楼主 # 2022-08-01 21:29:41
tevada2010
已发帖子: 54
buildroot 怎么能像这样显示 root ?
通常 buildroot 会像这样显示 root。
bin      lib      media    proc     sbin     usr
dev      lib32    mnt      root     sys      var
etc      linuxrc  opt      run      tmp
root@TinaLinux:/tmp#
最近编辑记录 tevada2010 (2022-08-01 21:31:27)
#1 2022-08-01 21:48:48
unturned3
已发帖子: 272
Re: buildroot 怎么能像这样显示 root ?
You need to customize your shell's PS1 environment variable; see https://linuxhint.com/bash-ps1-customization/
楼主 #2 2022-08-01 23:22:58
tevada2010
已发帖子: 54
Thank you very much?
