楼主 #1 2019-05-04 08:45:10
wu150
已发帖子: 57
N32903支持多少像素的摄像头
有限制吗?还是像素大了只是慢而已
#2 2019-05-04 09:03:58
已发帖子: 9,473
Re: N32903支持多少像素的摄像头
N3290x_Design_Guide_A1.pdf
 Capture (CMOS Sensor I/F)
 CCIR601 & CCIR656 interfaces supported for connection to CMOS image sensor
Resolution up to 3M pixel
 YUV422 and RGB565 color format supported for data-in from CMOS sensor
 YUV422, RGB565, RGB555 and Y-only color format supported for data storing to system memory
 Planar and packet data format supported for data storing to system memory
 Image cropping supported with the cropping window up to 4096x2048
 Image scaling-down supported
 Vertical and horizontal scaling-down for preview mode supported NO.:
 The scaling factor is N/M
 Two pairs of configurable 8-bit N and 8-bit M for vertical and horizontal scaling-down
 The value of N has to equal to or less than M
 Frame rate control supported
 Combines two interlace fields to a single frame supported for data in from TV-decoder
可以接 300万像素的摄像头。
#3 2019-05-07 17:35:02
tom
已发帖子: 128
分辨率应该还受DCMI接口最大时钟影响,内存带宽有限。
300W应该只是内部DMA的可搬移范围,如果时钟比较低,那应该是可以满足300W。
