楼主 #1 2019-12-06 16:24:38
逸俊晨晖
已发帖子: 151
LittlevGL用VS2017进行PC仿真时 如何接收键盘事件
如题 能接受PC键盘的某一个按键按下的输入
#2 2019-12-06 16:38:10
Zodiac
Re: LittlevGL用VS2017进行PC仿真时 如何接收键盘事件
lvgl在x86平台上用SDL库来实现的跨平台兼容,能接受的输入包括键盘、鼠标和鼠标滚轮,在例程里的main.c里就有,打开相应的条件编译开关就行了。
具体的处理逻辑在indev/keyboard.c里面实现,用keyboard_read()来提取键值。
main.c
    while(1) {
        /* Periodically call the lv_task handler.
         * It could be done in a timer interrupt or an OS task too.*/
        lv_task_handler();
        usleep(5 * 1000);       /*Just to let the system breath*/
        #ifdef SDL_APPLE
            SDL_Event event;
            while(SDL_PollEvent(&event)) {
                #if USE_MOUSE != 0
                    mouse_handler(&event);
                #if USE_KEYBOARD
                    keyboard_handler(&event);
                #if USE_MOUSEWHEEL != 0
                    mousewheel_handler(&event);
keyboard.c
bool keyboard_read(lv_indev_data_t * data)
    data->state = state;
    data->key = keycode_to_ascii(last_key);
    return false;       /*No more data to read so return false*/
void keyboard_handler(SDL_Event * event)
    /* We only care about SDL_KEYDOWN and SDL_KEYUP events */
    switch(event->type) {
        case SDL_KEYDOWN:                       /*Button press*/
            last_key = event->key.keysym.sym;   /*Save the pressed key*/
            state = LV_INDEV_STATE_PR;          /*Save the key is pressed now*/
            break;
        case SDL_KEYUP:                         /*Button release*/
            state = LV_INDEV_STATE_REL;         /*Save the key is released but keep the last key*/
            break;
        default:
            break;
static uint32_t keycode_to_ascii(uint32_t sdl_key)
    /*Remap some key to LV_GROUP_KEY_... to manage groups*/
    switch(sdl_key) {
        case SDLK_RIGHT:
        case SDLK_KP_PLUS:
            return LV_GROUP_KEY_RIGHT;
        case SDLK_LEFT:
        case SDLK_KP_MINUS:
            return LV_GROUP_KEY_LEFT;
        case SDLK_UP:
            return LV_GROUP_KEY_UP;
        case SDLK_DOWN:
            return LV_GROUP_KEY_DOWN;
        case SDLK_ESCAPE:
            return LV_GROUP_KEY_ESC;
#ifdef  LV_GROUP_KEY_BACKSPACE        /*For backward compatibility*/
        case SDLK_BACKSPACE:
            return LV_GROUP_KEY_BACKSPACE;
#ifdef  LV_GROUP_KEY_DEL        /*For backward compatibility*/
        case SDLK_DELETE:
            return LV_GROUP_KEY_DEL;
        case SDLK_KP_ENTER:
        case '\r':
            return LV_GROUP_KEY_ENTER;
        default:
            return sdl_key;
楼主 #3 2019-12-07 10:50:14
逸俊晨晖
已发帖子: 151
按照你说的找到了 感谢指点
