驱动:
* drivers/input/touchscreen/ft5x0x_ts.c
* FocalTech ft5x TouchScreen driver.
* Copyright (c) 2010 Focal tech Ltd.
* This software is licensed under the terms of the GNU General Public
* License version 2, as published by the Free Software Foundation, and
* may be copied, distributed, and modified under those terms.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* note: only support mulititouch Wenfs 2010-10-01
* for this touchscreen to work, it's slave addr must be set to 0x7e | 0x70
#include <linux/i2c.h>
#include <linux/input.h>
#include "ft5x_ts.h"
#ifdef CONFIG_HAS_EARLYSUSPEND
#include <linux/pm.h>
#include <linux/earlysuspend.h>
#include <linux/interrupt.h>
#include <linux/delay.h>
#include <linux/errno.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/platform_device.h>
#include <linux/async.h>
#include <linux/hrtimer.h>
#include <linux/init.h>
#include <linux/ioport.h>
#include <linux/gpio.h>
#include <asm/irq.h>
#include <linux/io.h>
#include <linux/uaccess.h>
#include "../../init-input.h"
#define CONFIG_SUPPORT_FTS_CTP_UPG
#define FOR_TSLIB_TEST
#ifdef TOUCH_KEY_SUPPORT
#define TOUCH_KEY_FOR_EVB13
#ifdef TOUCH_KEY_FOR_ANGDA
#define TOUCH_KEY_X_LIMIT (60000)
#define TOUCH_KEY_NUMBER (4)
#ifdef TOUCH_KEY_FOR_EVB13
#define TOUCH_KEY_LOWER_X_LIMIT (848)
#define TOUCH_KEY_HIGHER_X_LIMIT (852)
#define TOUCH_KEY_NUMBER (5)
/* FT5X02_CONFIG */
#define FT5X02_CONFIG_NAME "fttpconfig_5x02public.ini"
extern int ft5x02_Init_IC_Param(struct i2c_client *client);
extern int ft5x02_get_ic_param(struct i2c_client *client);
extern int ft5x02_Get_Param_From_Ini(char *config_name);
struct i2c_dev{
struct list_head list;
struct i2c_adapter *adap;
struct device *dev;
static struct class *i2c_dev_class;
static LIST_HEAD (i2c_dev_list);
static DEFINE_SPINLOCK(i2c_dev_list_lock);
struct Upgrade_Info {
u16 delay_aa; /*delay of write FT_UPGRADE_AA */
u16 delay_55; /*delay of write FT_UPGRADE_55 */
u8 upgrade_id_1; /*upgrade id 1 */
u8 upgrade_id_2; /*upgrade id 2 */
u16 delay_readid; /*delay of read id */
#define FT5X_NAME "ft5x_ts"
static struct i2c_client *this_client;
static int key_tp = 0;
static int key_val = 0;
#define CTP_IRQ_NUMBER (config_info.int_number)
#define CTP_IRQ_MODE (IRQF_TRIGGER_LOW | IRQF_ONESHOT)
#define SCREEN_MAX_X (screen_max_x)
#define SCREEN_MAX_Y (screen_max_y)
#define CTP_NAME FT5X_NAME
#define PRESS_MAX (255)
static int screen_max_x = 0;
static int screen_max_y = 0;
static int revert_x_flag = 0;
static int revert_y_flag = 0;
static int exchange_x_y_flag = 0;
static __u32 twi_id = 0;
static struct ctp_config_info config_info = {
.input_type = CTP_TYPE,
.name = NULL,
.int_number = 0,
static u32 debug_mask = 0;
enum{
DEBUG_INIT = 1U << 0,
DEBUG_SUSPEND = 1U << 1,
DEBUG_INT_INFO = 1U << 2,
DEBUG_X_Y_INFO = 1U << 3,
DEBUG_KEY_INFO = 1U << 4,
DEBUG_WAKEUP_INFO = 1U << 5,
DEBUG_OTHERS_INFO = 1U << 6,
#define dprintk(level_mask,fmt,arg...) if(unlikely(debug_mask & level_mask)) \
printk("***CTP***"fmt, ## arg)
module_param_named(debug_mask,debug_mask,int,S_IRUGO | S_IWUSR | S_IWGRP);
/* Addresses to scan */
static const unsigned short normal_i2c[2] = {0x38,I2C_CLIENT_END};
static const int chip_id_value[] = {0x55,0x06,0x08,0x02,0xa3};
static int chip_id = 0;
static void ft5x_resume_events(struct work_struct *work);
struct workqueue_struct *ft5x_resume_wq;
static DECLARE_WORK(ft5x_resume_work, ft5x_resume_events);
static void ft5x_init_events(struct work_struct *work);
struct workqueue_struct *ft5x_wq;
static DECLARE_WORK(ft5x_init_work, ft5x_init_events);
static int ctp_detect(struct i2c_client *client, struct i2c_board_info *info)
struct i2c_adapter *adapter = client->adapter;
int ret = 0;
if (!i2c_check_functionality(adapter, I2C_FUNC_SMBUS_BYTE_DATA))
return -ENODEV;
if(twi_id == adapter->nr){
ret = i2c_smbus_read_byte_data(client,0xA3);
if(ret == -70) {
msleep(10);
dprintk(DEBUG_INIT,"addr:0x%x,chip_id_value:0x%x\n",client->addr,ret);
if(ret < 0){
printk("%s:I2C connection might be something wrong ! \n",__func__);
return -ENODEV;
} else {
strlcpy(info->type, CTP_NAME, I2C_NAME_SIZE);
chip_id = ret;
}else{
return -ENODEV;
* ctp_print_info - sysconfig print function
* return value:
static void ctp_print_info(struct ctp_config_info info,int debug_level)
if(debug_level == DEBUG_INIT)
dprintk(DEBUG_INIT,"info.ctp_used:%d\n",info.ctp_used);
dprintk(DEBUG_INIT,"info.twi_id:%d\n",info.twi_id);
dprintk(DEBUG_INIT,"info.screen_max_x:%d\n",info.screen_max_x);
dprintk(DEBUG_INIT,"info.screen_max_y:%d\n",info.screen_max_y);
dprintk(DEBUG_INIT,"info.revert_x_flag:%d\n",info.revert_x_flag);
dprintk(DEBUG_INIT,"info.revert_y_flag:%d\n",info.revert_y_flag);
dprintk(DEBUG_INIT,"info.exchange_x_y_flag:%d\n",info.exchange_x_y_flag);
dprintk(DEBUG_INIT,"info.irq_gpio_number:%d\n",info.irq_gpio.gpio);
dprintk(DEBUG_INIT,"info.wakeup_gpio_number:%d\n",info.wakeup_gpio.gpio);
* ctp_wakeup - function
static int ctp_wakeup(int status,int ms)
dprintk(DEBUG_INIT,"***CTP*** %s:status:%d,ms = %d\n",__func__,status,ms);
if (status == 0) {
if(ms == 0) {
__gpio_set_value(config_info.wakeup_gpio.gpio, 0);
}else {
msleep(ms);
__gpio_set_value(config_info.wakeup_gpio.gpio, 1);
if (status == 1) {
if(ms == 0) {
}else {
msleep(ms);
msleep(5);
int fts_ctpm_fw_upgrade_with_i_file(void);
static struct i2c_dev *i2c_dev_get_by_minor(unsigned index)
struct i2c_dev *i2c_dev = NULL;
spin_lock(&i2c_dev_list_lock);
list_for_each_entry(i2c_dev,&i2c_dev_list,list){
dprintk(DEBUG_OTHERS_INFO,"--line = %d ,i2c_dev->adapt->nr = %d,index = %d.\n",\
__LINE__,i2c_dev->adap->nr,index);
if(i2c_dev->adap->nr == index){
goto found;
i2c_dev = NULL;
found:
spin_unlock(&i2c_dev_list_lock);
return i2c_dev ;
static struct i2c_dev *get_free_i2c_dev(struct i2c_adapter *adap)
struct i2c_dev *i2c_dev;
if (adap->nr >= I2C_MINORS){
dprintk(DEBUG_OTHERS_INFO,"i2c-dev:out of device minors (%d) \n",adap->nr);
return ERR_PTR (-ENODEV);
i2c_dev = kzalloc(sizeof(*i2c_dev), GFP_KERNEL);
if (!i2c_dev){
return ERR_PTR(-ENOMEM);
i2c_dev->adap = adap;
list_add_tail(&i2c_dev->list, &i2c_dev_list);
return i2c_dev;
static int ft5x_i2c_rxdata(char *rxdata, int length);
struct ts_event {
u16 x1;
u16 y1;
u16 x2;
u16 y2;
u16 x3;
u16 y3;
u16 x4;
u16 y4;
u16 x5;
u16 y5;
u16 pressure;
s16 touch_ID1;
s16 touch_ID2;
s16 touch_ID3;
s16 touch_ID4;
s16 touch_ID5;
u8 touch_point;
struct ft5x_ts_data {
struct input_dev *input_dev;
struct ts_event event;
struct work_struct pen_event_work;
struct workqueue_struct *ts_workqueue;
struct early_suspend early_suspend;
bool is_suspended;
* Focal Touch panel upgrade related driver
typedef enum
ERR_OK,
ERR_MODE,
ERR_READID,
ERR_ERASE,
ERR_STATUS,
ERR_ECC,
ERR_DL_ERASE_FAIL,
ERR_DL_PROGRAM_FAIL,
ERR_DL_VERIFY_FAIL
}E_UPGRADE_ERR_TYPE;
typedef unsigned char FTS_BYTE; //8 bit
typedef unsigned short FTS_WORD; //16 bit
typedef unsigned int FTS_DWRD; //16 bit
typedef unsigned char FTS_BOOL; //8 bit
#define FTS_NULL 0x0
#define FTS_TRUE 0x01
#define FTS_FALSE 0x0
#define I2C_CTPM_ADDRESS (0x3b)
static void delay_ms(FTS_WORD w_ms)
//platform related, please implement this function
msleep( w_ms );
void delay_qt_ms(unsigned long w_ms)
unsigned long i;
unsigned long j;
for (i = 0; i < w_ms; i++)
for (j = 0; j < 1000; j++)
udelay(1);
[function]:
callback: read data from ctpm by i2c interface,implemented by special user;
[parameters]:
bt_ctpm_addr[in] :the address of the ctpm;
pbt_buf[out] :data buffer;
dw_lenth[in] :the length of the data buffer;
[return]:
FTS_TRUE :success;
FTS_FALSE :fail;
int i2c_read_interface(u8 bt_ctpm_addr, u8* pbt_buf, u16 dw_lenth)
int ret;
ret = i2c_master_recv(this_client, pbt_buf, dw_lenth);
if(ret != dw_lenth){
printk("ret = %d. \n", ret);
printk("i2c_read_interface error\n");
return FTS_FALSE;
return FTS_TRUE;
[function]:
callback: write data to ctpm by i2c interface,implemented by special user;
[parameters]:
pbt_buf[in] :data buffer;
[return]:
FTS_TRUE :success;
FTS_FALSE :fail;
int i2c_write_interface(u8 bt_ctpm_addr, u8* pbt_buf, u16 dw_lenth)
int ret;
ret=i2c_master_send(this_client, pbt_buf, dw_lenth);
printk("i2c_write_interface error\n");
return FTS_FALSE;
return FTS_TRUE;
[function]:
read out the register value.
[parameters]:
e_reg_name[in] :register name;
pbt_buf[out] :the returned register value;
bt_len[in] :length of pbt_buf, should be set to 2;
[return]:
FTS_TRUE :success;
FTS_FALSE :io fail;
u8 fts_register_read(u8 e_reg_name, u8* pbt_buf, u8 bt_len)
u8 read_cmd[3]= {0};
u8 cmd_len = 0;
read_cmd[0] = e_reg_name;
cmd_len = 1;
/*call the write callback function*/
// if(!i2c_write_interface(I2C_CTPM_ADDRESS, &read_cmd, cmd_len))
// return FTS_FALSE;
if(!i2c_write_interface(I2C_CTPM_ADDRESS, read_cmd, cmd_len)) {//change by zhengdixu
return FTS_FALSE;
/*call the read callback function to get the register value*/
if(!i2c_read_interface(I2C_CTPM_ADDRESS, pbt_buf, bt_len)){
return FTS_FALSE;
return FTS_TRUE;
[function]:
write a value to register.
