楼主 #1 2021-01-21 17:15:19
已发帖子: 856
树莓派派基金会发布新产品raspberry pi pico
https://www.raspberrypi.org/documentation/pico/getting-started/
Board Specifications
Raspberry Pi Pico is a low-cost, high-performance microcontroller board with flexible digital interfaces. Key features include:
RP2040 microcontroller chip designed by Raspberry Pi in the United Kingdom
Dual-core Arm Cortex M0+ processor, flexible clock running up to 133 MHz
264KB of SRAM, and 2MB of on-board Flash memory
Castellated module allows soldering direct to carrier boards
USB 1.1 with device and host support
Low-power sleep and dormant modes
Drag-and-drop programming using mass storage over USB
26 × multi-function GPIO pins
2 × SPI, 2 × I2C, 2 × UART, 3 × 12-bit ADC, 16 × controllable PWM channels
Accurate clock and timer on-chip
Temperature sensor
Accelerated floating-point libraries on-chip
8 × Programmable I/O (PIO) state machines for custom peripheral support
#2 2021-01-21 17:25:43
raspberryman
已发帖子: 503
Re: 树莓派派基金会发布新产品raspberry pi pico
单片机版本?
#3 2021-01-21 22:26:03
Quotation
已发帖子: 305
4美元,相当可以啊。
#4 2021-01-28 16:59:07
rick lou
所在地: 中国北京海淀
有寄存器和ram映射表吗
#5 2021-01-28 17:36:32
Blueskull
已发帖子: 458
rick lou wrote:
有寄存器和ram映射表吗
啥都有
#6 2021-01-28 18:16:18
aozima
已发帖子: 483
已买
#7 2021-01-28 19:26:55
SmallJu
已发帖子: 27
讲道理这玩意儿没前途啊,商用不现实,教育打不过arduino
#8 2021-01-31 11:49:12
whyabc666
封禁
已发帖子: 378
一颗赛艇,youarewelcom
#9 2021-01-31 12:30:43
狼狼
已发帖子: 107
应该是为了完善树莓派生态的吧?
