comm [A] S Addr Rd [A] [DataLow] A [DataHigh] NA P
* Where DataLow has [D11-D4], DataHigh has [D3-D0 << 4 | Dummy 4bit].
val = swab16(data) >> 4;
dev_dbg(&tsc->client->dev, "data: 0x%x, val: 0x%x\n", data, val);
return val;
static void tsc2007_read_values(struct tsc2007 *tsc, struct ts_event *tc)
/* y- still on; turn on only y+ (and ADC) */
tc->y = tsc2007_xfer(tsc, READ_Y);
/* turn y- off, x+ on, then leave in lowpower */
tc->x = tsc2007_xfer(tsc, READ_X);
/* turn y+ off, x- on; we'll use formula #1 */
tc->z1 = tsc2007_xfer(tsc, READ_Z1);
tc->z2 = tsc2007_xfer(tsc, READ_Z2);
/* Prepare for next touch reading - power down ADC, enable PENIRQ */
tsc2007_xfer(tsc, PWRDOWN);
static u32 tsc2007_calculate_pressure(struct tsc2007 *tsc, struct ts_event *tc)
u32 rt = 0;
/* range filtering */
if (tc->x == MAX_12BIT)
tc->x = 0;
if (likely(tc->x && tc->z1)) {
/* compute touch pressure resistance using equation #1 */
rt = tc->z2 - tc->z1;
rt *= tc->x;
rt *= tsc->x_plate_ohms;
rt /= tc->z1;
rt = (rt + 2047) >> 12;
return rt;
static bool tsc2007_is_pen_down(struct tsc2007 *ts)
* NOTE: We can't rely on the pressure to determine the pen down
* state, even though this controller has a pressure sensor.
* The pressure value can fluctuate for quite a while after
* lifting the pen and in some cases may not even settle at the
* expected value.
* The only safe way to check for the pen up condition is in the
* work function by reading the pen signal state (it's a GPIO
* and IRQ). Unfortunately such callback is not always available,
* in that case we assume that the pen is down and expect caller
* to fall back on the pressure reading.
if (!ts->get_pendown_state)
return true;
return ts->get_pendown_state(&ts->client->dev);
static irqreturn_t tsc2007_soft_irq(int irq, void *handle)
struct tsc2007 *ts = handle;
struct input_dev *input = ts->input;
struct ts_event tc;
u32 rt;
SR_DEBUG(&ts->client->dev, "%s: Entering\n", __func__);
while (!ts->stopped && tsc2007_is_pen_down(ts)) {
/* pen is down, continue with the measurement */
tsc2007_read_values(ts, &tc);
rt = tsc2007_calculate_pressure(ts, &tc);
if (!rt && !ts->get_pendown_state) {
* If pressure reported is 0 and we don't have
* callback to check pendown state, we have to
* assume that pen was lifted up.
break;
if (rt <= ts->max_rt) {
dev_dbg(&ts->client->dev,
"DOWN point(%4d,%4d), pressure (%4u)\n",
tc.x, tc.y, rt);
input_report_key(input, BTN_TOUCH, 1);
input_report_abs(input, ABS_X, tc.x);
input_report_abs(input, ABS_Y, tc.y);
input_report_abs(input, ABS_PRESSURE, rt);
input_sync(input);
} else {
* Sample found inconsistent by debouncing or pressure is
* beyond the maximum. Don't report it to user space,
* repeat at least once more the measurement.
