楼主 # 2024-11-16 12:26:13
memory
已发帖子: 712
NXP GUI Guider 生成代码结构分析
main.c
int main(int argc, char ** argv)
    (void) argc;    /*Unused*/
    (void) argv;    /*Unused*/
    /*Initialize LittlevGL*/
    lv_init();
    /*Initialize the HAL (display, input devices, tick) for LittlevGL*/
    hal_init();
    /*Create a GUI-Guider app */
    setup_ui(&guider_ui);  //运行第一个screen,在编辑选中的那个screen最先启动
    events_init(&guider_ui);
    custom_init(&guider_ui);
gui_guider.c
void setup_ui(lv_ui *ui)
    init_scr_del_flag(ui);
    setup_scr_screen1(ui); //初始化第一个 screen,先设置ui,再执行用户自定义代码
    lv_scr_load(ui->screen1); //加载第一个screen
setup_scr_screenX.c //screenX 初始化
void setup_scr_screenX(lv_ui *ui)
楼主 #1 2024-11-16 12:30:05
memory
已发帖子: 712
Re: NXP GUI Guider 生成代码结构分析
GUI Guider 的 3D 动画是这个软件一帧帧生成的,
widgets_init.c
const lv_img_dsc_t * screen2_image3D_1_imgs[30] = {
    &screen2_image3D_1second_needle_2000,
    &screen2_image3D_1second_needle_2001,
    &screen2_image3D_1second_needle_2002,
    &screen2_image3D_1second_needle_2003,
    &screen2_image3D_1second_needle_2004,
    &screen2_image3D_1second_needle_2005,
    &screen2_image3D_1second_needle_2006,
    &screen2_image3D_1second_needle_2007,
    &screen2_image3D_1second_needle_2008,
    &screen2_image3D_1second_needle_2009,
    &screen2_image3D_1second_needle_2010,
    &screen2_image3D_1second_needle_2011,
    &screen2_image3D_1second_needle_2012,
    &screen2_image3D_1second_needle_2013,
    &screen2_image3D_1second_needle_2014,
    &screen2_image3D_1second_needle_2015,
    &screen2_image3D_1second_needle_2016,
    &screen2_image3D_1second_needle_2017,
    &screen2_image3D_1second_needle_2018,
    &screen2_image3D_1second_needle_2019,
    &screen2_image3D_1second_needle_2020,
    &screen2_image3D_1second_needle_2021,
    &screen2_image3D_1second_needle_2022,
    &screen2_image3D_1second_needle_2023,
    &screen2_image3D_1second_needle_2024,
    &screen2_image3D_1second_needle_2025,
    &screen2_image3D_1second_needle_2026,
    &screen2_image3D_1second_needle_2027,
    &screen2_image3D_1second_needle_2028,
    &screen2_image3D_1second_needle_2029,
楼主 #2 2024-11-16 12:34:09
memory
已发帖子: 712
楼主 #3 2024-11-16 13:02:11
memory
已发帖子: 712
NXP GUI Guider 控件比 squareline 丰富多了!!!
但是 GUI Guider 不能弹性布局,也不能设置对齐方式。
最近编辑记录 memory (2024-11-16 13:07:01)
楼主 #4 2024-11-17 21:43:33
memory
已发帖子: 712
Ubuntu24.04 安装 Gui-Guider-Setup-1.8.1-GA.deb 失败
Ubuntu22.04 安装成功:
sudo apt-get install gconf2 gconf2-common  libsdl2-* libvips42* cmake libappindicator1* libffi* -y