[parameters]:
pbt_buf[in] :the returned register value;
[return]:
FTS_TRUE :success;
FTS_FALSE :io fail;
int fts_register_write(u8 e_reg_name, u8 bt_value)
FTS_BYTE write_cmd[2] = {0};
write_cmd[0] = e_reg_name;
write_cmd[1] = bt_value;
//return i2c_write_interface(I2C_CTPM_ADDRESS, &write_cmd, 2);
return i2c_write_interface(I2C_CTPM_ADDRESS, write_cmd, 2); //change by zhengdixu
[function]:
send a command to ctpm.
[parameters]:
btcmd[in] :command code;
btPara1[in] :parameter 1;
btPara2[in] :parameter 2;
btPara3[in] :parameter 3;
num[in] :the valid input parameter numbers, if only command code needed and no parameters followed,then the num is 1;
[return]:
FTS_TRUE :success;
FTS_FALSE :io fail;
int cmd_write(u8 btcmd,u8 btPara1,u8 btPara2,u8 btPara3,u8 num)
FTS_BYTE write_cmd[4] = {0};
write_cmd[0] = btcmd;
write_cmd[1] = btPara1;
write_cmd[2] = btPara2;
write_cmd[3] = btPara3;
//return i2c_write_interface(I2C_CTPM_ADDRESS, &write_cmd, num);
return i2c_write_interface(I2C_CTPM_ADDRESS, write_cmd, num);//change by zhengdixu
[function]:
write data to ctpm , the destination address is 0.
[parameters]:
pbt_buf[in] :point to data buffer;
bt_len[in] :the data numbers;
[return]:
FTS_TRUE :success;
FTS_FALSE :io fail;
int byte_write(u8* pbt_buf, u16 dw_len)
return i2c_write_interface(I2C_CTPM_ADDRESS, pbt_buf, dw_len);
[function]:
read out data from ctpm,the destination address is 0.
[parameters]:
pbt_buf[out] :point to data buffer;
[return]:
FTS_TRUE :success;
FTS_FALSE :io fail;
int byte_read(u8* pbt_buf, u8 bt_len)
return i2c_read_interface(I2C_CTPM_ADDRESS, pbt_buf, bt_len);
//ft5x_i2c_rxdata
[function]:
burn the FW to ctpm.
[parameters]:(ref. SPEC)
pbt_buf[in] :point to Head+FW ;
dw_lenth[in]:the length of the FW + 6(the Head length);
bt_ecc[in] :the ECC of the FW
[return]:
ERR_OK :no error;
ERR_MODE :fail to switch to UPDATE mode;
ERR_READID :read id fail;
ERR_ERASE :erase chip fail;
ERR_STATUS :status error;
ERR_ECC :ecc error.
#define FTS_PACKET_LENGTH 128 //2//4//8//16//32//64//128//256
static unsigned char CTPM_FW[]=
#include "ft_app.i"
unsigned char fts_ctpm_get_i_file_ver(void)
unsigned int ui_sz;
ui_sz = sizeof(CTPM_FW);
if (ui_sz > 2){
return CTPM_FW[ui_sz - 2];
}else{
//TBD, error handling?
return 0xff; //default value
*get upgrade information depend on the ic type
static void fts_get_upgrade_info(struct Upgrade_Info *upgrade_info)
#ifdef WILLIAM_DEBUG
printk("####ft5x chip_id=%d####\n", chip_id);
switch (chip_id) {
case 0x55: //IC_FT5X06:
upgrade_info->delay_55 = FT5X06_UPGRADE_55_DELAY;
upgrade_info->delay_aa = FT5X06_UPGRADE_AA_DELAY;
upgrade_info->upgrade_id_1 = FT5X06_UPGRADE_ID_1;
upgrade_info->upgrade_id_2 = FT5X06_UPGRADE_ID_2;
upgrade_info->delay_readid = FT5X06_UPGRADE_READID_DELAY;
break;
case 0x08: //IC_FT5606IC_FT5506
upgrade_info->delay_55 = FT5606_UPGRADE_55_DELAY;
upgrade_info->delay_aa = FT5606_UPGRADE_AA_DELAY;
upgrade_info->upgrade_id_1 = FT5606_UPGRADE_ID_1;
upgrade_info->upgrade_id_2 = FT5606_UPGRADE_ID_2;
upgrade_info->delay_readid = FT5606_UPGRADE_READID_DELAY;
break;
case 0x00: //IC FT5316
case 0x0a: //IC FT5316
upgrade_info->delay_55 = FT5316_UPGRADE_55_DELAY;
upgrade_info->delay_aa = FT5316_UPGRADE_AA_DELAY;
upgrade_info->upgrade_id_1 = FT5316_UPGRADE_ID_1;
upgrade_info->upgrade_id_2 = FT5316_UPGRADE_ID_2;
upgrade_info->delay_readid = FT5316_UPGRADE_READID_DELAY;
break;
default:
break;
E_UPGRADE_ERR_TYPE ft5x06_ctpm_fw_upgrade(u8* pbt_buf, u16 dw_lenth)
u8 reg_val[2] = {0};
FTS_BOOL i_ret = 0;
u16 i = 0;
u16 packet_number;
u16 j;
u16 temp;
u16 lenght;
u8 packet_buf[FTS_PACKET_LENGTH + 6];
//u8 auc_i2c_write_buf[10];
u8 bt_ecc;
struct Upgrade_Info upgradeinfo = {0, 0, 0, 0 , 0};
fts_get_upgrade_info(&upgradeinfo);
/*********Step 1:Reset CTPM *****/
/*write 0xaa to register 0xfc*/
//delay_ms(100);//µԴȥʱ
fts_register_write(0xfc,0xaa);
delay_ms(upgradeinfo.delay_aa);
/*write 0x55 to register 0xfc*/
fts_register_write(0xfc,0x55);
printk("Step 1: Reset CTPM test\n");
delay_ms(upgradeinfo.delay_55);
/*********Step 2:Enter upgrade mode *****/
//auc_i2c_write_buf[0] = 0x55;
//auc_i2c_write_buf[1] = 0xaa;
i = 0;
do{
i++;
//i_ret = i2c_write_interface(I2C_CTPM_ADDRESS, auc_i2c_write_buf, 2);
cmd_write(0x55,0xaa,0x00,0x00,2);
printk("Step 2: Enter update mode. \n");
delay_ms(5);
}while((FTS_FALSE == i_ret) && i<5);
/*********Step 3:check READ-ID***********************/
/*send the opration head*/
msleep(upgradeinfo.delay_readid);
cmd_write(0x90,0x00,0x00,0x00,4);
byte_read(reg_val,2);
if (reg_val[0] == upgradeinfo.upgrade_id_1&& reg_val[1] == upgradeinfo.upgrade_id_2) {
printk("Step 3: CTPM ID,ID1 = 0x%x,ID2 = 0x%x\n",reg_val[0],reg_val[1]);
else {
return ERR_READID;
cmd_write(0xcd,0x00,0x00,0x00,1);
byte_read(reg_val,1);
/*Step 4:erase app and panel paramenter area*/
cmd_write(0x61,0x00,0x00,0x00,1);
msleep(2000);
cmd_write(0x63,0x00,0x00,0x00,1);
msleep(100);
printk("Step 4: erase. \n");
/*********Step 5:write firmware(FW) to ctpm flash*********/
bt_ecc = 0;
printk("Step 5: start upgrade. \n");
dw_lenth = dw_lenth - 8;
packet_number = (dw_lenth) / FTS_PACKET_LENGTH;
packet_buf[0] = 0xbf;
packet_buf[1] = 0x00;
for (j=0;j<packet_number;j++){
temp = j * FTS_PACKET_LENGTH;
packet_buf[2] = (FTS_BYTE)(temp>>8);
packet_buf[3] = (FTS_BYTE)temp;
lenght = FTS_PACKET_LENGTH;
packet_buf[4] = (FTS_BYTE)(lenght>>8);
packet_buf[5] = (FTS_BYTE)lenght;
for (i=0;i<FTS_PACKET_LENGTH;i++){
packet_buf[6+i] = pbt_buf[j*FTS_PACKET_LENGTH + i];
bt_ecc ^= packet_buf[6+i];
byte_write(&packet_buf[0],FTS_PACKET_LENGTH + 6);
//delay_ms(FTS_PACKET_LENGTH/6 + 1);
msleep(FTS_PACKET_LENGTH/6 + 1);
if ((j * FTS_PACKET_LENGTH % 1024) == 0){
printk("upgrade the 0x%x th byte.\n", ((unsigned int)j) * FTS_PACKET_LENGTH);
if ((dw_lenth) % FTS_PACKET_LENGTH > 0){
temp = packet_number * FTS_PACKET_LENGTH;
temp = (dw_lenth) % FTS_PACKET_LENGTH;
packet_buf[4] = (FTS_BYTE)(temp>>8);
packet_buf[5] = (FTS_BYTE)temp;
for (i=0;i<temp;i++){
packet_buf[6+i] = pbt_buf[ packet_number*FTS_PACKET_LENGTH + i];
byte_write(&packet_buf[0],temp+6);
//delay_ms(20);
msleep(20);
//send the last six byte
for (i = 0; i<6; i++){
temp = 0x6ffa + i;
temp =1;
packet_buf[6] = pbt_buf[ dw_lenth + i];
bt_ecc ^= packet_buf[6];
byte_write(&packet_buf[0],7);
//delay_ms(20);
msleep(20);
/*********Step 6: read out checksum***********************/
//cmd_write(0xcc,0x00,0x00,0x00,1);//0xccĴַȥһֽ
// byte_read(reg_val,1);//change by zhengdixu
fts_register_read(0xcc, reg_val,1);
printk("Step 6: ecc read 0x%x, new firmware 0x%x. \n", reg_val[0], bt_ecc);
if(reg_val[0] != bt_ecc){
//cmd_write(0x07,0x00,0x00,0x00,1);
printk("ecc error! \n");
return ERR_ECC;
/*********Step 7: reset the new FW***********************/
msleep(300);
return ERR_OK;
E_UPGRADE_ERR_TYPE ft5x02_ctpm_fw_upgrade(u8* pbt_buf, u32 dw_lenth)
u32 i = 0;
u32 packet_number;
u32 j;
u32 temp;
u32 lenght;
u8 bt_ecc;
//struct timeval begin_tv, end_tv;
//do_gettimeofday(&begin_tv);
for (i=0; i<16; i++) {
msleep(30);
//delay_qt_ms(18);
delay_qt_ms(25);
#if 0
do
i ++;
//i_ret = ft5x02_i2c_Write(client, auc_i2c_write_buf, 2);
delay_qt_ms(5);
}while(i_ret <= 0 && i < 5 );
#else
//ft5x02_i2c_Write(client, auc_i2c_write_buf, 1);
cmd_write(0x55,0x00,0x00,0x00,1);
delay_qt_ms(1);
//auc_i2c_write_buf[0] = 0xaa;
cmd_write(0xaa,0x00,0x00,0x00,1);
delay_qt_ms(1);
//ft5x02_upgrade_send_head(client);
cmd_write(0xFA,0xFA,0x00,0x00,2);//ft5x02_upgrade_send_head
//auc_i2c_write_buf[0] = 0x90;
//auc_i2c_write_buf[1] = auc_i2c_write_buf[2] = auc_i2c_write_buf[3] = 0x00;
//ft5x02_i2c_Read(client, auc_i2c_write_buf, 4, reg_val, 2);
if (reg_val[0] == 0x79
&& reg_val[1] == 0x02) {
//dev_dbg(&client->dev, "[FTS] Step 3: CTPM ID,ID1 = 0x%x,ID2 = 0x%x\n",reg_val[0],reg_val[1]);
printk("[FTS] Step 3: CTPM ID,ID1 = 0x%x,ID2 = 0x%x\n",reg_val[0],reg_val[1]);
break;
} else {
printk("[FTS] Step 3 ERROR: CTPM ID,ID1 = 0x%x,ID2 = 0x%x\n",reg_val[0],reg_val[1]);
//delay_qt_ms(1);
if (i >= 6)
return ERR_READID;
/********Step 4:enable write function*/
//auc_i2c_write_buf[0] = 0x06;
cmd_write(0x06,0x00,0x00,0x00,1);
bt_ecc = 0;
for (j=0; j<packet_number; j++) {
packet_buf[2] = (u8)(temp>>8);
packet_buf[3] = (u8)temp;
packet_buf[4] = (u8)(lenght>>8);
packet_buf[5] = (u8)lenght;
if(temp>=0x4c00 && temp <(0x4c00+512))
continue;
for (i=0; i<FTS_PACKET_LENGTH; i++) {
//ft5x02_i2c_Write(client, packet_buf, FTS_PACKET_LENGTH+6);
delay_qt_ms(2);
if ((dw_lenth) % FTS_PACKET_LENGTH > 0) {
packet_buf[4] = (u8)(temp>>8);
packet_buf[5] = (u8)temp;
for (i=0; i<temp; i++) {
//ft5x02_i2c_Write(client, packet_buf, temp+6);
byte_write(&packet_buf[0],temp + 6);
delay_qt_ms(2);
/********Disable write function*/
//auc_i2c_write_buf[0] = 0x04;
cmd_write(0x04,0x00,0x00,0x00,1);
delay_qt_ms(1);
//auc_i2c_write_buf[0] = 0xcc;
//ft5x02_i2c_Read(client, auc_i2c_write_buf, 1, reg_val, 1);
if (reg_val[0] != bt_ecc) {
printk("[FTS]--ecc error! FW=%02x bt_ecc=%02x\n", reg_val[0], bt_ecc);
//return -EIO;
return ERR_READID;
//auc_i2c_write_buf[0] = 0x07;
msleep(200); /*make sure CTP startup normally*/
//DBG("-------upgrade successful-----\n");
//do_gettimeofday(&end_tv);
//DBG("cost time=%lu.%lu\n", end_tv.tv_sec-begin_tv.tv_sec,
// end_tv.tv_usec-begin_tv.tv_usec);
return ERR_OK;
int fts_ctpm_auto_clb(void)
unsigned char uc_temp;
unsigned char i ;
printk("[FTS] start auto CLB.\n");
msleep(200);
fts_register_write(0, 0x40);
//delay_ms(100); //make sure already enter factory mode
msleep(100);
fts_register_write(2, 0x4); //write command to start calibration
//delay_ms(300);
msleep(300);
for(i=0;i<100;i++){
fts_register_read(0,&uc_temp,1);
if (((uc_temp&0x70)>>4) == 0x0){ //return to normal mode, calibration finish
break;
//delay_ms(200);
msleep(200);
printk("[FTS] waiting calibration %d\n",i);
printk("[FTS] calibration OK.\n");
msleep(300);
fts_register_write(0, 0x40); //goto factory mode
fts_register_write(2, 0x5); //store CLB result
delay_ms(300);
fts_register_write(0, 0x0); //return to normal mode
msleep(300);
printk("[FTS] store CLB result OK.\n");
void getVerNo(u8* buf, int len)
u8 start_reg=0x0;
int ret = -1;
//int status = 0;
int i = 0;
start_reg = 0xa6;
(void)i;
#if 0
printk("read 0xa6 one time. \n");
if(FTS_FALSE == fts_register_read(0xa6, buf, len)){
return ;
for (i=0; i< len; i++) {
printk("=========buf[%d] = 0x%x \n", i, buf);
printk("read 0xa8. \n");
if(FTS_FALSE == fts_register_read(0xa8, buf, len)){
return ;
ft5x_i2c_rxdata(buf, len);
byte_read(buf, len);
ret =fts_register_read(0xa6, buf, len);
//et = ft5406_read_regs(ft5x0x_ts_data_test->client,start_reg, buf, 2);
if (ret < 0) {
printk("%s read_data i2c_rxdata failed: %d\n", __func__, ret);
return;
#if 0
for (i=0; i<2; i++) {
return;
FTS_BYTE* pbt_buf = FTS_NULL;
int i_ret = 0;
unsigned char a;
unsigned char b;
#define BUFFER_LEN (2) //len == 2
unsigned char buf[BUFFER_LEN] = {0};
//=========FW upgrade========================*/
printk("%s. \n", __func__);
pbt_buf = CTPM_FW;
//msleep(200);
// cmd_write(0x07,0x00,0x00,0x00,1);
msleep(100);
getVerNo(buf, BUFFER_LEN);
a = buf[0];
b = fts_ctpm_get_i_file_ver();
/* printk("a == %hu, b== %hu \n",a, b);*/
* when the firmware in touch panel maybe corrupted,