dev_dbg(&ts->client->dev, "ignored pressure %d\n", rt);
wait_event_timeout(ts->wait, ts->stopped,
msecs_to_jiffies(10)); /* ts->poll_period */
//dev_dbg(&ts->client->dev, "UP\n");
SR_DEBUG(&ts->client->dev, "UP\n");
input_report_key(input, BTN_TOUCH, 0);
input_report_abs(input, ABS_PRESSURE, 0);
input_sync(input);
if (ts->clear_penirq)
ts->clear_penirq();
/* Now that the touch has been handled, re-enabled the PENIRQ */
enable_irq(ts->irq);
return IRQ_HANDLED;
static irqreturn_t tsc2007_hard_irq(int irq, void *handle)
if (tsc2007_is_pen_down(ts))
/* Once the IRQ handling starts, disable the interrupt */
disable_irq_nosync(ts->irq);
SR_DEBUG(&ts->client->dev, "%s: Pen down returns true\n", __func__);
return IRQ_WAKE_THREAD;
SR_DEBUG(&ts->client->dev, "%s: Clear pending interrupt", __func__);
ts->clear_penirq();
return IRQ_HANDLED;
static void tsc2007_stop(struct tsc2007 *ts)
ts->stopped = true;
mb();
wake_up(&ts->wait);
disable_irq(ts->irq);
static int tsc2007_open(struct input_dev *input_dev)
struct tsc2007 *ts = input_get_drvdata(input_dev);
int err;
ts->stopped = false;
mb();
SR_DEBUG(&ts->client->dev, "%s: Executed\n", __func__);
/* Prepare for touch readings - power down ADC and enable PENIRQ */
err = tsc2007_xfer(ts, PWRDOWN);
if (err < 0) {
tsc2007_stop(ts);
return err;
static void tsc2007_close(struct input_dev *input_dev)
tsc2007_stop(ts);
#ifdef CONFIG_OF
static int tsc2007_get_pendown_state_gpio(struct device *dev)
struct i2c_client *client = to_i2c_client(dev);
struct tsc2007 *ts = i2c_get_clientdata(client);
return !gpio_get_value(ts->gpio);
static int tsc2007_probe_dt(struct i2c_client *client, struct tsc2007 *ts)
struct device_node *np = client->dev.of_node;
u32 val32;
u64 val64;
if (!np) {
dev_err(&client->dev, "missing device tree data\n");
return -EINVAL;
if (!of_property_read_u32(np, "ti,max-rt", &val32))
ts->max_rt = val32;
ts->max_rt = MAX_12BIT;
if (!of_property_read_u32(np, "ti,fuzzx", &val32))
ts->fuzzx = val32;
if (!of_property_read_u32(np, "ti,fuzzy", &val32))
ts->fuzzy = val32;
if (!of_property_read_u32(np, "ti,fuzzz", &val32))
ts->fuzzz = val32;
if (!of_property_read_u64(np, "ti,poll-period", &val64))
ts->poll_period = val64;
ts->poll_period = 1;
if (!of_property_read_u32(np, "ti,x-plate-ohms", &val32)) {
ts->x_plate_ohms = val32;
} else {
dev_err(&client->dev, "missing ti,x-plate-ohms devicetree property.");
return -EINVAL;
ts->gpio = of_get_gpio(np, 0);
printk("ts->gpio = %d\n", ts->gpio);
if (gpio_is_valid(ts->gpio))
ts->get_pendown_state = tsc2007_get_pendown_state_gpio;
/* If GPIO is valid, then request the GPIO for use */
SR_DEBUG(&client->dev, "%s: Requesting GPIO", __func__);
if (gpio_request(ts->gpio, "nPENIRQ"))
//SR_DEBUG(&client->dev, "%s: Requesting GPIO failed", __func__);
/* Set the direction to be input - may not be required */
SR_DEBUG(&client->dev, "%s: Setting direction for GPIO", __func__);
if (gpio_direction_input(ts->gpio))
gpio_free(ts->gpio);
/* Set the debounce limit/value for the GPIO
//SR_DEBUG(&client->dev, "%s: Setting debounce for GPIO", __func__);
if (gpio_set_debounce(ts->gpio, 50000))
dev_warn(&client->dev,
"GPIO not specified in DT (of_get_gpio returned %d)\n",
ts->gpio);
#else
dev_err(&client->dev, "platform data is required!\n");
return -EINVAL;
static int tsc2007_probe_pdev(struct i2c_client *client, struct tsc2007 *ts,
const struct tsc2007_platform_data *pdata,
const struct i2c_device_id *id)
ts->model = pdata->model;
ts->x_plate_ohms = pdata->x_plate_ohms;
ts->max_rt = pdata->max_rt ? : MAX_12BIT;
ts->poll_period = pdata->poll_period ? : 1;
ts->get_pendown_state = pdata->get_pendown_state;
ts->clear_penirq = pdata->clear_penirq;
ts->fuzzx = pdata->fuzzx;
ts->fuzzy = pdata->fuzzy;
ts->fuzzz = pdata->fuzzz;
if (pdata->x_plate_ohms == 0) {
