https://linux-sunxi.org/Used_IP_cores
Allwinner implementation used. Might have connection to Exynos G2D.
Samsung 2D Graphic Accelerator using DRM frame work
Samsung FIMG2D is a graphics 2D accelerator which supports Bit Block Transfer.
We set the drawing-context registers for configuring rendering parameters and
then start rendering.
This driver is for SOCs which contain G2D IPs with version 4.1.
Required properties:
-compatible:
should be "samsung,exynos-g2d-41".
-reg:
physical base address of the controller and length
of memory mapped region.
-interrupts:
interrupt combiner values.
Example:
g2d {
compatible = "samsung,exynos-g2d-41";
reg = <0x10850000 0x1000>;
interrupts = <0 91 0>;
D1S这款芯片吗?
sokou wrote:
D1S这款芯片吗?
是的,全志所有支持G2D功能的芯片都是这个IP,包括D1S
这个是怎看出来的呢?