* or the firmware in host flash is new, need upgrade
if ( 0xa6 == a || a != b ){
/*call the upgrade function*/
if(chip_id == 0x55 || chip_id == 0x08 || chip_id == 0x00 || chip_id == 0x0a){
i_ret = ft5x06_ctpm_fw_upgrade(&pbt_buf[0],sizeof(CTPM_FW));
if (i_ret != 0){
printk("[FTS] upgrade failed i_ret = %d.\n", i_ret);
else {
printk("[FTS] upgrade successfully.\n");
#ifdef AUTO_CLB
fts_ctpm_auto_clb(); //start auto CLB
return i_ret;
unsigned char fts_ctpm_get_upg_ver(void)
unsigned int ui_sz;
if (ui_sz > 2){
return CTPM_FW[0];
else{
int ret;
struct i2c_msg msgs[] = {
.addr = this_client->addr,
.flags = 0,
.len = 1,
.buf = rxdata,
.flags = I2C_M_RD,
.len = length,
.buf = rxdata,
ret = i2c_transfer(this_client->adapter, msgs, 2);
if (ret < 0)
printk("msg %s i2c read error: %d\n", __func__, ret);
return ret;
static int ft5x_i2c_txdata(char *txdata, int length)
int ret;
struct i2c_msg msg[] = {
.flags = 0,
.len = length,
.buf = txdata,
//msleep(1);
ret = i2c_transfer(this_client->adapter, msg, 1);
if (ret < 0)
pr_err("%s i2c write error: %d\n", __func__, ret);
return ret;
static int ft5x_set_reg(u8 addr, u8 para)
u8 buf[3];
int ret = -1;
buf[0] = addr;
buf[1] = para;
ret = ft5x_i2c_txdata(buf, 2);
if (ret < 0) {
pr_err("write reg failed! %#x ret: %d", buf[0], ret);
return -1;
static void ft5x_ts_release(void)
struct ft5x_ts_data *data = i2c_get_clientdata(this_client);
#ifdef CONFIG_FT5X0X_MULTITOUCH
if(1 == key_tp){
input_report_key(data->input_dev, key_val, 0);
dprintk(DEBUG_KEY_INFO,"Release Key = %d\n",key_val);
} else{
input_report_abs(data->input_dev, ABS_MT_TOUCH_MAJOR, 0);
#else
input_report_abs(data->input_dev, ABS_MT_WIDTH_MAJOR, 0);
input_report_key(data->input_dev, BTN_TOUCH, 0);
#else
input_report_abs(data->input_dev, ABS_PRESSURE, 0);
input_sync(data->input_dev);
return;
static int ft5x_read_data(void)
struct ts_event *event = &data->event;
unsigned char buf[32]={0};
int ret = -1;
ret = ft5x_i2c_rxdata(buf, 31);
#else
if (ret < 0) {
dprintk(DEBUG_X_Y_INFO,"%s read_data i2c_rxdata failed: %d\n", __func__, ret);
return ret;
memset(event, 0, sizeof(struct ts_event));
event->touch_point = buf[2] & 0x07;// 000 0111
dprintk(DEBUG_X_Y_INFO,"touch point = %d\n",event->touch_point);
if (event->touch_point == 0) {
ft5x_ts_release();
return 1;
switch (event->touch_point) {
case 5:
event->x5 = (s16)(buf[0x1b] & 0x0F)<<8 | (s16)buf[0x1c];
event->y5 = (s16)(buf[0x1d] & 0x0F)<<8 | (s16)buf[0x1e];
dprintk(DEBUG_X_Y_INFO,"source data:event->x5 = %d, event->y5 = %d. \n", event->x5, event->y5);
if(1 == exchange_x_y_flag){
swap(event->x5, event->y5);
if(1 == revert_x_flag){
event->x5 = SCREEN_MAX_X - event->x5;
if(1 == revert_y_flag){
event->y5 = SCREEN_MAX_Y - event->y5;
event->touch_ID5=(s16)(buf[0x1d] & 0xF0)>>4;
dprintk(DEBUG_X_Y_INFO,"touch id : %d. \n",event->touch_ID5);
case 4:
event->x4 = (s16)(buf[0x15] & 0x0F)<<8 | (s16)buf[0x16];
event->y4 = (s16)(buf[0x17] & 0x0F)<<8 | (s16)buf[0x18];
dprintk(DEBUG_X_Y_INFO,"source data:event->x4 = %d, event->y4 = %d. \n", event->x4, event->y4);
swap(event->x4, event->y4);
event->x4 = SCREEN_MAX_X - event->x4;
event->y4 = SCREEN_MAX_Y - event->y4;
event->touch_ID4=(s16)(buf[0x17] & 0xF0)>>4;
dprintk(DEBUG_X_Y_INFO,"touch id : %d. \n",event->touch_ID4);
case 3:
event->x3 = (s16)(buf[0x0f] & 0x0F)<<8 | (s16)buf[0x10];
event->y3 = (s16)(buf[0x11] & 0x0F)<<8 | (s16)buf[0x12];
dprintk(DEBUG_X_Y_INFO,"source data:event->x3 = %d, event->y3 = %d. \n", event->x3, event->y3);
swap(event->x3, event->y3);
event->x3 = SCREEN_MAX_X - event->x3;
event->y3 = SCREEN_MAX_Y - event->y3;
event->touch_ID3=(s16)(buf[0x11] & 0xF0)>>4;
dprintk(DEBUG_X_Y_INFO,"touch id : %d. \n",event->touch_ID3);
case 2:
event->x2 = (s16)(buf[9] & 0x0F)<<8 | (s16)buf[10];
event->y2 = (s16)(buf[11] & 0x0F)<<8 | (s16)buf[12];
dprintk(DEBUG_X_Y_INFO,"source data:event->x2 = %d, event->y2 = %d. \n", event->x2, event->y2);
swap(event->x2, event->y2);
event->x2 = SCREEN_MAX_X - event->x2;
event->y2 = SCREEN_MAX_Y - event->y2;
event->touch_ID2=(s16)(buf[0x0b] & 0xF0)>>4;
dprintk(DEBUG_X_Y_INFO,"touch id : %d. \n",event->touch_ID2);
case 1:
event->x1 = (s16)(buf[3] & 0x0F)<<8 | (s16)buf[4];
event->y1 = (s16)(buf[5] & 0x0F)<<8 | (s16)buf[6];
dprintk(DEBUG_X_Y_INFO,"source data:event->x1 = %d, event->y1 = %d. \n", event->x1, event->y1);
swap(event->x1, event->y1);
event->x1 = SCREEN_MAX_X - event->x1;
event->y1 = SCREEN_MAX_Y - event->y1;
event->touch_ID1=(s16)(buf[0x05] & 0xF0)>>4;
dprintk(DEBUG_X_Y_INFO,"touch id : %d. \n",event->touch_ID1);
break;
default:
return -1;
event->pressure = 20;
#ifdef TOUCH_KEY_LIGHT_SUPPORT
static void ft5x_lighting(void)
ctp_key_light(1,15);
return;
static void ft5x_report_multitouch(void)
printk("####%s####\n", __func__);
if(1 == key_tp){
return;
if (event->touch_point)
input_report_key(data->input_dev, BTN_TOUCH, 1);
switch(event->touch_point) {
case 5:
input_report_abs(data->input_dev, ABS_MT_TRACKING_ID, event->touch_ID5);
input_report_abs(data->input_dev, ABS_MT_TOUCH_MAJOR, event->pressure);
input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->x5);
input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->y5);
input_report_abs(data->input_dev, ABS_MT_WIDTH_MAJOR, 30);
input_mt_sync(data->input_dev);
dprintk(DEBUG_X_Y_INFO,"report data:===x5 = %d,y5 = %d ====\n",event->x5,event->y5);
case 4:
input_report_abs(data->input_dev, ABS_MT_TRACKING_ID, event->touch_ID4);
input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->x4);
input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->y4);
dprintk(DEBUG_X_Y_INFO,"report data:===x4 = %d,y4 = %d ====\n",event->x4,event->y4);
case 3:
input_report_abs(data->input_dev, ABS_MT_TRACKING_ID, event->touch_ID3);
input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->x3);
input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->y3);
dprintk(DEBUG_X_Y_INFO,"report data:===x3 = %d,y3 = %d ====\n",event->x3,event->y3);
case 2:
input_report_abs(data->input_dev, ABS_MT_TRACKING_ID, event->touch_ID2);
input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->x2);
input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->y2);
dprintk(DEBUG_X_Y_INFO,"report data:===x2 = %d,y2 = %d ====\n",event->x2,event->y2);
case 1:
input_report_abs(data->input_dev, ABS_MT_TRACKING_ID, event->touch_ID1);
input_report_abs(data->input_dev, ABS_MT_POSITION_X, event->x1);
input_report_abs(data->input_dev, ABS_MT_POSITION_Y, event->y1);
dprintk(DEBUG_X_Y_INFO,"report data:===x1 = %d,y1 = %d ====\n",event->x1,event->y1);
break;
default:
dprintk(DEBUG_X_Y_INFO,"report data:==touch_point default =\n");
break;
return;
#ifndef CONFIG_FT5X0X_MULTITOUCH
static void ft5x_report_singletouch(void)
if (event->touch_point == 1) {
input_report_abs(data->input_dev, ABS_PRESSURE, event->pressure);
dprintk(DEBUG_X_Y_INFO,"report:===x1 = %d,y1 = %d ====\n",event->x1,event->y1);
return;
static void ft5x_report_touchkey(void)
if((1==event->touch_point)&&(event->x1 > TOUCH_KEY_X_LIMIT)){
key_tp = 1;
if(event->y1 < 40){
key_val = 1;
input_report_key(data->input_dev, key_val, 1);
dprintk(DEBUG_KEY_INFO,"===KEY 1====\n");
}else if(event->y1 < 90){
key_val = 2;
dprintk(DEBUG_KEY_INFO,"===KEY 2 ====\n");
}else{
key_val = 3;
dprintk(DEBUG_KEY_INFO,"===KEY 3====\n");
} else{
key_tp = 0;
if((1==event->touch_point)&&((event->x1 > TOUCH_KEY_LOWER_X_LIMIT)&&(event->x1<TOUCH_KEY_HIGHER_X_LIMIT))){
key_tp = 1;
if(event->y1 < 5){
key_val = 1;
}else if((event->y1 < 45)&&(event->y1>35)){
key_val = 2;
}else if((event->y1 < 75)&&(event->y1>65)){
key_val = 3;
}else if ((event->y1 < 105)&&(event->y1>95)) {
key_val = 4;
dprintk(DEBUG_KEY_INFO,"===KEY 4====\n");
}else{
key_tp = 0;
ft5x_lighting();
return;
static void ft5x_report_value(void)
ft5x_report_touchkey();
ft5x_report_multitouch();
#else /* CONFIG_FT5X0X_MULTITOUCH*/
ft5x_report_singletouch();
#endif /* CONFIG_FT5X0X_MULTITOUCH*/
return;
static void ft5x_ts_pen_irq_work(struct work_struct *work)
int ret = -1;
ret = ft5x_read_data();
if (ret == 0) {
ft5x_report_value();
dprintk(DEBUG_INT_INFO,"%s:ret:%d\n",__func__,ret);
irqreturn_t ft5x_ts_interrupt(int irq, void *dev_id)
struct ft5x_ts_data *ft5x_ts = (struct ft5x_ts_data *)dev_id;
dprintk(DEBUG_INT_INFO,"==========ft5x_ts TS Interrupt============\n");
queue_work(ft5x_ts->ts_workqueue, &ft5x_ts->pen_event_work);
return IRQ_HANDLED;
static void ft5x_resume_events (struct work_struct *work)
int i = 0;
int ret = 0;
ctp_wakeup(0, 20);
if(STANDBY_WITH_POWER_OFF != standby_level){
goto standby_with_power_on;
if(chip_id == 0x02 ){
#ifdef FT5X02_CONFIG_INI
if (ft5x02_Get_Param_From_Ini(FT5X02_CONFIG_NAME) >= 0)
ft5x02_Init_IC_Param(this_client);
printk("Get ft5x02 param from INI file failed\n");
#else
msleep(200); /*wait...*/
while(i<5){
dprintk(DEBUG_INIT,"-----------------------------------------Init ic param\r\n");
if (ft5x02_Init_IC_Param(this_client) >=0 ){
dprintk(DEBUG_INIT,"---------------------------------------get ic param\r\n");
if(ft5x02_get_ic_param(this_client) >=0)
break;
i++;
standby_with_power_on:
ret = input_set_int_enable(&(config_info.input_type), 1);
if (ret < 0)
dprintk(DEBUG_SUSPEND,"%s irq disable failed\n", __func__);
static int ft5x_ts_suspend(struct device *dev, pm_message_t mesg)
struct i2c_client *client = to_i2c_client(dev);
struct ft5x_ts_data *data = i2c_get_clientdata(client);
int ret = 0;
dprintk(DEBUG_SUSPEND,"==ft5x_ts_suspend=\n");
dprintk(DEBUG_SUSPEND,"CONFIG_PM: write FT5X0X_REG_PMODE .\n");
#ifndef CONFIG_HAS_EARLYSUSPEND
data->is_suspended = true;
if (data->is_suspended == true) {
//ft5x_ts_release();
flush_workqueue(ft5x_resume_wq);
ret = input_set_int_enable(&(config_info.input_type), 0);
if (ret < 0)
cancel_work_sync(&data->pen_event_work);
flush_workqueue(data->ts_workqueue);
ft5x_set_reg(FT5X0X_REG_PMODE, PMODE_HIBERNATE);
msleep(5);
input_set_power_enable(&(config_info.input_type), 0);
static int ft5x_ts_resume(struct device *dev)
dprintk(DEBUG_SUSPEND,"==CONFIG_PM:ft5x_ts_resume== \n");
input_set_power_enable(&(config_info.input_type), 1);
msleep(5);
queue_work(ft5x_resume_wq, &ft5x_resume_work);
static void ft5x_ts_early_suspend(struct early_suspend *handler)
int ret = 0;
dprintk(DEBUG_SUSPEND,"CONFIG_HAS_EARLYSUSPEND: write FT5X0X_REG_PMODE .\n");
ft5x_ts_release();
data->is_suspended = false;
if (ret < 0)
msleep(5);
static void ft5x_ts_late_resume(struct early_suspend *handler)
struct ft5x_ts_data *data = container_of(handler, struct ft5x_ts_data, early_suspend);
dprintk(DEBUG_SUSPEND,"==CONFIG_HAS_EARLYSUSPEND:ft5x_ts_resume== \n");
if (data->is_suspended == false) {
msleep(5);
printk("ts->is_suspended:%d\n",data->is_suspended);
static void ft5x_init_events (struct work_struct *work)
int i = 0;
int ret;
dprintk(DEBUG_INIT,"====%s begin=====. \n", __func__);
while((chip_id == 0x00) || (chip_id == 0xa3)){
delay_ms(5);
ret = i2c_smbus_read_byte_data(this_client,0xA3);
dprintk(DEBUG_INIT,"addr:0x%x,chip_id_value:0x%x\n",this_client->addr,ret);
if((ret != 0x00) && (ret != 0xa3)) {
chip_id = ret;
break;
if((i++)>10) {
break;
dprintk(DEBUG_INIT,"read chip_id timers,timers=%d\n",i);
i = 0;
#ifdef CONFIG_SUPPORT_FTS_CTP_UPG
fts_ctpm_fw_upgrade_with_i_file();
#else