dev_err(&client->dev, "x_plate_ohms is not set up in platform data");
return -EINVAL;
static void tsc2007_call_exit_platform_hw(void *data)
struct device *dev = data;
const struct tsc2007_platform_data *pdata = dev_get_platdata(dev);
pdata->exit_platform_hw();
static int tsc2007_probe(struct i2c_client *client,
const struct tsc2007_platform_data *pdata = dev_get_platdata(&client->dev);
struct tsc2007 *ts;
struct input_dev *input_dev;
int err;
if (!i2c_check_functionality(client->adapter,
I2C_FUNC_SMBUS_READ_WORD_DATA))
return -EIO;
ts = devm_kzalloc(&client->dev, sizeof(struct tsc2007), GFP_KERNEL);
if (!ts)
return -ENOMEM;
if (pdata)
err = tsc2007_probe_pdev(client, ts, pdata, id);
err = tsc2007_probe_dt(client, ts);
if (err)
return err;
input_dev = devm_input_allocate_device(&client->dev);
if (!input_dev)
return -ENOMEM;
i2c_set_clientdata(client, ts);
ts->client = client;
/* map GPIO numbers to IRQ numbers */
client->irq = gpio_to_irq(ts->gpio);
ts->irq = client->irq;
SR_DEBUG(&client->dev, "%s: IRQ number is %d", __func__, ts->irq);
ts->input = input_dev;
init_waitqueue_head(&ts->wait);
snprintf(ts->phys, sizeof(ts->phys),
"%s/input0", dev_name(&client->dev));
input_dev->name = "TSC2007 Touchscreen";
input_dev->phys = ts->phys;
input_dev->id.bustype = BUS_I2C;
input_dev->open = tsc2007_open;
input_dev->close = tsc2007_close;
input_set_drvdata(input_dev, ts);
input_dev->evbit[0] = BIT_MASK(EV_KEY) | BIT_MASK(EV_ABS);
input_dev->keybit[BIT_WORD(BTN_TOUCH)] = BIT_MASK(BTN_TOUCH);
input_set_abs_params(input_dev, ABS_X, 0, MAX_12BIT, ts->fuzzx, 0);
input_set_abs_params(input_dev, ABS_Y, 0, MAX_12BIT, ts->fuzzy, 0);
input_set_abs_params(input_dev, ABS_PRESSURE, 0, MAX_12BIT,
ts->fuzzz, 0);
if (pdata) {
if (pdata->exit_platform_hw) {
err = devm_add_action(&client->dev,
tsc2007_call_exit_platform_hw,
&client->dev);
if (err) {
"Failed to register exit_platform_hw action, %d\n",
err);
return err;
if (pdata->init_platform_hw)
pdata->init_platform_hw();
err = devm_request_threaded_irq(&client->dev, ts->irq,
tsc2007_hard_irq, tsc2007_soft_irq,
IRQF_TRIGGER_FALLING /*| IRQF_TRIGGER_RISING | IRQF_ONESHOT*/,
client->dev.driver->name, ts);
if (err) {
dev_err(&client->dev, "Failed to request irq %d: %d\n",
ts->irq, err);
return err;
tsc2007_stop(ts);
err = input_register_device(input_dev);
if (err) {
"Failed to register input device: %d\n", err);
return err;
static const struct i2c_device_id tsc2007_idtable[] = {
{ "tsc2007", 0 },
MODULE_DEVICE_TABLE(i2c, tsc2007_idtable);
#ifdef CONFIG_OF
static const struct of_device_id tsc2007_of_match[] = {
{ .compatible = "ti,tsc2007" },
{ /* sentinel */ }
MODULE_DEVICE_TABLE(of, tsc2007_of_match);
static struct i2c_driver tsc2007_driver = {
.driver = {
.owner = THIS_MODULE,
.name = "tsc2007",
.of_match_table = of_match_ptr(tsc2007_of_match),
.id_table = tsc2007_idtable,
.probe = tsc2007_probe,
module_i2c_driver(tsc2007_driver);
MODULE_AUTHOR("Kwangwoo Lee <kwlee@mtekvision.com>");
MODULE_DESCRIPTION("TSC2007 TouchScreen Driver");
MODULE_LICENSE("GPL");中断查看:
cat /proc/interrupts
CPU0
19: 28915 GIC-0 27 Level arch_timer
21: 0 GIC-0 50 Level /soc/timer@01c20c00
22: 0 GIC-0 82 Level 1c02000.dma-controller
23: 29990 GIC-0 92 Level sunxi-mmc
24: 2 GIC-0 103 Level musb-hdrc.1.auto
25: 0 GIC-0 104 Level ehci_hcd:usb1
26: 0 GIC-0 105 Level ohci_hcd:usb2
31: 0 GIC-0 62 Level sun4i-a10-lradc-keys
34: 4 GIC-0 33 Level
36: 304044 GIC-0 38 Level mv64xxx_i2c
37: 3692 GIC-0 114 Level eth0
38: 213809 GIC-0 97 Level sun6i-spi
71: 1401 sunxi_pio_edge 32 Edge tsc2007
IPI0: 0 CPU wakeup interrupts
IPI1: 0 Timer broadcast interrupts
IPI2: 0 Rescheduling interrupts
IPI3: 0 Function call interrupts
IPI4: 0 CPU stop interrupts
IPI5: 0 IRQ work interrupts
IPI6: 0 completion interrupts
Err: 0
从一个 NUC972 开发板拆了一片 TSC2007 下来,
并且使用了 GPIO 中断, 发现没有什么改善.
