64 bytes from 183.2.193.224: seq=2593 ttl=56 time=52.159 ms
64 bytes from 183.2.193.224: seq=2594 ttl=56 time=9.867 ms
64 bytes from 183.2.193.224: seq=2595 ttl=56 time=9.895 ms
[1970-01-01 02:22:37] WARNING: cedarc <waitInterruptDecoder:748>: wait ve interrupt timeout. ret = 0
64 bytes from 183.2.193.224: seq=2596 ttl=56 time=10.993 ms
64 bytes from 183.2.193.224: seq=2597 ttl=56 time=30.195 ms
64 bytes from 183.2.193.224: seq=2598 ttl=56 time=12.402 ms
64 bytes from 183.2.193.224: seq=2599 ttl=56 time=6.879 ms
64 bytes from 183.2.193.224: seq=2600 ttl=56 time=12.246 ms
64 bytes from 183.2.193.224: seq=2601 ttl=56 time=21.728 ms
64 bytes from 183.2.193.224: seq=2602 ttl=56 time=17.808 ms
64 bytes from 183.2.193.224: seq=2603 ttl=56 time=6.241 ms
64 bytes from 183.2.193.224: seq=2604 ttl=56 time=20.518 ms
64 bytes from 183.2.193.224: seq=2605 ttl=56 time=9.801 ms
64 bytes from 183.2.193.224: seq=2606 ttl=56 time=11.661 ms
64 bytes from 183.2.193.224: seq=2607 ttl=56 time=8.761 ms
64 bytes from 183.2.193.224: seq=2608 ttl=56 time=16.567 ms
64 bytes from 183.2.193.224: seq=2609 ttl=56 time=7.684 ms
64 bytes from 183.2.193.224: seq=2610 ttl=56 time=47.762 ms
64 bytes from 183.2.193.224: seq=2611 ttl=56 time=16.499 ms
64 bytes from 183.2.193.224: seq=2612 ttl=56 time=25.055 ms
64 bytes from 183.2.193.224: seq=2613 ttl=56 time=13.752 ms
64 bytes from 183.2.193.224: seq=2614 ttl=56 time=11.462 ms
64 bytes from 183.2.193.224: seq=2615 ttl=56 time=7.686 ms
[1970-01-01 02:22:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail, 3143162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
64 bytes from 183.2.193.224: seq=2616 ttl=56 time=5.880 ms
[1970-01-01 02:22:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail, 3143162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
64 bytes from 183.2.193.224: seq=2617 ttl=56 time=41.615 ms
[1970-01-01 02:22:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail, 3143162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.离线
RTL8723DS WIFI测试了12小时都正常
改大这个初始化参数试一试: VideoConf.nVbvBufferSize
if(Decoder->ScaleDownEn > 0){
VideoConf.nVbvBufferSize = 1*1024*1024;
VideoConf.bScaleDownEn = 1;
VideoConf.nHorizonScaleDownRatio = 1;
VideoConf.nVerticalScaleDownRatio = 1;
VideoConf.eOutputPixelFormat = Decoder->decode_format;
VideoConf.nDeInterlaceHoldingFrameBufferNum = GetConfigParamterInt("pic_4di_num", 2);
VideoConf.nDisplayHoldingFrameBufferNum = GetConfigParamterInt("pic_4list_num", 3);
VideoConf.nRotateHoldingFrameBufferNum = GetConfigParamterInt("pic_4rotate_num", 0);
VideoConf.nDecodeSmoothFrameBufferNum = GetConfigParamterInt("pic_4smooth_num", 3);
VideoConf.memops = Decoder->memops;
nRet = InitializeVideoDecoder(Decoder->pVideoDec, &VideoInfo, &VideoConf);离线
扩大VideoConf.nVbvBufferSize参数,是不是能延长到4小时才挂掉?
所以是WIFI断连的问题导致挂掉的么?
可能和DRAM内存频率有关系,从792M降低到600M貌似正常多了。
