#221 2025-09-14 20:37:50
myxiaonia
已发帖子: 83
Re: 45块顺丰包邮买到的10.1寸保资LCD价签F1C200S 值不值
搞个python上去吧
#223 2025-09-30 08:42:42
gcbhgv
18578292200 wrote:
/files/members/2995/微信图片_20240921210652.jpg
可以跑自己的应用了,只是帧率低的可怜
我去f1c200性能差这么多,新版的保资用ssd201也可以直接进系统,编了个lvgl性能测试,能到150帧,10倍性能,就是可用ram不大,连网后就只有9m
#224 2025-10-01 20:47:47
heiyanquan
@DDER
上面分享的tina3.5 sdk遇到屏幕抖动的问题,可以试试修改lichee/linux-3.10/drivers/video/sunxi/disp/disp/de/lowlevel_v1x/de_layer.c文件DE_BE_Layer_Set_Screen_Win函数,供参考
__s32 DE_BE_Layer_Set_Screen_Win(__u32 sel, __u8 layidx, disp_window *win)
	__u32 tmp;
	if (win->width == 0 || win->height == 0) {
	    printk("ERROR,%s:%d w,h=[%d,%d]\n", __FUNCTION__, __LINE__, win->width, win->height);
	} else {
        tmp = ((((__u32) (win->y)) >> 31) << 31) |
    	    ((((__u32) (win->y)) & 0x7fff) << 16) |
    	    ((((__u32) (win->x)) >> 31) << 15) | (((__u32) (win->x)) & 0x7fff);
    	DE_BE_WUINT32IDX(sel, DE_BE_LAYER_CRD_CTL_OFF, layidx, tmp);
    	DE_BE_WUINT32IDX(sel, DE_BE_LAYER_SIZE_OFF,
    			 layidx, (win->height - 1) << 16 | (win->width - 1));
#225 2025-10-14 20:47:47
ooppuyg
屏幕边角有红色会不会是系统问题呢?
#227 2025-10-14 21:46:23
memory
已发帖子: 712
ooppuyg wrote:
屏幕边角有红色会不会是系统问题呢?
不是,液晶老化。
#229 2025-11-05 10:23:55
artint
去年买了三块,48/块,结果都是老化很严重的
#230 2025-11-05 15:43:48
sofia
还有吗
#231 2026-02-13 17:26:54
aaaccc2000
@18578292200
可以添加图片和视频到/mnt/UDISK/bloziplayer 文件夹,配置/mnt/UDISK/bloziplayer/bloziplayer.json来控制播放内容
默认是这个:
{"code":0,"data":[{"type":"video","label":"video","time":0,"area":{"left":0,"top":0,"width":800,"height":800},"files":[{"name":"blozi-800-800.mp4","md5":"9746fc6bc53e0cf5f1c475905e193b15"}]},{"type":"img","label":"tag","time":0,"area":{"left":0,"top":800,"width":800,"height":480},"files":[{"name":"tag-5000001054-1629347081.png","md5":"b9441367c35d85189d5e2c23cf377453"}]}],"type":"2"}
修改/etc/wifi/wpa_supplicant.conf里面的热点名称和密码连接WIFI
wpa_supplicant.conf文件我看了/etc目录里面,wifi里面没有,
#232 2026-02-13 21:01:07
aaaccc2000
JiangLin wrote:
本来/etc/wifi/wpa_supplicant.conf中是没有network字段的,我自己添加的:
network={
    ssid="troyself-wifi"
    psk="xxx"  //已经更改为自己的wifi密码
    key_mgmt=WPA-PSK
    priority=1
搞定了吗?我没有搞出来
#233 2026-02-13 21:40:21
aaaccc2000
热点连接不上,那位大佬看看
修改了以下2个文件,还是无法连接网络
/etc/prole.d/bloziplayer.sh
/etc/wpa_supplicant.conf
#234 2026-03-02 09:25:31
wnk64
给我打开新世界的大门了,自带f1c200s,rgb转mipi芯片,10寸mipi屏,才45元,而且现在还有卖,还有一款30元的,我先买下试试水