调整了一下 tsc2007_core.c:
* Using code from:
* - ads7846.c
* - corgi_ts.c
s32 data;
u16 val;
if (data < 0) {
return data;
return val;
u32 rt = 0;
tc->x = 0;
rt *= tc->x;
rt /= tc->z1;
return rt;
* expected value.
return true;
struct ts_event tc;
u32 rt;
dev_dbg(&ts->client->dev, "%s: Entering\n", __func__);
break;
tc.x, tc.y, rt);
input_sync(input);
} else {
input_sync(input);
ts->clear_penirq();
return IRQ_HANDLED;
dev_dbg(&ts->client->dev, "%s: Pen down returns true\n", __func__);
dev_dbg(&ts->client->dev, "%s: Clear pending interrupt", __func__);
ts->clear_penirq();
return IRQ_HANDLED;
ts->stopped = true;
mb();
wake_up(&ts->wait);
int err;
mb();
dev_dbg(&ts->client->dev, "%s: Executed\n", __func__);
if (err < 0) {
tsc2007_stop(ts);
return err;
tsc2007_stop(ts);
#ifdef CONFIG_OF
u32 val32;
u64 val64;
if (!np) {
return -EINVAL;
ts->max_rt = val32;
ts->fuzzx = val32;
ts->fuzzy = val32;
ts->fuzzz = val32;
} else {
return -EINVAL;
dev_dbg(&client->dev, "%s: Requesting GPIO", __func__);
//dev_dbg(&client->dev, "%s: Requesting GPIO failed", __func__);
dev_dbg(&client->dev, "%s: Setting direction for GPIO", __func__);
//dev_dbg(&client->dev, "%s: Setting debounce for GPIO", __func__);
ts->gpio);
#else
return -EINVAL;
return -EINVAL;
struct tsc2007 *ts;
int err;
return -EIO;
if (!ts)
return -ENOMEM;
if (pdata)
if (err)
return err;
if (!input_dev)
return -ENOMEM;
dev_dbg(&client->dev, "%s: IRQ number is %d", __func__, ts->irq);
ts->fuzzz, 0);
if (pdata) {
&client->dev);
if (err) {
err);
return err;
if (err) {
ts->irq, err);
return err;
tsc2007_stop(ts);
if (err) {
return err;
{ "tsc2007", 0 },
#ifdef CONFIG_OF
{ /* sentinel */ }
.driver = {
.name = "tsc2007",
MODULE_LICENSE("GPL");在线
* Using code from:
* - ads7846.c
* - corgi_ts.c
s32 data;
u16 val;
if (data < 0) {
return data;
return val;
u32 rt = 0;
tc->x = 0;
rt *= tc->x;
rt /= tc->z1;
return rt;
* expected value.
