楼主 #1 2020-05-09 18:29:42
缥缈九哥
已发帖子: 93
基于STM32的TM1629的驱动代码--缥缈九哥
某年写个番禺龙美游戏机IO板用到了STM32F103VBT6及TM1629.写下了一个驱动程序。希望能帮助到有需要的朋友。不多说了,代码如下:
/* Includes ------------------------------------------------------------------*/
#ifdef GAME
#include "stm32f10x.h"
#include "stdio.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup GPIO_JTAG_Remap
_________________________________________________
|	STM32F103						TM1629		|
|	PC0-3	CSA-CSD		---->		STB 		|
|	PE14	MISO		<----		MISO		|
|	PC6		SCLK		---->		SCLK		|
|	PC7		MOSI		---->		MOSI		|
|	PC4		KEYLED		---->		KEYLED		|
|	PC5		CPULED		---->		CPULED		|
|_______________________________________________|
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
//TM1629片选 			//STB
#define	TM1629_STB		GPIOC 					/* PC0-PC3			*/
#define	TM1629_CSA		GPIOC, GPIO_Pin_0
#define	TM1629_CSB		GPIOC, GPIO_Pin_1
#define	TM1629_CSC		GPIOC, GPIO_Pin_2
#define	TM1629_CSD		GPIOC, GPIO_Pin_3
//TM1629信号脚
#define	TM1629_SCLK		GPIOC, GPIO_Pin_6		/*PC6	SCLK*/
#define	TM1629_MOSI		GPIOC, GPIO_Pin_7		/*PC7	DIN*/
#define	TM1629_MISO		GPIOE, GPIO_Pin_14		/*PE14	DOUT*/
//键盘指示灯使能
#define	KEY_LAMP_EN		GPIOC, GPIO_Pin_4		/*PC4	RESVIN*/
#define	CPU_LAMP_EN		GPIOC, GPIO_Pin_5		/*PC5	LAMP*/
//TM1629命令
#define	TM1629_ADDR_INC			0x40
#define	TM1629_ADDR_FIXED		0x44
#define	TM1629_ADDR_BASE		0xc0
#define	TM1629_DISP_OFF			0x80
#define	TM1629_DISP_MINON		0x88
#define	TM1629_DISP_MAXON		0x8f
#define	TM1629_DISP_ONX			7
#define	TM1629_DISP_ON			(0x88+TM1629_DISP_ONX)
#define	TM1629_KEY_READ			0x42
//TM1629延时
#define	TM1629_DELAY			2				/* 640ns	*/
//TM1629应用
#define	TM1629_LED_DARK			0x00
#define	TM1629_LED_BRIGHT		0x7F
#define	TM1629_LED_BRIGHT_DOT	0xFF
#define	TM1629_CS_MASK			0xFFF0
#ifdef PART5
#define	TM1629_CS_NONE			7
#else
#define	TM1629_CS_NONE			0
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
const unsigned char TM1629_CODE[16]=
/*0x0	0x1   0x2   0x3   0x4   0x5   0x6   0x7   0x8   0x9   0xA   0xb   0xC   0xd   0xE   0xF*/
{0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0X7C, 0x39, 0x5E, 0x79, 0x71};
const unsigned char TM1629_CODE_LED[16]=
/*0x0	0x1   0x2   0x3   0x4   0x5   0x6   0x7   0x8   0x9   0xA   0xB   0xC   0xD   0xE   0xF*/
{0xBF, 0x86, 0xDB, 0xCF, 0xE6, 0xED, 0xFD, 0x87, 0xFF, 0xEF, 0xF7, 0XFF, 0xB9, 0xBF, 0xF9, 0xF1};
const unsigned char TM1629_SEGMENT[8]=
/*  a     b     c     d     e     f     g     h*/
{0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
/* Private function prototypes -----------------------------------------------*/
void TM1629_Test(void);
void TM1629_Configuration(void);
void TM1629_Write_Byte(uint8_t wrdata);
void TM1629_Write_CMD(uint8_t chip,uint8_t wrdata);
void TM1629_Write_CMD2(uint8_t chip,uint8_t wrdata);
uint8_t TM1629_Read_Byte(void);
uint32_t TM1629_Read_Keys(unsigned char chip);
void TM1629_Activation(uint8_t chip);
void TM1629_Write_Chip(uint8_t chip,uint8_t *led_data);
void TM1629_Write_Led(uint8_t chip,uint8_t led_index,uint8_t led_data);
void TM1629_Write_Leds(uint8_t chip,uint8_t index,uint32_t *data,uint8_t length);
void TM1629_Write_Digital(uint8_t chip,uint8_t led_index,uint8_t led_data);
void TM1629_Write_3Digital(uint8_t chip,uint8_t led_index,uint32_t led_data);