msleep(1000); /*wait...*/
while(i<5){
break;
i++;
static int ft5x_ts_probe(struct i2c_client *client, const struct i2c_device_id *id)
printk("==ft5x_ts_probe==\n");
struct ft5x_ts_data *ft5x_ts;
struct device *dev;
int err = 0;
int i = 0;
if (!i2c_check_functionality(client->adapter, I2C_FUNC_I2C)) {
err = -ENODEV;
printk("check_functionality_failed\n");
goto exit_check_functionality_failed;
ft5x_ts = kzalloc(sizeof(*ft5x_ts), GFP_KERNEL);
if (!ft5x_ts) {
err = -ENOMEM;
printk("alloc_data_failed\n");
goto exit_alloc_data_failed;
this_client = client;
i2c_set_clientdata(client, ft5x_ts);
ft5x_wq = create_singlethread_workqueue("ft5x_init");
if (ft5x_wq == NULL) {
printk("create ft5x_wq fail!\n");
return -ENOMEM;
queue_work(ft5x_wq, &ft5x_init_work);
INIT_WORK(&ft5x_ts->pen_event_work, ft5x_ts_pen_irq_work);
ft5x_ts->ts_workqueue = create_singlethread_workqueue(dev_name(&client->dev));
if (!ft5x_ts->ts_workqueue) {
err = -ESRCH;
printk("ts_workqueue fail!\n");
goto exit_create_singlethread;
input_dev = input_allocate_device();
if (!input_dev) {
err = -ENOMEM;
dev_err(&client->dev, "failed to allocate input device\n");
goto exit_input_dev_alloc_failed;
ft5x_ts->input_dev = input_dev;
set_bit(ABS_MT_TOUCH_MAJOR, input_dev->absbit);
set_bit(ABS_MT_POSITION_X, input_dev->absbit);
set_bit(ABS_MT_POSITION_Y, input_dev->absbit);
set_bit(ABS_MT_WIDTH_MAJOR, input_dev->absbit);
#ifdef FOR_TSLIB_TEST
set_bit(BTN_TOUCH, input_dev->keybit);
input_set_abs_params(input_dev,
ABS_MT_POSITION_X, 0, SCREEN_MAX_X, 0, 0);
ABS_MT_POSITION_Y, 0, SCREEN_MAX_Y, 0, 0);
ABS_MT_TOUCH_MAJOR, 0, PRESS_MAX, 0, 0);
ABS_MT_WIDTH_MAJOR, 0, 200, 0, 0);
ABS_MT_TRACKING_ID, 0, 4, 0, 0);
key_tp = 0;
input_dev->evbit[0] = BIT_MASK(EV_KEY);
for (i = 1; i < TOUCH_KEY_NUMBER; i++)
set_bit(i, input_dev->keybit);
#else
set_bit(ABS_PRESSURE, input_dev->absbit);
input_set_abs_params(input_dev, ABS_MT_POSITION_X, 0, SCREEN_MAX_X, 0, 0);
input_set_abs_params(input_dev, ABS_MT_POSITION_Y, 0, SCREEN_MAX_Y, 0, 0);
ABS_PRESSURE, 0, PRESS_MAX, 0 , 0);
set_bit(EV_ABS, input_dev->evbit);
set_bit(EV_KEY, input_dev->evbit);
set_bit(INPUT_PROP_DIRECT, input_dev->propbit);
input_dev->name = CTP_NAME; //dev_name(&client->dev)
err = input_register_device(input_dev);
if (err) {
dev_err(&client->dev,"ft5x_ts_probe: failed to register input device: %s\n",
goto exit_input_register_device_failed;
ft5x_ts->is_suspended = false;
ft5x_resume_wq = create_singlethread_workqueue("ft5x_resume");
if (ft5x_resume_wq == NULL) {
printk("create ft5x_resume_wq fail!\n");
return -ENOMEM;
printk("==register_early_suspend =\n");
ft5x_ts->early_suspend.level = EARLY_SUSPEND_LEVEL_BLANK_SCREEN + 1;
ft5x_ts->early_suspend.suspend = ft5x_ts_early_suspend;
ft5x_ts->early_suspend.resume = ft5x_ts_late_resume;
register_early_suspend(&ft5x_ts->early_suspend);
dprintk(DEBUG_INIT,"CONFIG_FT5X0X_MULTITOUCH is defined. \n");
config_info.dev = &(ft5x_ts->input_dev->dev);
err = input_request_int(&(config_info.input_type), ft5x_ts_interrupt,
CTP_IRQ_MODE, ft5x_ts);
if (err) {
pr_info( "goodix_probe: request irq failed\n");
goto exit_irq_request_failed;
i2c_dev = get_free_i2c_dev(client->adapter);
if (IS_ERR(i2c_dev)){
err = PTR_ERR(i2c_dev);
printk("i2c_dev fail!");
return err;
dev = device_create(i2c_dev_class, &client->adapter->dev, MKDEV(I2C_MAJOR,client->adapter->nr),
NULL, "aw_i2c_ts%d", client->adapter->nr);
if (IS_ERR(dev)) {
err = PTR_ERR(dev);
printk("dev fail!\n");
return err;
device_enable_async_suspend(&client->dev);
dprintk(DEBUG_INIT,"==%s over =\n", __func__);
exit_irq_request_failed:
cancel_work_sync(&ft5x_resume_work);
destroy_workqueue(ft5x_resume_wq);
exit_input_register_device_failed:
input_free_device(input_dev);
exit_input_dev_alloc_failed:
input_free_int(&(config_info.input_type), ft5x_ts);
i2c_set_clientdata(client, NULL);
cancel_work_sync(&ft5x_ts->pen_event_work);
destroy_workqueue(ft5x_ts->ts_workqueue);
exit_create_singlethread:
kfree(ft5x_ts);
exit_alloc_data_failed:
exit_check_functionality_failed:
cancel_work_sync(&ft5x_init_work);
destroy_workqueue(ft5x_wq);
return err;
static int ft5x_ts_remove(struct i2c_client *client)
struct ft5x_ts_data *ft5x_ts = i2c_get_clientdata(client);
printk("==ft5x_ts_remove=\n");
device_destroy(i2c_dev_class, MKDEV(I2C_MAJOR,client->adapter->nr));
unregister_early_suspend(&ft5x_ts->early_suspend);
input_unregister_device(ft5x_ts->input_dev);
input_free_device(ft5x_ts->input_dev);
kfree(ft5x_ts);
i2c_set_clientdata(this_client, NULL);
static const struct i2c_device_id ft5x_ts_id[] = {
{ CTP_NAME, 0 },
MODULE_DEVICE_TABLE(i2c, ft5x_ts_id);
static struct i2c_driver ft5x_ts_driver = {
.class = I2C_CLASS_HWMON,
.probe = ft5x_ts_probe,
.remove = ft5x_ts_remove,
.id_table = ft5x_ts_id,
.driver = {
.name = CTP_NAME,
.owner = THIS_MODULE,
.suspend = ft5x_ts_suspend,
.resume = ft5x_ts_resume,
.address_list = normal_i2c,
static int aw_open(struct inode *inode, struct file *file)
int subminor;
struct i2c_client *client;
struct i2c_adapter *adapter;
printk("====%s======.\n", __func__);
dprintk(DEBUG_OTHERS_INFO,"enter aw_open function\n");
subminor = iminor(inode);
dprintk(DEBUG_OTHERS_INFO,"subminor=%d\n",subminor);
i2c_dev = i2c_dev_get_by_minor(2);
if (!i2c_dev) {
printk("error i2c_dev\n");
return -ENODEV;
adapter = i2c_get_adapter(i2c_dev->adap->nr);
if (!adapter) {
return -ENODEV;
client = kzalloc(sizeof(*client), GFP_KERNEL);
if (!client) {
i2c_put_adapter(adapter);
return -ENOMEM;
snprintf(client->name, I2C_NAME_SIZE, "pctp_i2c_ts%d", adapter->nr);
//client->driver = &ft5x_ts_driver;
client->adapter = adapter;
file->private_data = client;
static long aw_ioctl(struct file *file, unsigned int cmd,unsigned long arg )
dprintk(DEBUG_OTHERS_INFO,"====%s====\n",__func__);
dprintk(DEBUG_OTHERS_INFO,"line :%d,cmd = %d,arg = %ld.\n",__LINE__,cmd,arg);
switch (cmd) {
case UPGRADE:
dprintk(DEBUG_OTHERS_INFO,"==UPGRADE_WORK=\n");
// calibrate();
break;
default:
break;
static int aw_release (struct inode *inode, struct file *file)
struct i2c_client *client = file->private_data;
dprintk(DEBUG_OTHERS_INFO,"enter aw_release function.\n");
i2c_put_adapter(client->adapter);
kfree(client);
file->private_data = NULL;
static const struct file_operations aw_i2c_ts_fops ={
.open = aw_open,
.unlocked_ioctl = aw_ioctl,
.release = aw_release,
static int ctp_get_system_config(void)
ctp_print_info(config_info,DEBUG_INIT);
twi_id = config_info.twi_id;
screen_max_x = config_info.screen_max_x;
screen_max_y = config_info.screen_max_y;
revert_x_flag = config_info.revert_x_flag;
revert_y_flag = config_info.revert_y_flag;
exchange_x_y_flag = config_info.exchange_x_y_flag;
if((screen_max_x == 0) || (screen_max_y == 0)){
printk("%s:read config error!\n",__func__);
return 1;
static int __init ft5x_ts_init(void)
printk("==ft5x_ts_init==\n");
int ret = -1;
dprintk(DEBUG_INIT,"***************************init begin*************************************\n");
printk("####%s start####\n", __func__);
if (input_sensor_startup(&(config_info.input_type))) {
printk("%s: ctp_fetch_sysconfig_para err.\n", __func__);
} else {
ret = input_sensor_init(&(config_info.input_type));
if (0 != ret) {
printk("%s:ctp_ops.init_platform_resource err. \n", __func__);
if(config_info.ctp_used == 0){
printk("*** ctp_used set to 0 !\n");
printk("*** if use ctp,please put the sys_config.fex ctp_used set to 1. \n");
if(!ctp_get_system_config()){
printk("%s:read config fail!\n",__func__);
return ret;
msleep(10);
ctp_wakeup(0, 10);
ft5x_ts_driver.detect = ctp_detect;
ret= register_chrdev(I2C_MAJOR,"aw_i2c_ts",&aw_i2c_ts_fops );
if(ret) {
printk("%s:register chrdev failed\n",__FILE__);
return ret;
i2c_dev_class = class_create(THIS_MODULE,"aw_i2c_dev");
if (IS_ERR(i2c_dev_class)) {
ret = PTR_ERR(i2c_dev_class);
class_destroy(i2c_dev_class);
ret = i2c_add_driver(&ft5x_ts_driver);
dprintk(DEBUG_INIT,"****************************init end************************************\n");
printk("####%s end####\n", __func__);
return ret;
static void __exit ft5x_ts_exit(void)
printk("==ft5x_ts_exit==\n");
i2c_del_driver(&ft5x_ts_driver);
unregister_chrdev(I2C_MAJOR, "aw_i2c_ts");
input_sensor_free(&(config_info.input_type));
late_initcall(ft5x_ts_init);
module_exit(ft5x_ts_exit);
MODULE_AUTHOR("<wenfs@Focaltech-systems.com>");
MODULE_DESCRIPTION("FocalTech ft5x TouchScreen driver");
MODULE_LICENSE("GPL");设备树配置:
twi0: twi@0x05002000{
clock-frequency = <100000>;
pinctrl-0 = <&twi0_pins_a>;
pinctrl-1 = <&twi0_pins_b>;
ctp@3b {
compatible = "ft5x_ts";
reg = <0x3b>;
device_type = "ctp";
ctp_name = "ft5x_ts";
ctp_twi_id = <0x0>;
ctp_twi_addr = <0x3b>;
ctp_screen_max_x = <0x02D0>;
ctp_screen_max_y = <0x0500>;
ctp_revert_x_flag = <1>;
ctp_revert_y_flag = <1>;
ctp_exchange_x_y_flag = <0x1>;
ctp_int_port = <&pio PH 15 6 0xffffffff 0xffffffff 0>;
ctp_wakeup = <&pio PH 14 1 0xffffffff 0xffffffff 1>;
ctp_power_io = <&pio PB 5 1 0xffffffff 0xffffffff 1>;
ctp-supply = <®_cldo2>;
ctp_power_ldo_vol = <3300>;
pio: pinctrl@0300b000 {
twi0_pins_a: twi0@0 {
allwinner,pins = "PH0", "PH1";
allwinner,pname = "twi0_scl", "twi0_sda";
allwinner,function = "twi0";
allwinner,muxsel = <2>;
allwinner,drive = <1>;
allwinner,pull = <0>;
twi0_pins_b: twi0@1 {
allwinner,function = "io_disabled";
allwinner,muxsel = <7>;
}报错信息:
[ 107.311165] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3)
[ 107.320956] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4)
[ 107.330676] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5)
[ 107.340367] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6)
[ 107.350250] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x7)
[ 107.359835] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x8)
[ 107.369453] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x9)
[ 107.379070] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0xa)
[ 107.388751] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0xb)
[ 107.398379] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0xc)
[ 107.407991] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0xd)
[ 107.417682] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0xe)
[ 107.427290] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0xf)
[ 107.437429] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x10)
[ 107.447131] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x11)
[ 107.456932] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x12)
[ 107.466689] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x13)
[ 107.476443] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[ 107.486187] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x15)
[ 107.495887] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x16)
[ 107.505627] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x17)
[ 107.515488] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[ 107.525335] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[ 107.535075] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[ 107.544771] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1b)
[ 107.554712] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1c)
[ 107.564565] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1d)
