楼主 # 2025-07-16 15:31:30
yszqb-delta
rp2040正常刷入官方MicroPython固件后无法被电脑设备管理器和thonny识别
仿照微雪tiny,做了一个rp2040的系统。布局重新弄了。正常焊接并检查引脚没有问题后,和微雪tiny一样上电。电脑弹出了大容量USB设备的提示,我把官方uf2固件拖进去后,USB设备消失。正常pico到现在开thonny就能看到py版本,但是我开thonny却看到了:
Couldn't find the device automatically.
Check the connection (making sure the device is not in bootloader mode) or choose
"Configure interpreter" in the interpreter menu (bottom-right corner of the window)
to select specific port or another interpreter.
Process ended with exit code None.
而且设备管理器也没有扫描到rp2040。请问这是什么情况?
