[ 0.959402] using random host ethernet address
[ 0.964953] usb0: HOST MAC e2:f0:c0:75:44:a3
[ 0.969276] usb0: MAC 22:25:ab:57:04:a8
[ 0.973156] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 0.980739] g_cdc gadget: g_cdc ready
[ 0.984755] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:37 UTC (37)
[ 0.992992] vcc3v0: disabling
[ 0.996043] vcc5v0: disabling
[ 0.999012] ALSA device list:
[ 1.001974] No soundcards found.
[ 1.007502] random: fast init done
[ 1.050037] random: crng init done
[ 1.677847] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 1.684859] devtmpfs: mounted
[ 1.688997] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting mdev...
[ 5.381577] ------------[ cut here ]------------
[ 5.386298] WARNING: CPU: 0 PID: 86 at drivers/mtd/spi-nor/spi-nor.c:1182 spi_nor_write+0x138/0x1b4
[ 5.395376] Writing at offset 100 into a NOR page. Writing partial pages may decrease reliability and increase wear of NOR flash.
[ 5.395382] Modules linked in:
[ 5.410089] CPU: 0 PID: 86 Comm: touch Not tainted 4.10.15-licheepi-zero #8
[ 5.417038] Hardware name: Allwinner sun8i Family
[ 5.421767] [<c010e2fc>] (unwind_backtrace) from [<c010b098>] (show_stack+0x10/0x14)
[ 5.429509] [<c010b098>] (show_stack) from [<c03465c4>] (dump_stack+0x84/0x98)
[ 5.436732] [<c03465c4>] (dump_stack) from [<c011b634>] (__warn+0xe8/0x100)
[ 5.443689] [<c011b634>] (__warn) from [<c011b684>] (warn_slowpath_fmt+0x38/0x48)
[ 5.451168] [<c011b684>] (warn_slowpath_fmt) from [<c0453094>] (spi_nor_write+0x138/0x1b4)
[ 5.459426] [<c0453094>] (spi_nor_write) from [<c044b454>] (mtd_writev+0xa4/0xec)
[ 5.466909] [<c044b454>] (mtd_writev) from [<c02fbec8>] (jffs2_flash_writev+0x414/0x4b0)
[ 5.474995] [<c02fbec8>] (jffs2_flash_writev) from [<c02f4d48>] (jffs2_write_dnode+0xd4/0x328)
[ 5.483598] [<c02f4d48>] (jffs2_write_dnode) from [<c02f9458>] (jffs2_do_setattr+0x280/0x558)
[ 5.492114] [<c02f9458>] (jffs2_do_setattr) from [<c02f9754>] (jffs2_setattr+0x24/0x48)
[ 5.500114] [<c02f9754>] (jffs2_setattr) from [<c020d990>] (notify_change+0x1c4/0x3d0)
[ 5.508026] [<c020d990>] (notify_change) from [<c021e65c>] (utimes_common+0xa8/0x170)
[ 5.515847] [<c021e65c>] (utimes_common) from [<c021e7d4>] (do_utimes+0xb0/0x144)
[ 5.523322] [<c021e7d4>] (do_utimes) from [<c021ea10>] (SyS_futimesat+0xd0/0xfc)
[ 5.530712] [<c021ea10>] (SyS_futimesat) from [<c0107580>] (ret_fast_syscall+0x0/0x3c)
[ 5.538693] ---[ end trace 2eb92dd1d99ad103 ]---
Starting network: OK
jffs2 文件系统有问题
我思故我在 wrote:
jffs2 文件系统有问题
有没有解决方法啊?我就是下载网上的解压,然后制作啊,有什么问题吗?
哇酷小二 wrote:
先烧 @路漫漫 的固件测试: https://whycan.cn/search.php?action=show_user_topics&user_id=1842
这个是什么固件?