[ 107.574809] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1e)
[ 107.584560] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1f)
[ 107.594328] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x20)
[ 107.599813] healthd: battery l=79 v=4003 t=30.0 h=2 st=2 fc=1771 chg=u
[ 107.611603] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x21)
[ 107.621483] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x22)
[ 107.631398] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x23)
[ 107.641359] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x24)
[ 107.651147] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x25)
[ 107.660840] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x26)
[ 107.670569] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x27)
[ 107.680301] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x28)
[ 107.690746] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[ 107.700783] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[ 107.710488] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[ 107.720374] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2c)
[ 107.730071] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2d)
[ 107.739777] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2e)
[ 107.749500] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 107.759010] msg ft5x_i2c_rxdata i2c read error: -70
[ 107.764648] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2f)
[ 107.774298] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 107.783673] msg ft5x_i2c_rxdata i2c read error: -70
[ 107.789257] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x30)
[ 107.798948] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 107.808392] msg ft5x_i2c_rxdata i2c read error: -70
[ 107.814000] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x31)
[ 107.823651] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 107.833054] msg ft5x_i2c_rxdata i2c read error: -70
[ 107.838659] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x32)
[ 107.848292] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 107.857735] msg ft5x_i2c_rxdata i2c read error: -70
[ 107.863393] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x33)
[ 107.873097] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 107.882583] msg ft5x_i2c_rxdata i2c read error: -70
[ 107.882836] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x34)
[ 107.883142] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x35)
[ 107.883424] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x36)
[ 107.883699] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x37)
[ 107.883968] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38)
[ 107.884241] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x39)
[ 107.884581] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3a)
[ 107.884880] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3c)
[ 107.885151] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3d)
[ 107.885420] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3e)
[ 107.885689] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3f)
[ 107.885991] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x40)
[ 107.886260] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x41)
[ 107.886529] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x42)
[ 107.886798] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x43)
[ 107.887066] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x44)
[ 107.887335] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x45)
[ 107.887611] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x46)
[ 107.887880] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x47)
[ 107.888148] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48)
[ 107.888420] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x49)
[ 107.888708] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4a)
[ 107.888977] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4b)
[ 107.889239] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[ 107.889501] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[ 107.889771] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[ 107.890038] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4f)
[ 107.890340] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x50)
[ 107.890607] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51)
[ 107.890886] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x52)
[ 107.891155] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x53)
[ 107.891422] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x54)
[ 107.891687] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x55)
[ 107.891952] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x56)
[ 107.892219] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x57)
[ 107.892484] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x58)
[ 107.892749] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x59)
[ 107.893016] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5a)
[ 107.893282] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5b)
[ 107.893548] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5c)
[ 107.893814] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[ 107.894079] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5e)
[ 107.894399] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5f)
[ 107.894702] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x60)
[ 107.894973] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x61)
[ 107.895241] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x62)
[ 107.895509] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x63)
[ 107.895778] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x64)
[ 107.896048] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x65)
[ 107.896317] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x66)
[ 107.896584] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x67)
[ 107.896853] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x68)
[ 107.897122] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x69)
[ 107.897391] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6a)
[ 107.897666] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6b)
[ 107.897938] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6c)
[ 107.898208] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6d)
[ 107.898476] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6e)
[ 107.898744] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x6f)
[ 107.899045] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x70)
[ 107.899313] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x71)
[ 107.899581] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x72)
[ 107.899850] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x73)
[ 107.900118] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x74)
[ 107.900386] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x75)
[ 107.900656] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x76)
[ 107.900928] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77)
[ 108.516483] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.525921] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.531723] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.541209] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.546989] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.556390] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.562104] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.571472] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.577197] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.586569] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.592297] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.601670] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.607396] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.616769] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.622474] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.632107] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.637920] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.647337] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.653059] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.662524] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.668299] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.677696] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.683468] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.692978] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.698772] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.708168] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.713881] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.723296] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.729010] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.738384] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.744121] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.753495] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.759232] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.768662] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.774445] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.783824] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.789573] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.798964] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.804677] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.814068] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.819784] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.829172] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.834884] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.844356] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.850192] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.867975] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.875015] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.884979] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.893156] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.903009] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.909402] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.918950] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.924824] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.934287] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.940130] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.949631] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.955409] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.964898] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.971172] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.980763] msg ft5x_i2c_rxdata i2c read error: -70
[ 108.986597] sunxi_i2c_do_xfer()1951 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x3b)
[ 108.996107] msg ft5x_i2c_rxdata i2c read error: -70
[ 117.627842] healthd: battery l=79 v=4006 t=30.0 h=2 st=2 fc=1771 chg=u\ceres-b6:/ # dmesg
[ 206.502538] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.502847] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.503154] twi_start()481 - [i2c0] START can't sendout!
