act8846可以设置延时开机吗?比如长按5秒才开机。
https://active-semi.com/wp-content/uploads/ACT8846_Datasheet.pdf
是这个吗:
Long Press / Power-cycle:
If the Manual Reset button is asserted for more
than 4s/10s, ACT8846 commences a power
cycle routine in which case all regulators are turned
off and then turned back on. A status bit, PCSTAT[
], is set after the power cycle. The PCSTAT[ ] bit is
automatically cleared to 0 after read.
长按/电源循环:
如果声明手动复位按钮更多
超过4s/10s,ACT8846开始供电
循环程序,在这种情况下所有调节器都会转动
关闭然后再打开。 状态位,PCSTAT [],
在电源循环后设置。 PCSTAT []位是
读取后自动清除为0。
是这个吗:
automatically cleared to 0 after read.长按/电源循环:
如果声明手动复位按钮更多
读取后自动清除为0。
这个看着是复位,而不是开机吧。
