楼主 #1 2018-12-30 14:01:22
trigger
已发帖子: 41
一个基于xlib 与 cairo 一个非常简单的窗口程序
https://www.cairographics.org/Xlib/
https://www.cypherpunk.at/files/2014/11/cairo_xlib_simple.c
#include <X11/Xlib.h>
#include <X11/Xatom.h>
#include <X11/Xutil.h>
#include <cairo.h>
#include <cairo-xlib.h>
#include <stdio.h>
#include <stdlib.h>
/*! Simple Cairo/Xlib example.
 * @author Bernhard R. Fischer, 2048R/5C5FFD47 <bf@abenteuerland.at>.
 * @version 2014110801
 * Compile with
 * gcc -Wall $(pkg-config --libs --cflags cairo x11) -o cairo_xlib_simple cairo_xlib_simple.c
/*! Check for Xlib Mouse/Keypress events. All other events are discarded.
 * @param sfc Pointer to Xlib surface.
 * @param block If block is set to 0, this function always returns immediately
 * and does not block. if set to a non-zero value, the function will block
 * until the next event is received.
 * @return The function returns 0 if no event occured (and block is set). A
 * positive value indicates that a key was pressed and the X11 key symbol as
 * defined in <X11/keysymdef.h> is returned. A negative value indicates a mouse
 * button event. -1 is button 1 (left button), -2 is the middle button, and -3
 * the right button.
int cairo_check_event(cairo_surface_t *sfc, int block)
   char keybuf[8];
   KeySym key;
   XEvent e;
   for (;;)
      if (block || XPending(cairo_xlib_surface_get_display(sfc)))
         XNextEvent(cairo_xlib_surface_get_display(sfc), &e);
      switch (e.type)
         case ButtonPress:
            return -e.xbutton.button;
         case KeyPress:
            XLookupString(&e.xkey, keybuf, sizeof(keybuf), &key, NULL);
            return key;
         default:
            fprintf(stderr, "Dropping unhandled XEevent.type = %d.\n", e.type);
/*! Open an X11 window and create a cairo surface base on that window.
 * @param x Width of window.
 * @param y Height of window.
 * @return Returns a pointer to a valid Xlib cairo surface. The function does
 * not return on error (exit(3)).
cairo_surface_t *cairo_create_x11_surface0(int x, int y)
   Display *dsp;
   Drawable da;
   int screen;
   cairo_surface_t *sfc;
   if ((dsp = XOpenDisplay(NULL)) == NULL)
      exit(1);
   screen = DefaultScreen(dsp);
   da = XCreateSimpleWindow(dsp, DefaultRootWindow(dsp), 0, 0, x, y, 0, 0, 0);
   XSelectInput(dsp, da, ButtonPressMask | KeyPressMask);
   XMapWindow(dsp, da);
   sfc = cairo_xlib_surface_create(dsp, da, DefaultVisual(dsp, screen), x, y);
   cairo_xlib_surface_set_size(sfc, x, y);
   return sfc;
/*! Destroy cairo Xlib surface and close X connection.
void cairo_close_x11_surface(cairo_surface_t *sfc)
   Display *dsp = cairo_xlib_surface_get_display(sfc);
   cairo_surface_destroy(sfc);
   XCloseDisplay(dsp);
int main(int argc, char **argv)
   cairo_t *ctx;
   sfc = cairo_create_x11_surface0(500, 500);
   ctx = cairo_create(sfc);
   cairo_set_source_rgb(ctx, 1, 1, 1);
   cairo_paint(ctx);
   cairo_move_to(ctx, 20, 20);
   cairo_line_to(ctx, 200, 400);
   cairo_line_to(ctx, 450, 100);
   cairo_line_to(ctx, 20, 20);
   cairo_set_source_rgb(ctx, 0, 0, 1);
   cairo_fill_preserve(ctx);
   cairo_set_line_width(ctx, 5);
   cairo_set_source_rgb(ctx, 1, 1, 0);
   cairo_stroke(ctx);
   cairo_destroy(ctx);
   cairo_check_event(sfc, 1);
   cairo_close_x11_surface(sfc);
楼主 #2 2018-12-30 14:03:33
trigger
已发帖子: 41
Re: 一个基于xlib 与 cairo 一个非常简单的窗口程序
包含代码可能需要修改一点点:
#include <cairo/cairo.h>
#include <cairo/cairo-xlib.h>
安装cairo库:
sudo apt-get install libcairo2-dev
编译指令:
gcc -o cairo_xlib_simple cairo_xlib_simple.c -lcairo -lX11