void TM1629_Write_Digitals(uint8_t chip,uint8_t led_index,uint32_t led_data,uint8_t digit_limit);
void TM1629_Write_Segment(uint8_t chip,uint8_t led_index,uint8_t led_data);
extern void SEND_RS485_STRING(char *s);
extern void Delay(__IO uint32_t nTime);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
	GPIO_InitTypeDef GPIO_InitStructure;
	uint32_t i,j;
	/* Enable GPIOC, GPIOE and AFIO clocks */
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
	/* Enable GPIOC PC0-PC7 output */
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 ;
	GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_ResetBits(KEY_LAMP_EN);
	GPIO_ResetBits(CPU_LAMP_EN);
	TM1629_Activation(TM1629_CS_NONE);
	/* Enable GPIOE PE14 input */
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14 ;
	GPIO_Init(GPIOE, &GPIO_InitStructure);
	//全部熄灭
	for(i=1;i<=8;i++)
	{for(j=0;j<16;j++){TM1629_Write_Led(i,j,TM1629_LED_DARK);}}
	uint8_t i; uint32_t j;
	for(i=0;i<8;i++)
		GPIO_ResetBits(TM1629_SCLK);		//拉低时钟
		if(wrdata&0x01) 					//最低位判断
		{GPIO_SetBits(TM1629_MOSI);	 }		//最低位为1,则写1到DIN口
  		{GPIO_ResetBits(TM1629_MOSI);}		//最低位为0,则写0到DIN口
		for(j=0;j<TM1629_DELAY;j++){;}		//delay
		GPIO_SetBits(TM1629_SCLK);			//拉高时钟
  		wrdata>>=1; 						//数据移到下一位
	uint8_t i,rddata=0x0; uint32_t j;
	for(i=0;i<8;i++)
		rddata>>=1; 						//数据移到下一位
  		//DOUT为1,最高位付值为1
		if(GPIO_ReadInputDataBit(TM1629_MISO))	//最高位判断
		{rddata|=0x80;}
		//DOUT为0,最高位付值为0
  	return rddata;
	uint16_t temp = (GPIO_ReadOutputData(TM1629_STB)&TM1629_CS_MASK)+chip;
	GPIO_Write(TM1629_STB, temp);
{	uint32_t j;
	for(j=0;j<TM1629_DELAY;j++){;}//delay
	TM1629_Activation(chip);
	TM1629_Write_Byte(wrdata);
	TM1629_Write_CMD(chip,wrdata);
	TM1629_Write_CMD(chip,TM1629_ADDR_FIXED);
	TM1629_Write_CMD(chip,TM1629_ADDR_BASE+led_index);
	TM1629_Write_Byte(led_data);
	TM1629_Write_CMD2(chip,TM1629_DISP_ON);
{TM1629_Write_Led(chip,led_index,TM1629_CODE[led_data]);}
{TM1629_Write_Led(chip,led_index,TM1629_SEGMENT[led_data]);}
	uint8_t i;
	TM1629_Write_CMD(chip,TM1629_ADDR_INC);
	TM1629_Write_CMD(chip,TM1629_ADDR_BASE+index);
	for(i=0;i<length;i++){TM1629_Write_Byte(data[i]);}
	TM1629_Write_Byte(TM1629_CODE[(led_data%   10)/   1]);
	TM1629_Write_Byte(TM1629_LED_DARK);
	if(led_data>99)TM1629_Write_Byte(TM1629_CODE[(led_data% 1000)/ 100]);
	else TM1629_Write_Byte(TM1629_LED_DARK);
	if(led_data> 9)TM1629_Write_Byte(TM1629_CODE[(led_data%  100)/  10]);
	uint8_t i,data[16];
	data[0]=TM1629_CODE[0];
	for(i=1;i<digit_limit;i++){data[i]=0x0;}
	for(i=0;(led_data>0)&&(i<digit_limit);led_data/=10)
	{data[i++]=TM1629_CODE[led_data%10];}
	for(i=0;i<digit_limit;i++)
	uint8_t i;
	TM1629_Write_CMD(chip,TM1629_ADDR_BASE);
	for(i=0;i<16;i++){TM1629_Write_Byte(led_data[i]);}
uint32_t TM1629_Read_Keys(uint8_t chip)
	uint32_t i,j;
	union {__IO uint32_t u32data;__IO uint8_t u8data[4];} data;
	TM1629_Write_CMD(chip,TM1629_KEY_READ);
	for(i=0;i<4;i++){data.u8data[i]=TM1629_Read_Byte();	}
	return data.u32data;
void TM1629_Clear_All(void)
	uint8_t i,data[16];
	for(i=0;i<16;i++){data[i]=0;}
	TM1629_Configuration();
	for(i=1;i<=9;i++)
	{TM1629_Write_Chip(i,data);}
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
代码完毕。