return true;
struct ts_event tc;
u32 rt;
break;
tc.x, tc.y, rt);
input_sync(input);
} else {
input_sync(input);
ts->clear_penirq();
return IRQ_HANDLED;
ts->clear_penirq();
return IRQ_HANDLED;
ts->stopped = true;
mb();
wake_up(&ts->wait);
int err;
mb();
if (err < 0) {
tsc2007_stop(ts);
return err;
tsc2007_stop(ts);
#ifdef CONFIG_OF
u32 val32;
u64 val64;
if (!np) {
return -EINVAL;
ts->max_rt = val32;
ts->fuzzx = val32;
ts->fuzzy = val32;
ts->fuzzz = val32;
} else {
return -EINVAL;
ts->gpio);
#else
return -EINVAL;
return -EINVAL;
struct tsc2007 *ts;
int err;
return -EIO;
if (!ts)
return -ENOMEM;
if (pdata)
if (err)
return err;
if (!input_dev)
return -ENOMEM;
ts->fuzzz, 0);
if (pdata) {
&client->dev);
if (err) {
err);
return err;
if (err) {
ts->irq, err);
return err;
tsc2007_stop(ts);
if (err) {
return err;
{ "tsc2007", 0 },
#ifdef CONFIG_OF
{ /* sentinel */ }
.driver = {
.name = "tsc2007",
* Using code from:
* - ads7846.c
* - corgi_ts.c
s32 data;
u16 val;
if (data < 0) {
return data;
return val;
u32 rt = 0;
tc->x = 0;
rt *= tc->x;
rt /= tc->z1;
return rt;
* expected value.
return true;
struct ts_event tc;
u32 rt;
break;
tc.x, tc.y, rt);
input_sync(input);
} else {
input_sync(input);
ts->clear_penirq();
return IRQ_HANDLED;
ts->clear_penirq();
return IRQ_HANDLED;
ts->stopped = true;
mb();
wake_up(&ts->wait);
int err;
mb();
if (err < 0) {
tsc2007_stop(ts);
return err;
tsc2007_stop(ts);
#ifdef CONFIG_OF
u32 val32;
u64 val64;
if (!np) {
return -EINVAL;
ts->max_rt = val32;
ts->fuzzx = val32;
ts->fuzzy = val32;
ts->fuzzz = val32;
} else {
return -EINVAL;
ts->gpio);
#else
return -EINVAL;
return -EINVAL;
struct tsc2007 *ts;
int err;
return -EIO;
if (!ts)
return -ENOMEM;
if (pdata)
if (err)
return err;
if (!input_dev)
return -ENOMEM;
ts->fuzzz, 0);
if (pdata) {
&client->dev);
if (err) {
err);
return err;
if (err) {
ts->irq, err);
return err;
tsc2007_stop(ts);
if (err) {
return err;
{ "tsc2007", 0 },
#ifdef CONFIG_OF
{ /* sentinel */ }
.driver = {
.name = "tsc2007",
MODULE_LICENSE("GPL");最后修改,基本不抱什么希望了.
触摸ad一般要做滤波的,不滤波效果是很差。有没有试过用tslib?
linux下应用层有用 tslib,
但是发现 V3s 主线上的 ns2009 驱动有问题,
我的修改思路是,
检测到压力寄存器超过 0x80,
那么先采集两次x,y扔掉,
再采集10次x,y, 去掉两个最大值,去掉两个最小值, 中间求平均。
但是发现,经常有飞点,这种飞点有时候会出来7,8个,
已经干扰系统运行了。
现在想到的办法是记录上一次的时间戳(jiffies)和xy, 如果时间戳很近并且两点距离很远的点直接抛弃。
有后续???
哦,那我也用这个芯片了。呵呵,跟着吃螃蟹。
这个是荔枝派zero开发板的触摸屏驱动程序,驱动是现成的,不用吃螃蟹,改进优化一下就可以了。
大神,您好,您修改好的,ns2009驱动,可以分享一下给我学习一下吗?本人小白,正在学习这方面知识
这个是 。。。。 你懂的
你到时候有什么问题, 直接发上来看看
后来我想想, 应该是当时 tslib 静态链接造成的, 没有正确使用 tslib 的插件。
因为 tslib 里面本身自带了各种滤波器插件, 所以你不用改任何代码,但是我一直没有来得及验证这个想法
就参考晕哥的方法改的。代码在另一电脑,等空上传。
-------------粘贴代码出现下面的错误,难道不能用[]?
