内核版本是6.12.35
内核日志如下:
[ 0.264623] dwmac-sun8i 4500000.ethernet: IRQ eth_wake_irq not found
[ 0.268356] ehci-platform 4200000.usb: irq 36, io mem 0x04200000
[ 0.272992] dwmac-sun8i 4500000.ethernet: IRQ eth_lpi not found
[ 0.273002] dwmac-sun8i 4500000.ethernet: IRQ sfty not found
[ 0.273382] dwmac-sun8i 4500000.ethernet: PTP uses main clock
[ 0.275620] hub 2-0:1.0: 1 port detected
[ 0.281819] dwmac-sun8i 4500000.ethernet: Current syscon value is not the default 58000 (expect 0)
[ 0.303961] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
[ 0.314219] dwmac-sun8i 4500000.ethernet: No HW DMA feature register supported
[ 0.319352] hub 1-0:1.0: USB hub found
[ 0.323451] dwmac-sun8i 4500000.ethernet: RX Checksum Offload Engine supported
[ 0.329956] hub 1-0:1.0: 1 port detected
[ 0.339431] dwmac-sun8i 4500000.ethernet: COE Type 2
[ 0.623933] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 0.629268] dwmac-sun8i 4500000.ethernet: TX Checksum insertion supported
[ 0.815287] hub 1-1:1.0: USB hub found
[ 0.819142] dwmac-sun8i 4500000.ethernet: Normal descriptors
[ 0.827001] hub 1-1:1.0: 4 ports detected
[ 0.835403] dwmac-sun8i 4500000.ethernet: Chain mode enabled
[ 1.263936] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.537277] dwmac-sun8i 4500000.ethernet: EMAC reset timeout
[ 1.542964] dwmac-sun8i 4500000.ethernet eth0: stmmac_dvr_remove: removing driver
[ 1.584892] dwmac-sun8i 4500000.ethernet: probe with driver dwmac-sun8i failed with error -110
设备树配置如下:
&emac {
pinctrl-0 = <&rmii_pg_clk25m_pins>;
pinctrl-names = "default";
phy-mode = "rmii";
phy-handle = <&ip101gr>;
phy-supply = <®_3v3>;
clocks = <&ccu CLK_BUS_EMAC>,<&ccu CLK_EMAC_25M>;
clock-names = "stmmaceth","ephy25m";
use_ephy25m = <1>;
&mdio{
reset-assert-us = <10000>;
reset-post-delay-us = <150000>;
reset-deassert-us = <150000>;
reset-gpios = <&pio 6 6 GPIO_ACTIVE_LOW>; / PG6 /
ip101gr: ethernet-phy@0 {
// compatible = "ethernet-phy-ieee802.3-c22";
// compatible = "ethernet-phy-id001c.c816";
compatible = "ethernet-phy-id0243.0c54","ethernet-phy-ieee802.3-c22";
reg = <0>;
现在的问题是我没办法识别出PHY,而且用示波器去看EPHY-25M引脚也没有时钟输出,问一下主线内核该怎么开启内部时钟输出?
是不是哪里没配置好
防沉,暖个贴,实在不知道这一块的时钟怎么整
可以用FANOUT的25M时钟吗?
困扰了我好久,在网上翻出这个
按照 https://lore.kernel.org/netdev/20230605154010.49611-2-detlev.casanova@collabora.com/T/#u
格式修改对应的phy驱动
然后在phy节点添加 clocks = <&ccu CLK_EMAC_25M>;
参考实现,内核版本 6.12.0
diff --git a/drivers/net/phy/icplus.c b/drivers/net/phy/icplus.c
index a00a667454a9..411ca8fbb30e 100644
--- a/drivers/net/phy/icplus.c
+++ b/drivers/net/phy/icplus.c
@@ -21,6 +21,7 @@
#include <linux/ethtool.h>
#include <linux/phy.h>
#include <linux/property.h>
+#include <linux/clk.h>
#include <asm/io.h>
#include <asm/irq.h>
@@ -89,6 +90,7 @@ static struct ip101g_hw_stat ip101g_hw_stats[] = {
struct ip101a_g_phy_priv {
enum ip101gr_sel_intr32 sel_intr32;
u64 stats[ARRAY_SIZE(ip101g_hw_stats)];
+ struct clk *clk;
static int ip175c_config_init(struct phy_device *phydev)
@@ -210,6 +212,11 @@ static int ip101a_g_probe(struct phy_device *phydev)
if (!priv)
return -ENOMEM;
+ priv->clk = devm_clk_get_optional_enabled(dev, NULL);
+ if (IS_ERR(priv->clk))
+ return dev_err_probe(dev, PTR_ERR(priv->clk),
+ "failed to get phy clock\n");
/* Both functions (RX error and interrupt status) are sharing the same
* pin on the 32-pin IP101GR, so this is an exclusive choice.
@@ -571,6 +578,33 @@ static void ip101g_get_stats(struct phy_device *phydev,
data[i] = ip101g_get_stat(phydev, i);
+static int ip101a_g_suspend(struct phy_device *phydev)
+ struct ip101a_g_phy_priv *priv = phydev->priv;
+ int ret = 0;
+ if (!phydev->wol_enabled) {
+ ret = genphy_suspend(phydev);
+ if (ret)
+ return ret;
+ clk_disable_unprepare(priv->clk);
+ return ret;
+static int ip101a_g_resume(struct phy_device *phydev)
++ clk_prepare_enable(priv->clk);
+ return genphy_resume(phydev);
static struct phy_driver icplus_driver[] = {
PHY_ID_MATCH_MODEL(IP175C_PHY_ID),
@@ -601,8 +635,9 @@ static struct phy_driver icplus_driver[] = {
.config_aneg = ip101a_g_config_aneg,
.read_status = ip101a_g_read_status,
.soft_reset = genphy_soft_reset,
- .suspend = genphy_suspend,
- .resume = genphy_resume,
+ .suspend = ip101a_g_suspend,
+ .resume = ip101a_g_resume,
+ .flags = PHY_ALWAYS_CALL_SUSPEND,
.name = "ICPlus IP101G",
.match_phy_device = ip101g_match_phy_device,
@@ -618,8 +653,9 @@ static struct phy_driver icplus_driver[] = {
.get_sset_count = ip101g_get_sset_count,
.get_strings = ip101g_get_strings,
.get_stats = ip101g_get_stats,
module_phy_driver(icplus_driver);&emac {
pinctrl-0 = <&rmii_pg_pins>;
phy-mode = "rmii";
phy-handle = <&phy1>;
phy-supply = <®_vcc3v3>;
&mdio {
phy1: ethernet-phy@1 {
reg = <1>;
reset-gpios = <&pio 6 6 GPIO_ACTIVE_LOW>; /* PG6 */
reset-assert-us = <5000>;
reset-deassert-us = <5000>;
};离线
@lanb_yy5
还没测试,晚上再试试,先说声谢谢啦
@lanb_yy5
可以提供一下rmii_pg_pins节点的pins吗,我这边内核只有rmii_pe_pins的
最近编辑记录 breaktime1903 (2025-10-17 10:52:37)
rmii_pg_pins: rmii-pg-pins {
pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5",
"PG11", "PG12", "PG13", "PG14", "PG15";
function = "emac";
drive-strength = <10>;
};PG11 和 drive-strength 是改驱动之前调试时写的
其中 PG11 是 25M 时钟引脚
还没测去掉这两项后能否跑通
这是原理图部分,板子是淘宝上的 bingpi_m2