[ 206.503157] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.503261] msg ft5x_i2c_rxdata i2c read error: -121
[ 206.503468] twi_start()481 - [i2c0] START can't sendout!
[ 206.503470] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.503777] twi_start()481 - [i2c0] START can't sendout!
[ 206.503779] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.504087] twi_start()481 - [i2c0] START can't sendout!
[ 206.504089] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.504193] msg ft5x_i2c_rxdata i2c read error: -121
[ 206.504401] twi_start()481 - [i2c0] START can't sendout!
[ 206.504403] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.504710] twi_start()481 - [i2c0] START can't sendout!
[ 206.504712] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 206.505020] twi_start()481 - [i2c0] START can't sendout!离线
有没有4K7上来,逻辑分析仪抓一下 SCL/SDA?
都是正常的scl/sda
关闭系统日志:
echo 0 > /proc/sys/kernel/printk扫描:
i2c-detect -y 0可能需要把 ctp@3b 这部分注释起来。
扫描的时候,除了看日志输出,可以配合逻辑分析仪看下设备的反应。
ctp这整个节点注释掉吗 还是说只注释这个地址?
@xuuu
注释这个节点,否则 i2c-detect -y 0(i2c-utils) 扫描会跳过这个地址。
ctp这整个节点注释掉 再用这个扫吗 i2c-detect -y 0
@xuuu
我卸载这个驱动 用i2cdetect -y 0 什么也扫不出来
最近编辑记录 xuuu (2026-01-19 13:46:12)
大概率是硬件问题,再结合逻辑分析仪数据分析吧。
那我配置没有问题吧 是不是哪里还没有加
你提供的信息很有限,没法分析。
完整报错信息:
[ 127.075858] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 127.083902] [DISP] de_smbl_apply,line:241:sel0, en=1, win=<0,0,720,1280>
[ 127.091597] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 127.646667] healthd: battery l=79 v=3999 t=30.0 h=2 st=2 fc=1771 chg=u
[ 134.125838] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 134.133961] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 134.142416] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 134.149711] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 134.156975] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 134.164266] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 134.171540] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 134.178839] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 134.186180] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 134.193462] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 134.200636] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 134.207889] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 134.215142] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 134.222370] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 134.229576] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 134.236797] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 134.243963] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 134.251209] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 134.258528] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 134.264479] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 134.272459] [DISP] de_al_lyr_apply,line:484:ch0 z 0 en
[ 134.278302] [DISP] de_al_lyr_apply,line:484:ch1 z 1 dis
[ 134.284236] [DISP] de_al_lyr_apply,line:484:ch2 z 0 dis
[ 134.290131] [DISP] de_al_lyr_apply,line:484:ch3 z 0 dis
[ 134.296061] [DISP] de_al_lyr_apply,line:487:pipe0 z 0 en
[ 134.302118] [DISP] de_al_lyr_apply,line:487:pipe1 z 0 dis
[ 134.308244] [DISP] de_al_lyr_apply,line:487:pipe2 z 0 dis
[ 134.314350] [DISP] de_al_lyr_apply,line:487:pipe3 z 0 dis
[ 134.320462] [DISP] de_al_lyr_apply,line:502:format[0]=0
[ 134.326366] [DISP] de_al_lyr_apply,line:502:format[1]=0
[ 134.332259] [DISP] de_calc_ovl_coord,line:389:half_shift_xy=<40000,19,0>
[ 134.339901] [DISP] de_calc_ovl_coord,line:389:half_shift_xy=<40000,19,0>
[ 134.347474] [DISP] de_rtmx_calc_chnrect,line:1729:layernum=4, i=0
[ 134.354411] [DISP] de_rtmx_calc_chnrect,line:1731:crop=<0,0,720,1280>
[ 134.361726] [DISP] de_rtmx_calc_chnrect,line:1733:layer=<0,0,720,1280>
[ 134.369133] [DISP] de_rtmx_calc_chnrect,line:1742:ovl_rect=<0,0,720,1280>
[ 134.376778] [DISP] de_rtmx_calc_chnrect,line:1744:bld_rect=<0,0,720,1280>
[ 134.384477] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[0]=<720,1280>
[ 134.392684] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[0]=<0,0,720,1280>
[ 134.401259] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[1]=<0,0>
[ 134.408971] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[1]=<0,0,0,0>
[ 134.417044] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[2]=<0,0>
[ 134.424774] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[2]=<0,0,0,0>
[ 134.432399] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=3
[ 134.432407] [DISP] de_smbl_apply,line:241:sel0, en=1, win=<0,0,720,1280>
[ 134.432413] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=2
[ 134.456337] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[3]=<0,0>
[ 134.464041] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[3]=<0,0,0,0>
[ 134.472183] [DISP] de_calc_overlay_scaler_para,line:187:fmt[0]=0, ovlw[0]=720,ovlh[0]=1280, bld_rect[0].w=720, bld_rect[0].h=1280
[ 134.485376] [DISP] de_vsu_set_para,line:274:sel0, ch 0, en=0, in<720x1280>,out<720x1280>
[ 134.494596] [DISP] de_calc_overlay_scaler_para,line:187:fmt[1]=0, ovlw[1]=0,ovlh[1]=0, bld_rect[1].w=0, bld_rect[1].h=0
[ 134.506828] [DISP] de_vsu_set_para,line:274:sel0, ch 1, en=0, in<0x0>,out<0x0>
[ 134.515145] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[0]=<0,0,720,1280>
[ 134.523367] [DISP] de_rtmx_set_route,line:1539:sel0, pno0, zorder0, route:0x0
[ 134.531458] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 134.539763] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[1]=<0,0,0,0>
[ 134.547420] [DISP] de_rtmx_set_route,line:1539:sel0, pno1, zorder0, route:0x0
[ 134.555526] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 134.563824] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[2]=<0,0,0,0>
[ 134.571520] [DISP] de_rtmx_set_route,line:1539:sel0, pno2, zorder0, route:0x0
[ 134.579609] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 134.587901] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[3]=<0,0,0,0>
[ 134.595647] [DISP] de_rtmx_set_route,line:1539:sel0, pno3, zorder0, route:0x0
[ 134.603782] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 134.612122] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 134.620219] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 134.633735] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 134.641887] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 134.650108] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 134.657416] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 134.664726] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 134.672025] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 134.679368] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 134.686700] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 134.693890] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 134.701152] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 134.708403] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 134.715669] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 134.722930] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 134.730227] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 134.737455] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 134.744715] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 134.752005] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 134.759267] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 134.766654] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 134.772658] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 134.780713] [DISP] de_al_lyr_apply,line:484:ch0 z 0 en
[ 134.786580] [DISP] de_al_lyr_apply,line:484:ch1 z 1 dis
[ 134.792500] [DISP] de_al_lyr_apply,line:484:ch2 z 0 dis
[ 134.798439] [DISP] de_al_lyr_apply,line:484:ch3 z 0 dis
[ 134.804382] [DISP] de_al_lyr_apply,line:487:pipe0 z 0 en
[ 134.810417] [DISP] de_al_lyr_apply,line:487:pipe1 z 0 dis
[ 134.816546] [DISP] de_al_lyr_apply,line:487:pipe2 z 0 dis
[ 134.822644] [DISP] de_al_lyr_apply,line:487:pipe3 z 0 dis
[ 134.828854] [DISP] de_al_lyr_apply,line:502:format[0]=0
[ 134.834836] [DISP] de_al_lyr_apply,line:502:format[1]=0
[ 134.840816] [DISP] de_calc_ovl_coord,line:389:half_shift_xy=<40000,19,0>
[ 134.848506] [DISP] de_calc_ovl_coord,line:389:half_shift_xy=<40000,19,0>
[ 134.856168] [DISP] de_rtmx_calc_chnrect,line:1729:layernum=4, i=0
[ 134.863072] [DISP] de_rtmx_calc_chnrect,line:1731:crop=<0,0,720,1280>
[ 134.870358] [DISP] de_rtmx_calc_chnrect,line:1733:layer=<0,0,720,1280>
[ 134.877762] [DISP] de_rtmx_calc_chnrect,line:1742:ovl_rect=<0,0,720,1280>
[ 134.885476] [DISP] de_rtmx_calc_chnrect,line:1744:bld_rect=<0,0,720,1280>
[ 134.893215] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[0]=<720,1280>
[ 134.901401] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[0]=<0,0,720,1280>
[ 134.910012] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[1]=<0,0>
[ 134.917711] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[1]=<0,0,0,0>
[ 134.925779] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[2]=<0,0>
[ 134.933405] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[2]=<0,0,0,0>
[ 134.941421] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[3]=<0,0>
[ 134.949046] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[3]=<0,0,0,0>
[ 134.957052] [DISP] de_calc_overlay_scaler_para,line:187:fmt[0]=0, ovlw[0]=720,ovlh[0]=1280, bld_rect[0].w=720, bld_rect[0].h=1280
[ 134.970130] [DISP] de_vsu_set_para,line:274:sel0, ch 0, en=0, in<720x1280>,out<720x1280>
[ 134.979216] [DISP] de_calc_overlay_scaler_para,line:187:fmt[1]=0, ovlw[1]=0,ovlh[1]=0, bld_rect[1].w=0, bld_rect[1].h=0
[ 134.991326] [DISP] de_vsu_set_para,line:274:sel0, ch 1, en=0, in<0x0>,out<0x0>
[ 134.999467] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[0]=<0,0,720,1280>
[ 135.007583] [DISP] de_rtmx_set_route,line:1539:sel0, pno0, zorder0, route:0x0
[ 135.015667] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.023877] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[1]=<0,0,0,0>
[ 135.031511] [DISP] de_rtmx_set_route,line:1539:sel0, pno1, zorder0, route:0x0
[ 135.039526] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.047736] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[2]=<0,0,0,0>
[ 135.055360] [DISP] de_rtmx_set_route,line:1539:sel0, pno2, zorder0, route:0x0
[ 135.063378] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.071599] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[3]=<0,0,0,0>
[ 135.079232] [DISP] de_rtmx_set_route,line:1539:sel0, pno3, zorder0, route:0x0
[ 135.087265] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.095464] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 135.103384] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 135.119815] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 135.127754] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 135.135847] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 135.142970] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 135.150083] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 135.157265] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 135.164406] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 135.171524] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 135.178638] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 135.185751] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 135.192866] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 135.199979] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 135.207081] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 135.214196] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 135.221310] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 135.228421] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 135.235536] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 135.242650] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 135.249819] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 135.255663] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 135.263544] [DISP] de_al_lyr_apply,line:484:ch0 z 0 en
[ 135.269289] [DISP] de_al_lyr_apply,line:484:ch1 z 1 dis
[ 135.275141] [DISP] de_al_lyr_apply,line:484:ch2 z 0 dis
[ 135.280991] [DISP] de_al_lyr_apply,line:484:ch3 z 0 dis
[ 135.286831] [DISP] de_al_lyr_apply,line:487:pipe0 z 0 en
[ 135.292770] [DISP] de_al_lyr_apply,line:487:pipe1 z 0 dis
[ 135.298823] [DISP] de_al_lyr_apply,line:487:pipe2 z 0 dis
[ 135.304886] [DISP] de_al_lyr_apply,line:487:pipe3 z 0 dis
[ 135.310955] [DISP] de_al_lyr_apply,line:502:format[0]=0
[ 135.316819] [DISP] de_al_lyr_apply,line:502:format[1]=0
[ 135.322694] [DISP] de_calc_ovl_coord,line:389:half_shift_xy=<40000,19,0>
[ 135.330223] [DISP] de_calc_ovl_coord,line:389:half_shift_xy=<40000,19,0>
[ 135.337752] [DISP] de_rtmx_calc_chnrect,line:1729:layernum=4, i=0
[ 135.344599] [DISP] de_rtmx_calc_chnrect,line:1731:crop=<0,0,720,1280>
[ 135.351833] [DISP] de_rtmx_calc_chnrect,line:1733:layer=<0,0,720,1280>
[ 135.359165] [DISP] de_rtmx_calc_chnrect,line:1742:ovl_rect=<0,0,720,1280>
[ 135.366782] [DISP] de_rtmx_calc_chnrect,line:1744:bld_rect=<0,0,720,1280>
[ 135.374418] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[0]=<720,1280>
[ 135.382534] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[0]=<0,0,720,1280>
[ 135.391033] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[1]=<0,0>
[ 135.398656] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[1]=<0,0,0,0>
[ 135.406663] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[2]=<0,0>
[ 135.414287] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[2]=<0,0,0,0>
[ 135.422300] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[3]=<0,0>
[ 135.429913] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[3]=<0,0,0,0>
[ 135.437930] [DISP] de_calc_overlay_scaler_para,line:187:fmt[0]=0, ovlw[0]=720,ovlh[0]=1280, bld_rect[0].w=720, bld_rect[0].h=1280
[ 135.451003] [DISP] de_vsu_set_para,line:274:sel0, ch 0, en=0, in<720x1280>,out<720x1280>
[ 135.460087] [DISP] de_calc_overlay_scaler_para,line:187:fmt[1]=0, ovlw[1]=0,ovlh[1]=0, bld_rect[1].w=0, bld_rect[1].h=0
[ 135.472185] [DISP] de_vsu_set_para,line:274:sel0, ch 1, en=0, in<0x0>,out<0x0>
[ 135.480316] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[0]=<0,0,720,1280>
[ 135.488431] [DISP] de_rtmx_set_route,line:1539:sel0, pno0, zorder0, route:0x0
[ 135.496449] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.504658] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[1]=<0,0,0,0>