继续发帖前请修正以下错误:
[ i ] 标签不允许在其自身内部使用
谢谢,谢谢
static int ns2009_ts_report(struct ns2009_data *data)
u16 x[10], y[10], z1;
u16 agvx,agvy,maxx,minx,maxy,miny;
s32 sx,sy,stx,sty,stax,stay;
int i;
int ret;
* NS2009 chip supports pressure measurement, but currently it needs
* more investigation, so we only use z1 axis to detect pen down
* here.
ret = ns2009_ts_read_data(data, NS2009_READ_Z1_LOW_POWER_12BIT, &z1);
if (ret) return ret;
if (z1 >= NS2009_PEN_UP_Z1_ERR)
for(i=0;i<10;i++)
ret = ns2009_ts_read_data(data, NS2009_READ_X_LOW_POWER_12BIT,&x[i]);
ret = ns2009_ts_read_data(data, NS2009_READ_Y_LOW_POWER_12BIT,&y[i]);
//计算平均值
agvx=0;
agvx=0;
maxx=x[2];
minx=maxx;
maxy=y[2];
miny=maxy;
for(i=0;i<10;i++)
agvx += x[i];
agvy += y[i];
if(minx > x[i]) minx = x[i];
if(maxx < x[i]) maxx = x[i];
if(miny > y[i]) miny = y[i];
if(maxy < y[i]) maxy = y[i];
//agvx -= maxx;
//agvx -= minx;
///agvy -= maxy;
//agvy -= miny;
agvx /= 10;
agvy /= 10;
//计算方差
stax = agvx;
stay = agvy;
sx = 0;
sy = 0;
for(i=0;i<10;i++)
stx = x[i];
sx += (stx-stax)*(stx-stax);
sty = y[i];
sy += (sty-stay)*(sty-stay);
sx /= 10;
sy /= 10;
if(sx>50) return sx;
if(sy>50) return sy;
if (!data->pen_down)
input_report_key(data->input, BTN_TOUCH, 1);
data->pen_down = true;
input_report_abs(data->input, ABS_X, agvx);
input_report_abs(data->input, ABS_Y, agvy);
input_sync(data->input);
} else if (data->pen_down) {
input_report_key(data->input, BTN_TOUCH, 0);
data->pen_down = false;
}离线
不错, 这个算法好, 晚点学习学习!
马上要用到了,谢谢大神们的分享!
这个好,可以用MCU来模拟,就是需要MCU有i2c salve功能。
@晕哥,能发出测试视频看看效果吗
john78 wrote:
static int ns2009_ts_report(struct ns2009_data *data) { u16 x[10], y[10], z1; u16 agvx,agvy,maxx,minx,maxy,miny; s32 sx,sy,stx,sty,stax,stay; int i; int ret; /* * NS2009 chip supports pressure measurement, but currently it needs * more investigation, so we only use z1 axis to detect pen down * here. */ ret = ns2009_ts_read_data(data, NS2009_READ_Z1_LOW_POWER_12BIT, &z1); if (ret) return ret; if (z1 >= NS2009_PEN_UP_Z1_ERR) { for(i=0;i<10;i++) { ret = ns2009_ts_read_data(data, NS2009_READ_X_LOW_POWER_12BIT,&x[i]); if (ret) return ret; ret = ns2009_ts_read_data(data, NS2009_READ_Y_LOW_POWER_12BIT,&y[i]); if (ret) return ret; } //计算平均值 agvx=0; agvx=0; maxx=x[2]; minx=maxx; maxy=y[2]; miny=maxy; for(i=0;i<10;i++) { agvx += x[i]; agvy += y[i]; if(minx > x[i]) minx = x[i]; if(maxx < x[i]) maxx = x[i]; if(miny > y[i]) miny = y[i]; if(maxy < y[i]) maxy = y[i]; } //agvx -= maxx; //agvx -= minx; ///agvy -= maxy; //agvy -= miny; agvx /= 10; agvy /= 10; //计算方差 stax = agvx; stay = agvy; sx = 0; sy = 0; for(i=0;i<10;i++) { stx = x[i]; sx += (stx-stax)*(stx-stax); sty = y[i]; sy += (sty-stay)*(sty-stay); } sx /= 10; sy /= 10; if(sx>50) return sx; if(sy>50) return sy; if (!data->pen_down) { input_report_key(data->input, BTN_TOUCH, 1); data->pen_down = true; } input_report_abs(data->input, ABS_X, agvx); input_report_abs(data->input, ABS_Y, agvy); input_sync(data->input); } else if (data->pen_down) { input_report_key(data->input, BTN_TOUCH, 0); input_sync(data->input); data->pen_down = false; } return 0; }
我修改了驱动部分代码之后发现在执行ts_calibrate和ts_test效果还没有原来在好
运行QT程序也没有什么作用
你们处理电阻屏数据的时候有发现压力不一样处理出来的坐标也不一样,这个有什么算法处理一下吗
先mark一波
