楼主 # 2024-09-19 00:40:16
xichuangxue
已发帖子: 26
hi3516ev300摄像头-官方SDK不得劲,各种人脸检测跑起来(Tengine\NCNN\Dlib)
hi3516ev300摄像头的前面几个帖子如下:
hi3516ev300摄像头-刷OpenIPC固件
https://whycan.com/t_11292.html
motion Detect 实现
https://whycan.com/t_11291.html
人形检测
https://whycan.com/t_11275.html
话接上文,官方SDK中的人形检测只能判断是否有人,没办法用红框标记出来,实在很不得劲。于是一顿搜索,果然找到几个可以在嵌入式上跑的开源项目,
于是在128M内存,256M Flash小身板上,都跑了一下最简单的人脸检测,记录如下:
原图size 474*316
Tengine 之 ultraface
参考 https://github.com/OAID/Tengine
使用 Tengine 的 ultraface例程进行处理,用时275.6ms,速度最佳,准确率略输retinaface
/tengine # ./tm_ultraface -i images/selfie_960.jpg -m models/rfb-320.tmfile
tengine-lite library version: 1.5-dev
Repeat 1 times, thread 1, avg time 275.66 ms, max_time 275.66 ms, min_time 275.66 ms
detected face num: 4
BOX 0.97:(389.72, 58.97),(458.94, 142.53)
BOX 0.91:(38.55, 87.36),(82.94, 147.53)
BOX 0.91:(289.84, 100.03),(325.86, 149.08)
BOX 0.94:(168.73, 81.97),(206.14, 133.12)
[DETECTED IMAGE SAVED]:
Tengine 之 retinaface
参考相同git ,使用不同例子,用时686.3ms,速度第二,用时间换来了准确率。可以看到还标出5个关键点。
~/tengine # ./tm_retinaface -i images/mtcnn_face4.jpg
img_h, img_w : 316, 474
Repeat 1 times, thread 1, avg time 686.30 ms, max_time 686.30 ms, min_time 686.30 ms
BOX 1.00:( 38.4053 , 86.142 ),( 46.3009 , 64.0174 )
BOX 0.99:( 384.076 , 56.9844 ),( 76.968 , 83.9609 )
BOX 0.99:( 169.196 , 87.1324 ),( 38.4133 , 46.8504 )
BOX 0.98:( 290.004 , 104.453 ),( 37.6345 , 46.7777 )
腾讯开源的ncnn
参考 https://github.com/Tencent/ncnn.git
用时0.99s,速度第三,
/tengine/images # time ./retinaface selfie_960.jpg
dlopen failed File not found
load vulkan driver failed
0.99604 at 38.39 86.17 46.31 x 64.00
0.98804 at 384.06 57.02 76.96 x 83.92
0.98677 at 169.21 87.12 38.40 x 46.85
0.98447 at 290.00 104.45 37.62 x 46.79
waitKey stub
real 0m 0.99s
user 0m 0.90s
sys 0m 0.09s
dlib 之frontal_face_detector
参考https://github.com/david8862/dlib_on_arm
这个交叉编译又复杂,依赖又多,差点放弃,居然耗时最多,准确率也最低,漏检测一个人脸,运行结果图就不上了
/tengine/dlib # time ./sl_face_detect ../images/selfie_960.jpg
processing image ../images/selfie_960.jpg
Number of faces detected: 3
faces detected: [(352, 179) (438, 265)]
faces detected: [(102, 188) (188, 275)]
faces detected: [(563, 208) (649, 294)]
real 0m 34.48s
user 0m 34.43s
sys 0m 0.00s
总结
身板小归小,人脸识别也能跑。
3516本身的硬件计算Hog没能用起来,实在有些可惜 ,否则检测时间还会有很大提升。坛子里的大佬如有建议,还请不吝指导一下,感激不尽。
后续打算
原本以为在474316 大小用时 276ms, 预期在19201080图片上用时会和数据量成倍数关系的,结果直接刷新我的认知。
用ultraface跑一直不含人脸的19201080的图,用时280ms左右。 假如处理19201080图片的fps=3的话,感官上,延迟还可以接受,大概算是实时的吧。
所以最终是打算用官方SDK中的SMD例程,检测到人形后, 取一张图片来跑前面的ultra face,如果检测到人脸就标记后存下来。
顺便打个小广告,有需要的坛友,可以咸鱼购买小身板开发板
【闲鱼】 https://m.tb.cn/h.grWdc1o?tk=2XJ637NQSq4 MF6563 「我在闲鱼发布了【HI3516EV300开发板,cortex A7@ 900M。】」
点击链接直接打开
最近编辑记录 xichuangxue (2024-09-19 00:56:15)
#1 2024-09-19 16:03:59
wupaul2001
已发帖子: 307
Re: hi3516ev300摄像头-官方SDK不得劲,各种人脸检测跑起来(Tengine\NCNN\Dlib)
比我用全志A133慢