[ 135.512281] [DISP] de_rtmx_set_route,line:1539:sel0, pno1, zorder0, route:0x0
[ 135.520297] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.528507] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[2]=<0,0,0,0>
[ 135.536131] [DISP] de_rtmx_set_route,line:1539:sel0, pno2, zorder0, route:0x0
[ 135.544138] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.552348] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[3]=<0,0,0,0>
[ 135.559968] [DISP] de_rtmx_set_route,line:1539:sel0, pno3, zorder0, route:0x0
[ 135.567995] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.576215] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 135.584250] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 135.592391] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 135.600347] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 135.608470] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 135.615617] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 135.622758] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 135.629905] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 135.637037] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 135.644169] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 135.651309] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 135.658447] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 135.665587] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 135.672728] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 135.679867] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 135.686998] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 135.694126] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 135.701264] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 135.708406] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 135.715544] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 135.722686] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 135.728563] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 135.736484] [DISP] de_al_lyr_apply,line:484:ch0 z 0 dis
[ 135.742350] [DISP] de_al_lyr_apply,line:484:ch1 z 1 dis
[ 135.748224] [DISP] de_al_lyr_apply,line:484:ch2 z 0 dis
[ 135.754089] [DISP] de_al_lyr_apply,line:484:ch3 z 0 dis
[ 135.759956] [DISP] de_al_lyr_apply,line:487:pipe0 z 0 dis
[ 135.766016] [DISP] de_al_lyr_apply,line:487:pipe1 z 0 dis
[ 135.772082] [DISP] de_al_lyr_apply,line:487:pipe2 z 0 dis
[ 135.778150] [DISP] de_al_lyr_apply,line:487:pipe3 z 0 dis
[ 135.784216] [DISP] de_al_lyr_apply,line:502:format[0]=0
[ 135.790141] [DISP] de_al_lyr_apply,line:502:format[1]=0
[ 135.796030] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[0]=<0,0>
[ 135.803646] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[0]=<0,0,0,0>
[ 135.811662] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[1]=<0,0>
[ 135.819286] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[1]=<0,0,0,0>
[ 135.827315] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[2]=<0,0>
[ 135.835044] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[2]=<0,0,0,0>
[ 135.843113] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[3]=<0,0>
[ 135.850805] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[3]=<0,0,0,0>
[ 135.858916] [DISP] de_calc_overlay_scaler_para,line:187:fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
[ 135.871110] [DISP] de_vsu_set_para,line:274:sel0, ch 0, en=0, in<0x0>,out<0x0>
[ 135.879267] [DISP] de_calc_overlay_scaler_para,line:187:fmt[1]=0, ovlw[1]=0,ovlh[1]=0, bld_rect[1].w=0, bld_rect[1].h=0
[ 135.891400] [DISP] de_vsu_set_para,line:274:sel0, ch 1, en=0, in<0x0>,out<0x0>
[ 135.899542] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[0]=<0,0,0,0>
[ 135.907172] [DISP] de_rtmx_set_route,line:1539:sel0, pno0, zorder0, route:0x0
[ 135.915191] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.923407] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[1]=<0,0,0,0>
[ 135.931035] [DISP] de_rtmx_set_route,line:1539:sel0, pno1, zorder0, route:0x0
[ 135.939053] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.947263] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[2]=<0,0,0,0>
[ 135.954898] [DISP] de_rtmx_set_route,line:1539:sel0, pno2, zorder0, route:0x0
[ 135.962913] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.971125] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[3]=<0,0,0,0>
[ 135.978755] [DISP] de_rtmx_set_route,line:1539:sel0, pno3, zorder0, route:0x0
[ 135.986771] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 135.994992] [DISP] de_enhance_apply,line:203:disp 0, en=1, sharp=0
[ 136.001950] [DISP] de_peak_enable,line:122:sel=0, chno=0, en=0
[ 136.008519] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 136.016496] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 136.025404] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 136.033387] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 136.041518] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 136.048665] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 136.055806] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 136.062941] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 136.070078] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 136.077211] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 136.084350] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 136.091490] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 136.098626] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 136.105771] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 136.112912] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 136.120050] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 136.127183] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 136.134324] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 136.141468] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 136.148607] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 136.155751] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 136.161625] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 136.169542] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 136.177465] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 136.193225] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 136.201217] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 136.209345] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 136.216490] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 136.223621] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 136.230753] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 136.237973] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 136.245137] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 136.252277] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 136.259420] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 136.266559] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 136.273693] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 136.280829] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 136.287970] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 136.295111] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 136.302251] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 136.309391] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 136.316530] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 136.323665] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 136.329532] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 136.337441] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 136.345375] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 136.360677] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=1
[ 136.368622] [DISP] disp_mgr_set_layer_config2,line:1867:mgr0, config 16 layers
[ 136.376739] [DISP] disp_get_layer,line:97:0,0,0, name=mgr0 chn0 lyr0
[ 136.383872] [DISP] disp_get_layer,line:97:0,0,1, name=mgr0 chn0 lyr1
[ 136.391016] [DISP] disp_get_layer,line:97:0,0,2, name=mgr0 chn0 lyr2
[ 136.398155] [DISP] disp_get_layer,line:97:0,0,3, name=mgr0 chn0 lyr3
[ 136.405296] [DISP] disp_get_layer,line:97:0,1,0, name=mgr0 chn1 lyr0
[ 136.412434] [DISP] disp_get_layer,line:97:0,1,1, name=mgr0 chn1 lyr1
[ 136.419574] [DISP] disp_get_layer,line:97:0,1,2, name=mgr0 chn1 lyr2
[ 136.426796] [DISP] disp_get_layer,line:97:0,1,3, name=mgr0 chn1 lyr3
[ 136.433941] [DISP] disp_get_layer,line:97:0,2,0, name=mgr0 chn2 lyr0
[ 136.441084] [DISP] disp_get_layer,line:97:0,2,1, name=mgr0 chn2 lyr1
[ 136.448229] [DISP] disp_get_layer,line:97:0,2,2, name=mgr0 chn2 lyr2
[ 136.455383] [DISP] disp_get_layer,line:97:0,2,3, name=mgr0 chn2 lyr3
[ 136.462525] [DISP] disp_get_layer,line:97:0,3,0, name=mgr0 chn3 lyr0
[ 136.469665] [DISP] disp_get_layer,line:97:0,3,1, name=mgr0 chn3 lyr1
[ 136.476805] [DISP] disp_get_layer,line:97:0,3,2, name=mgr0 chn3 lyr2
[ 136.483935] [DISP] disp_get_layer,line:97:0,3,3, name=mgr0 chn3 lyr3
[ 136.491081] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 136.496943] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:1, cnt=2
[ 136.504866] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=1
[ 136.512823] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 136.528567] [DISP] disp_mgr_apply,line:2371:mgr 0 apply
[ 136.534487] [DISP] bsp_disp_shadow_protect,line:688:[ 136.539875] disp_runtime_idle
[ 136.543224] sel=0, protect:1, cnt=1
[ 136.547465] [DISP] de_al_lyr_apply,line:484:ch0 z 0 dis
[ 136.553371] [DISP] de_al_lyr_apply,line:484:ch1 z 1 dis
[ 136.559239] [DISP] de_al_lyr_apply,line:484:ch2 z 0 dis
[ 136.565125] [DISP] de_al_lyr_apply,line:484:ch3 z 0 dis
[ 136.571000] [DISP] de_al_lyr_apply,line:487:pipe0 z 0 dis
[ 136.577061] [DISP] de_al_lyr_apply,line:487:pipe1 z 0 dis
[ 136.583148] [DISP] de_al_lyr_apply,line:487:pipe2 z 0 dis
[ 136.589215] [DISP] de_al_lyr_apply,line:487:pipe3 z 0 dis
[ 136.595325] [DISP] de_al_lyr_apply,line:502:format[0]=0
[ 136.601179] [DISP] de_al_lyr_apply,line:502:format[1]=0
[ 136.607040] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[0]=<0,0>
[ 136.614677] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[0]=<0,0,0,0>
[ 136.622693] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[1]=<0,0>
[ 136.630320] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[1]=<0,0,0,0>
[ 136.638337] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[2]=<0,0>
[ 136.645972] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[2]=<0,0,0,0>
[ 136.653978] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[3]=<0,0>
[ 136.661600] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[3]=<0,0,0,0>
[ 136.669625] [DISP] de_calc_overlay_scaler_para,line:187:fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
[ 136.681789] [DISP] de_vsu_set_para,line:274:sel0, ch 0, en=0, in<0x0>,out<0x0>
[ 136.689903] [DISP] de_calc_overlay_scaler_para,line:187:fmt[1]=0, ovlw[1]=0,ovlh[1]=0, bld_rect[1].w=0, bld_rect[1].h=0
[ 136.702011] [DISP] de_vsu_set_para,line:274:sel0, ch 1, en=0, in<0x0>,out<0x0>
[ 136.710140] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[0]=<0,0,0,0>
[ 136.717779] [DISP] de_rtmx_set_route,line:1539:sel0, pno0, zorder0, route:0x0
[ 136.725794] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 136.734011] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[1]=<0,0,0,0>
[ 136.741786] [DISP] de_rtmx_set_route,line:1539:sel0, pno1, zorder0, route:0x0
[ 136.749831] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 136.758051] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[2]=<0,0,0,0>
[ 136.765692] [DISP] de_rtmx_set_route,line:1539:sel0, pno2, zorder0, route:0x0
[ 136.773706] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 136.781932] [DISP] de_al_lyr_apply,line:694:sel=0, pipe_rect[3]=<0,0,0,0>
[ 136.789560] [DISP] de_rtmx_set_route,line:1539:sel0, pno3, zorder0, route:0x0
[ 136.797589] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040580, reg=0x0
[ 136.805813] [DISP] bsp_disp_shadow_protect,line:688:sel=0, protect:0, cnt=0
[ 136.813822] [DISP] disp_mgr_apply,line:2371:mgr 1 apply
[ 136.819692] [DISP] bsp_disp_shadow_protect,line:688:sel=1, protect:1, cnt=1
[ 136.827623] [DISP] de_al_lyr_apply,line:484:ch0 z 0 dis
[ 136.833506] [DISP] de_al_lyr_apply,line:484:ch1 z 1 dis
[ 136.839373] [DISP] de_al_lyr_apply,line:484:ch2 z 0 dis
[ 136.845251] [DISP] de_al_lyr_apply,line:487:pipe0 z 0 dis
[ 136.851331] [DISP] de_al_lyr_apply,line:487:pipe1 z 0 dis
[ 136.857389] [DISP] de_al_lyr_apply,line:487:pipe2 z 0 dis
[ 136.863450] [DISP] de_al_lyr_apply,line:502:format[0]=0
[ 136.869337] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[0]=<0,0>
[ 136.876952] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[0]=<0,0,0,0>
[ 136.884983] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[1]=<0,0>
[ 136.892607] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[1]=<0,0,0,0>
[ 136.900626] [DISP] de_calc_overlay_scaler_para,line:178:ovl_rect[2]=<0,0>
[ 136.908250] [DISP] de_calc_overlay_scaler_para,line:180:bld_rect[2]=<0,0,0,0>
[ 136.916287] [DISP] de_calc_overlay_scaler_para,line:187:fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
[ 136.928394] [DISP] de_vsu_set_para,line:274:sel1, ch 0, en=0, in<0x0>,out<0x0>
[ 136.936531] [DISP] de_al_lyr_apply,line:694:sel=1, pipe_rect[0]=<0,0,0,0>
[ 136.944192] [DISP] de_rtmx_set_route,line:1539:sel1, pno0, zorder0, route:0x0
[ 136.952224] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040180, reg=0x0
[ 136.960435] [DISP] de_al_lyr_apply,line:694:sel=1, pipe_rect[1]=<0,0,0,0>
[ 136.968083] [DISP] de_rtmx_set_route,line:1539:sel1, pno1, zorder0, route:0x0
[ 136.976101] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040180, reg=0x0
[ 136.984431] [DISP] de_al_lyr_apply,line:694:sel=1, pipe_rect[2]=<0,0,0,0>
[ 136.992076] [DISP] de_rtmx_set_route,line:1539:sel1, pno2, zorder0, route:0x0
[ 137.000104] [DISP] de_rtmx_set_route,line:1543:addr=0xffffffc07b040180, reg=0x0
[ 137.008319] [DISP] bsp_disp_shadow_protect,line:688:sel=1, protect:0, cnt=0
[ 137.681568] healthd: battery l=79 v=4052 t=30.0 h=2 st=2 fc=1771 chg=u
[ 141.701236] disp_runtime_suspend
[ 141.704979] [DISP] disp_lcd_disable,line:2042:lcd 0
[ 141.710646] LCD_close_flow
[ 141.713762] LCD_bl_close
[ 141.738393] [DISP] disp_sys_pwm_disable,line:607:disp_sys_pwm_Disable pwm 0
[ 141.746399] [DISP] disp_sys_pwm_set_polarity,line:643:disp_sys_pwm_Set_Polarity pwm 0, active high
