楼主 #1 2018-09-08 16:39:25
已发帖子: 9,473
wrtnode 添加相关设备树、注册一个led灯, 注册一个按钮 【转】
参考链接: 将GPIO注册为一个led灯、按钮
修改 dts 文件
gpio-leds {
compatible = "gpio-leds";
indicator {
label = "wrtnode:blue:indicator";
gpios = <&gpio1 14 1>;
compatible要与Led的驱动leds-gpio.c里compatible对应。label是设备的名字,在文件系统/sys/class/leds/目录下设备名对应
gpios = <&gpio1 14 1>,这是指定对应的gpio引脚(GPIO#38)
注册一个按键:
gpio-keys-polled {
compatible = "gpio-keys-polled";
#address-cells = <1>;
#size-cells = <0>;
poll-interval = <20>;
reset {
label = "reset";
gpios = <&gpio0 1 1>;
linux,code = <0x198>;
楼主 #2 2018-09-08 16:42:31
已发帖子: 9,473
Re: wrtnode 添加相关设备树、注册一个led灯, 注册一个按钮 【转】
按照以上的套路, 在 V3s 系统添加一个 led:
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
leds {
blue_led {
label = "licheepi:blue:usr";
gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; / PG1 /
green_led {
label = "licheepi:green:usr";
gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; / PG0 /
default-state = "on";
red_led {
label = "licheepi:red:usr";
gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; / PG2 /
楼主 #3 2018-09-08 17:02:54
已发帖子: 9,473
/sys/class/leds/licheepi:blue:usr
/sys/class/leds/licheepi:green:usr
/sys/class/leds/licheepi:red:usr
应该可以通过这个接口控制 这三个LED.
