IPL g75a3331
D-1e
HW Reset
24400c00 00000000
Resume? N, addr 00000000
miupll_266MHz
MIU0 zq=0x003c
miu_bw_set
utmi_1_init done
utmi_2_init done
utmi_3_init done
usbpll init done......
CPU=1000Mhz
cpupll init done
SPI 54M
clk_init done
P1 USB_rterm trim=0x0000
P1 USB_HS_TX_CURRENT trim=0x0001
P2 USB_rterm trim=0x0000
P2 USB_HS_TX_CURRENT trim=0x0001
P3 USB_rterm trim=0x0000
P3 USB_HS_TX_CURRENT trim=0x0001
PM_vol_bgap trim=0x003f
GCR_SAR_DATA trim=0x0190
ETH 10T output swing trim=0x0010
ETH 100T output swing trim=0x0010
ETH RX input impedance trim=0x0000
ETH TX output impedance trim=0x0001
MIPI_HS_RTERM trim=0x0001
MIPI_LP_RTERM trim=0x0000
128MB
BIST0_0001-OK
Enable MMU and CACHE
Load IPL_CUST from SPINAND
QUAD MODE ENABLE
Checksum OK
IPL_CUST gabf224a
runUBOOT()
runUBOOT()
[SPINAND]
SPI 54M
Load UBOOT from SPINAND
-Verify UBOOT CRC32 passed!
-Decompress UBOOT XZ
decomp_size=0x000a3db0
Disable MMU and D-cache before jump to UBOOT
U-Boot 2015.01 (Sep 06 2023 - 18:38:20)
Version: I2g#######
[WDT] Enalbe WATCHDOG 10s
Watchdog enabled
I2C: ready
DRAM:
WARNING: Caches not enabled
SPINAND: _MDrv_SPINAND_GET_INFO: Found SPINAND INFO
(0xC8) (0x51)
SPINAND: board_nand_init: CIS contains part info
128 MiB
MMC: MStar SD/MMC: 0
In: serial
Out: serial
Err: serial
Net: MAC Address 00:30:1B:BA:02:DB
Auto-Negotiation...
AN failLink Status Speed:10 Full-duplex:0
Status Error!
sstar_emac
lcd spi init >>>>>>>>>>>>>>>>>>>>>>>>
gpio debug MHal_GPIO_Pad_Set: pin=86
gpio debug MHal_GPIO_Pad_Set: pin=69
gpio debug MHal_GPIO_Pad_Set: pin=70
gpio debug MHal_GPIO_Pad_Set: pin=85
gpio debug MHal_GPIO_Pad_Set: pin=5
gpio debug MHal_GPIO_Pad_Set: pin=12
gpio debug MHal_GPIO_Pad_Set: pin=4
IPL g75a3331
D-1e
HW Reset
24400c00 00000000
miupll_266MHz
MIU0 zq=0x003c
miu_bw_set
utmi_1_init done
utmi_2_init done
utmi_3_init done
CPU=1000Mhz
cpupll init done
SPI 54M
clk_init done
128MB
BIST0_0001-OK
QUAD MODE ENABLE
Checksum OK
IPL_CUST gabf224a
runUBOOT()
runUBOOT()
[SPINAND]
SPI 54M
Version: I2g#######
Watchdog enabled
I2C: ready
DRAM:
(0xC8) (0x51)
128 MiB
In: serial
Out: serial
Err: serial
Auto-Negotiation...
Status Error!
sstar_emac
IPL g75a3331
D-1e
HW Reset
24400c00 00000000
