楼主 #1 2019-11-28 19:28:46
并夕夕
已发帖子: 32
分享一个稳定的 ndk jni 读写串口的代码
serial.cpp
//包含头文件
#include <stdio.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#ifndef _WIN32
#include <sys/ioctl.h>
#include <unistd.h>
#include <termios.h>
#else
#include <io.h>
#pragma warning (disable:4996)
#include <errno.h>
#include <string.h>
#include <time.h>
int			fd_ = -1;
extern "C" {
	int set_opt(int fd, int nSpeed, int nBits, char nEvent, int nStop, int min_btye);
long long  getMilisec()
#ifndef _WIN32
	struct timeval now;
	gettimeofday(&now, NULL);
	long long  t_mili = ((long long)now.tv_sec) * 1000 + now.tv_usec / 1000;
	return t_mili;
#else
//打印
//#include "android/log.h"
//static const char *TAG = "HelloWorldScene";
//#define LOGI(fmt, args...) __android_log_print(ANDROID_LOG_INFO, TAG, fmt, ##args)
//#define LOGD(fmt, args...) __android_log_print(ANDROID_LOG_DEBUG, TAG, fmt, ##args)
//#define LOGE(fmt, args...) __android_log_print(ANDROID_LOG_ERROR, TAG, fmt, ##args)
extern "C"  {
	bool Serial_Open()
		if (fd_ > 0)//already open
			return true;
#ifndef _WIN32
		//char *dev[] = { "/dev/ttySAC0", "/dev/ttySAC1", "/dev/ttySAC2", "/dev/ttySAC3" };
		//long vdisable;
		fd_ = open("/dev/ttyS4", O_RDWR | O_NOCTTY | O_NDELAY);
		if (fd_ == -1) {
			return false;
		//LOGE("Open Serial Port %s\n",dev[comport]);
		//恢复串口为阻塞状态
		if (fcntl(fd_, F_SETFL, 0) < 0) {
			return false;
		/*测试是否为终端设备*/
		if (isatty(STDIN_FILENO) == 0) {
			//LOGE("standard input is not a terminal device\n");
		set_opt(fd_, 9600, 8, 'N', 1, 200);
#else
		fd_ = open("/dev/ttyS4", O_RDWR);
		if (fd_ == -1) {
			return false;
		return fd_ > 0;
	void Serial_Close()
		if (fd_ > 0)
			close(fd_);
			fd_ = -1;
	int Serial_SendData(const unsigned char* data, int size)
		if (fd_ < 0)//not open
			return -1;
		int ret = write(fd_, data, size);
		return ret;
	int Serial_RecvData(unsigned char* buff, int len)
			return -1;
		memset(buff, 0, len);
		int readSize = read(fd_, buff, len);
		return readSize;
	 * 功能:设置串口函数
	 * 入口:(fd,波特率,数据位,奇偶校验,停止位)
#ifndef _WIN32
		struct termios newtio, oldtio;
		/*保存测试现有串口参数设置,在这里如果串口号出错,会有相关的出错信息*/
		if (tcgetattr(fd, &oldtio) != 0) {
			// LOGE("SetupSerial 1");
			return -1;
		bzero(&newtio, sizeof(newtio));
		/*步骤一:设置字符大小*/
		newtio.c_cflag |= CLOCAL | CREAD;
		newtio.c_cflag &= ~CSIZE;
		/*设置停止位*/
		switch (nBits) {
		case 7: newtio.c_cflag |= CS7;
			break;
		case 8: newtio.c_cflag |= CS8;
			break;
		/*设置奇偶校验位*/
		switch (nEvent) {
		case 'O': //奇数
			newtio.c_cflag |= PARENB;
			newtio.c_cflag |= PARODD;
			newtio.c_iflag |= (INPCK | ISTRIP);
			break;
		case 'E': //偶数
			newtio.c_cflag &= ~PARODD;
			break;
		case 'N': //无奇偶校验位
			newtio.c_cflag &= ~PARENB;
			break;
		/*设置波特率*/
		switch (nSpeed)
		case 2400:
			cfsetispeed(&newtio, B2400);
			cfsetospeed(&newtio, B2400);
			break;
		case 4800:
			cfsetispeed(&newtio, B4800);
			cfsetospeed(&newtio, B4800);
			break;
		case 9600:
			cfsetispeed(&newtio, B9600);
			cfsetospeed(&newtio, B9600);
			break;
		case 19200:
			cfsetispeed(&newtio, B19200);
			cfsetospeed(&newtio, B19200);
			break;
		case 115200:
			cfsetispeed(&newtio, B115200);
			cfsetospeed(&newtio, B115200);
			break;
		case 460800:
			cfsetispeed(&newtio, B460800);
			cfsetospeed(&newtio, B460800);
			break;
		default:
			break;
		/*设置停止位*/
		if (nStop == 1) {
			newtio.c_cflag &= ~CSTOPB;
		else if (nStop == 2) {
			newtio.c_cflag |= CSTOPB;
		/*设置等待时间和最小接收字符*/
		newtio.c_cc[VTIME] = 1;
		newtio.c_cc[VMIN] = min_btye;
		/*处理未接收字符*/
		tcflush(fd, TCIFLUSH);
		/*激活新配置*/
		if ((tcsetattr(fd, TCSANOW, &newtio)) != 0) {
			// LOGE("COM set error\n");
			return -1;
Android.mk
# Copyright 2009 Cedric Priscal
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
LOCAL_PATH := $(call my-dir)
include $(CLEAR_VARS)
NDK_TOOLCHAIN_VERSION := 4.9
LOCAL_C_INCLUDES := C:/android-ndk-r15b/sources/cxx-stl/gnu-libstdc++/4.9/include
LOCAL_C_INCLUDES +=C:\android-ndk-r15b\sources\cxx-stl\gnu-libstdc++\4.9\libs\armeabi\include
TARGET_PLATFORM := android-18
LOCAL_MODULE    := serialport
LOCAL_SRC_FILES := serial.cpp
LOCAL_LDLIBS    := -llog
LOCAL_CPPFLAGS := -std=c++11 -D __cplusplus=201103L
APP_STL := gnustl_shared
APP_CPPFLAGS := -std=c++11 -frtti -fexceptions
APP_CPPFLAGS += -std=gun++11 -lpthread
include $(BUILD_SHARED_LIBRARY)
Application.mk
APP_ABI := armeabi armeabi-v7a x86
楼主 #2 2019-11-28 19:55:28
并夕夕
已发帖子: 32
Re: 分享一个稳定的 ndk jni 读写串口的代码
#3 2019-11-29 11:39:11
JasonWoo
已发帖子: 84
谢谢分享
#4 2020-05-26 16:27:37
beijingjiufang
谢谢分享,android的ndk有部分root的权限了,可以做很多事情
