楼主 # 2023-12-09 19:24:29
muxi01
已发帖子: 63
嘉立创的 泰山派,刚下单还没送货,原价转手有人要么?
我的快播小方 RK3188已经可以进入UBOOT了,EMMC也识别到了,所以刚下单的泰山派不打算要了,目前嘉立创商城缺货了,有人需要的话请留言。
快播小方开机 日志,下一步就是进入kernel了。
Model: Radxa Rock
MPIDR: 0x80000000
Serial: raw, 0x20064000
DRAM:  1 GiB
Sysmem: init
 ------Time:09:25:04------0
Relocation Offset: 00000000
Relocation fdt: 9de43ce0 - 9de48de8
CR: M/C/I
I2c1 speed: 400000Hz
VDD_ARM -5 uV
*** Warning - No MMC card found, using default environment
MMC:   dwmmc@1021c000: 0
In:    serial
Out:   serial
Err:   serial
Model: Radxa Rock
MPIDR: 0x80000000
## Error: "rkimg_bootdev" not defined
defalut set mmc 0
Bootdev(scan): mmc 0
rockchip_get_bootdev:257 -> dev_type=6 devnum=0
blk_get_devnum_by_type 90
MMC0: High Speed, 37Mhz
## Unknown partition table type 0
PartType: <NULL>
No misc partition
boot mode: None
CLK: (uboot. arm: enter 0 KHz, init 0 KHz, kernel 0N/A)
  apll 600000 KHz
  dpll 300000 KHz
  cpll 132000 KHz
  gpll 891000 KHz
Net:   Net Initialization Skipped
No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
## Error: "version" not defined
=> mmc info
Device: dwmmc@1021c000
Manufacturer ID: 15
OEM: 100
Timing Interface: High Speed
Tran Speed: 37500000
Rd Block Len: 512
MMC version 4.4.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 1 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 2 MiB ENH
RPMB Capacity: 128 KiB ENH
#1 2023-12-11 08:56:57
已发帖子: 1,409
Re: 嘉立创的 泰山派,刚下单还没送货,原价转手有人要么?
好家伙,五岳剑派!
多少钱转呢?什么配置?
楼主 #2 2023-12-11 11:15:47
muxi01
已发帖子: 63
已经卖了