[ 141.756631] [DISP] disp_lcd_panel_close,line:1754:close flow:step 0 finish, to delay 200
[ 142.034341] [DISP] disp_lcd_panel_close,line:1754:close flow:step 1 finish, to delay 20
[ 142.171220] [DISP] disp_lcd_panel_close,line:1754:close flow:step 2 finish, to delay 10
[ 142.191207] LCD_power_off
[ 142.194256] [DISP] disp_lcd_pin_cfg,line:1004:lcd 0 pin config, state off, 0
[ 142.203349] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.212555] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.221751] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.230980] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.240180] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.249382] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.258569] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.267780] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.276877] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.285943] sun50iw10p1-pinctrl pio: expect_func as:dsi4lane, but muxsel(4) is func:dsi0
[ 142.296582] twi_start()481 - [i2c0] START can't sendout!
[ 142.302565] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.309220] twi_start()481 - [i2c0] START can't sendout!
[ 142.315176] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.321853] twi_start()481 - [i2c0] START can't sendout!
[ 142.327904] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.331677] [DISP] disp_sys_power_disable,line:530:suceess to disable regulator cldo1!
[ 142.343576] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.344726] [DISP] disp_sys_power_disable,line:530:suceess to disable regulator cldo3!
[ 142.357638] 6000000.disp supply cldo4 not found, using dummy regulator
[ 142.357918] [DISP] disp_sys_power_disable,line:530:suceess to disable regulator cldo4!
[ 142.358097] [DISP] disp_lcd_panel_close,line:1754:close flow:step 3 finish, to delay 500
[ 142.383688] twi_start()481 - [i2c0] START can't sendout!
[ 142.389657] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.396292] twi_start()481 - [i2c0] START can't sendout!
[ 142.402269] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.408947] twi_start()481 - [i2c0] START can't sendout!
[ 142.414951] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.421440] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.427247] twi_start()481 - [i2c0] START can't sendout!
[ 142.433245] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.439942] twi_start()481 - [i2c0] START can't sendout!
[ 142.445928] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.452606] twi_start()481 - [i2c0] START can't sendout!
[ 142.458598] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.465088] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.470910] twi_start()481 - [i2c0] START can't sendout!
[ 142.476887] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.483557] twi_start()481 - [i2c0] START can't sendout!
[ 142.489530] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.496200] twi_start()481 - [i2c0] START can't sendout!
[ 142.502163] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.508628] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.514412] twi_start()481 - [i2c0] START can't sendout!
[ 142.520359] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.526978] twi_start()481 - [i2c0] START can't sendout!
[ 142.532935] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.539571] twi_start()481 - [i2c0] START can't sendout!
[ 142.545580] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.552031] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.557790] twi_start()481 - [i2c0] START can't sendout!
[ 142.563749] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.570386] twi_start()481 - [i2c0] START can't sendout!
[ 142.576345] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.582980] twi_start()481 - [i2c0] START can't sendout!
[ 142.588939] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.595394] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.601154] twi_start()481 - [i2c0] START can't sendout!
[ 142.607115] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.613749] twi_start()481 - [i2c0] START can't sendout!
[ 142.619710] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.626342] twi_start()481 - [i2c0] START can't sendout!
[ 142.632304] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.638754] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.644513] twi_start()481 - [i2c0] START can't sendout!
[ 142.650468] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.657108] twi_start()481 - [i2c0] START can't sendout!
[ 142.663066] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.669700] twi_start()481 - [i2c0] START can't sendout!
[ 142.675659] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.682185] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.688006] twi_start()481 - [i2c0] START can't sendout!
[ 142.693989] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.700621] twi_start()481 - [i2c0] START can't sendout!
[ 142.706585] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.713220] twi_start()481 - [i2c0] START can't sendout!
[ 142.719184] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.725634] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.731399] twi_start()481 - [i2c0] START can't sendout!
[ 142.737355] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.744085] twi_start()481 - [i2c0] START can't sendout!
[ 142.750112] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.756750] twi_start()481 - [i2c0] START can't sendout!
[ 142.762711] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.769171] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.774925] twi_start()481 - [i2c0] START can't sendout!
[ 142.780892] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.787535] twi_start()481 - [i2c0] START can't sendout!
[ 142.793495] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.800141] twi_start()481 - [i2c0] START can't sendout!
[ 142.806099] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.812555] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.818311] twi_start()481 - [i2c0] START can't sendout!
[ 142.824272] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.830921] twi_start()481 - [i2c0] START can't sendout!
[ 142.836882] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.843518] twi_start()481 - [i2c0] START can't sendout!
[ 142.849519] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.855996] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.861755] twi_start()481 - [i2c0] START can't sendout!
[ 142.867714] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.874292] [DISP] disp_sys_gpio_request,line:280:[ 142.874369] twi_start()481 - [i2c0] START can't sendout!
[ 142.874372] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.874680] twi_start()481 - [i2c0] START can't sendout!
[ 142.874682] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.874786] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.874995] twi_start()481 - [i2c0] START can't sendout!
[ 142.874997] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.875308] twi_start()481 - [i2c0] START can't sendout!
[ 142.875310] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.875620] twi_start()481 - [i2c0] START can't sendout!
[ 142.875623] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.875727] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.875936] twi_start()481 - [i2c0] START can't sendout!
[ 142.875938] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.876245] twi_start()481 - [i2c0] START can't sendout!
[ 142.876248] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.876558] twi_start()481 - [i2c0] START can't sendout!
[ 142.876560] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.876665] msg ft5x_i2c_rxdata i2c read error: -121
[ 142.876874] twi_start()481 - [i2c0] START can't sendout!
[ 142.876877] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
[ 142.877184] twi_start()481 - [i2c0] START can't sendout!
[ 142.877186] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 3 printk messages dropped ** [ 142.877821] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 142.886769] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 142.896195] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 142.905916] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 142.915019] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 142.924428] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 142.934160] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 142.943257] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 142.952724] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 142.962456] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 142.971548] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 142.980956] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 142.990693] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.000109] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.009837] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.019247] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.028980] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.038390] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.048119] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.057223] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.066631] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.076375] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.085471] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.094896] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 143.104627] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.114032] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.123763] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.133184] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.142911] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.152347] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.162076] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.171172] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.180578] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 143.190305] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.199735] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.209439] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.218847] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.228559] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.237978] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.247703] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.256792] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.266196] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.275925] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.285026] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.294755] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.303836] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.313245] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.322968] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.332062] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.341494] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 143.351226] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.360628] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.370343] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.379753] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.389473] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.398890] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.408622] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.417708] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.427112] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.436837] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.445935] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.455340] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.465055] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.474140] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.483857] twi_start()481 - [i2c0] START can't sendout!
** 46 printk messages dropped ** [ 143.490128] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 64 printk messages dropped ** [ 143.498908] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.508011] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.517741] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.526839] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.536573] twi_start()481 - [i2c0] START can't sendout!
** 60 printk messages dropped ** [ 143.544727] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 64 printk messages dropped ** [ 143.553541] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.562628] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.572361] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.581467] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.591193] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.600280] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.610023] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.619130] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 143.628874] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.642326] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.651678] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.661345] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.671005] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.680039] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.690659] twi_start()481 - [i2c0] START can't sendout!
** 67 printk messages dropped ** [ 143.700703] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 143.710366] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.720023] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.729379] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.739036] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 72 printk messages dropped ** [ 143.748699] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.758358] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 69 printk messages dropped ** [ 143.767719] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.777371] sunxi_i2c_do_xfer()1928 - [i2c0] twi_regulator:
** 71 printk messages dropped ** [ 143.787022] twi_start()481 - [i2c0] START can't sendout!离线
扫描不到查下硬件吧,触摸芯片电源复位是否都正常,建议逻辑分析仪或者示波器看下,不要盲调
