楼主 #1 2018-04-13 16:41:08
已发帖子: 9,473
step by step 给ts_calibrate 触摸屏校正程序加上汉字显示.
一个触摸屏校正程序,只能光秃秃显示几个英文字母,
不加几个汉字是不是没有一点民族自豪感?
那么下面我们step by step 给ts_calibrate.c 触摸屏校正程序加上汉字显示.
楼主 #2 2018-04-13 16:42:05
已发帖子: 9,473
Re: step by step 给ts_calibrate 触摸屏校正程序加上汉字显示.
因为只需要显示几个离散汉字: 请点击十字光标校正触摸屏。
所以没有必要弄一个全字库.
下载链接: 字模软件下载
楼主 #3 2018-04-13 16:45:24
已发帖子: 9,473
重新下载: zimoV2_2.rar
楼上的字库软件错了.
楼主 #4 2018-04-13 16:45:26
已发帖子: 9,473
还算顺利, 差不多搞定了。
楼主 #5 2018-04-13 16:45:28
已发帖子: 9,473
摆正一点
楼主 #6 2018-04-13 16:45:30
已发帖子: 9,473
fbutils.c 添加:
void put_chinese_char(int x, int y, int c, int colidx)
    int i,j;
    uint16_t a = 0, b = 0;
    uint16_t bits;
    for (i = 0; i < font_vga_16x16.height*2; i++) {
        a = font_vga_16x16.data [c * 32 + i];
        i++;
        b = font_vga_16x16.data [c * 32 + i];
        bits = a<<8 | b;
        printf("a=0x%02x, b=0x%02x, bits = 0x%04x, font_vga_16x16.width=%d\n", a, b, bits, font_vga_16x16.width);
        for (j = 0; j < font_vga_16x16.width; j++, bits <<= 1)
            if (bits & 0x8000)
                pixel (x + j, y + i/2, colidx);
字库文件 font_16x16.c:
#include "font.h"
#define FONTDATAMAX 4096*2
static unsigned char fontdata_16x16[FONTDATAMAX] = {
/*--  文字:  请  --*/
/*--  Franklin Gothic Medium12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x00,0x40,0x40,0x40,0x27,0xFC,0x20,0x40,0x03,0xF8,0x00,0x40,0xE7,0xFE,0x20,0x00,
0x23,0xF8,0x22,0x08,0x23,0xF8,0x22,0x08,0x2B,0xF8,0x32,0x08,0x22,0x28,0x02,0x10,
/*--  文字:  点  --*/
0x02,0x00,0x02,0x00,0x02,0x00,0x03,0xFC,0x02,0x00,0x02,0x00,0x3F,0xF0,0x20,0x10,
0x20,0x10,0x20,0x10,0x3F,0xF0,0x00,0x00,0x24,0x88,0x22,0x44,0x42,0x44,0x80,0x04,
/*--  文字:  击  --*/
0x01,0x00,0x01,0x00,0x01,0x00,0x3F,0xF8,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,
0x01,0x00,0x01,0x00,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x3F,0xF8,0x00,0x08,
/*--  文字:  十  --*/
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
/*--  文字:  字  --*/
0x02,0x00,0x01,0x00,0x7F,0xFE,0x40,0x02,0x80,0x04,0x1F,0xE0,0x00,0x40,0x00,0x80,
0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00,
/*--  文字:  光  --*/
0x01,0x00,0x21,0x08,0x11,0x08,0x09,0x10,0x09,0x20,0x01,0x00,0xFF,0xFE,0x04,0x40,
0x04,0x40,0x04,0x40,0x04,0x40,0x08,0x42,0x08,0x42,0x10,0x42,0x20,0x3E,0xC0,0x00,
/*--  文字:  标  --*/
0x10,0x00,0x11,0xFC,0x10,0x00,0x10,0x00,0xFC,0x00,0x13,0xFE,0x30,0x20,0x38,0x20,
0x55,0x28,0x55,0x24,0x92,0x24,0x12,0x22,0x14,0x22,0x10,0x20,0x10,0xA0,0x10,0x40,
/*--  文字:  校  --*/
0x10,0x40,0x10,0x20,0x10,0x20,0x11,0xFE,0xFC,0x00,0x10,0x88,0x31,0x04,0x3A,0x02,
0x54,0x88,0x50,0x88,0x90,0x50,0x10,0x50,0x10,0x20,0x10,0x50,0x10,0x88,0x13,0x06,
/*--  文字:  正  --*/
0x00,0x00,0x7F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x11,0x00,0x11,0xF8,
0x11,0x00,0x11,0x00,0x11,0x00,0x11,0x00,0x11,0x00,0x11,0x00,0xFF,0xFE,0x00,0x00,
/*--  文字:  触  --*/
0x20,0x20,0x20,0x20,0x78,0x20,0x49,0xFC,0x91,0x24,0x7D,0x24,0x55,0x24,0x55,0x24,
0x7D,0xFC,0x55,0x24,0x54,0x20,0x7C,0x28,0x54,0x24,0x57,0xFE,0x45,0x02,0x8C,0x00,
/*--  文字:  摸  --*/
0x11,0x10,0x11,0x10,0x17,0xFC,0x11,0x10,0xFC,0x00,0x13,0xF8,0x12,0x08,0x17,0xF8,
0x1A,0x08,0x33,0xF8,0xD0,0x40,0x17,0xFC,0x10,0xA0,0x11,0x10,0x52,0x08,0x24,0x06,
/*--  文字:  屏  --*/
0x00,0x00,0x3F,0xF8,0x20,0x08,0x20,0x08,0x3F,0xF8,0x24,0x10,0x22,0x20,0x2F,0xF8,
0x22,0x20,0x22,0x20,0x3F,0xFC,0x22,0x20,0x42,0x20,0x44,0x20,0x84,0x20,0x08,0x20,
/*--  文字:  。  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x18,0x00,0x24,0x00,0x24,0x00,0x18,0x00,0x00,0x00,0x00,0x00,
struct fbcon_font_desc font_vga_16x16 = {
    VGA16x16_IDX,
    "VGA16x16",
    16,
    16,
    fontdata_16x16,
    0
显示汉字:
	int xleft = 300;
	int ytop = yres / 4 + 50;
	put_chinese_char(xleft + 16*0, ytop + 0 ,0, 1);
	put_chinese_char(xleft + 16*1, ytop + 0 ,1, 1);
	put_chinese_char(xleft + 16*2, ytop + 0 ,2, 1);
	put_chinese_char(xleft + 16*3, ytop + 0 ,3, 1);
	put_chinese_char(xleft + 16*4, ytop + 0 ,4, 1);
	put_chinese_char(xleft + 16*5, ytop + 0 ,5, 1);
	put_chinese_char(xleft + 16*6, ytop + 0 ,6, 1);
	put_chinese_char(xleft + 16*7, ytop + 0 ,7, 1);
	put_chinese_char(xleft + 16*8, ytop + 0 ,8, 1);
	put_chinese_char(xleft + 16*9, ytop + 0 ,9, 1);
	put_chinese_char(xleft + 16*10, ytop + 0 ,10, 1);
	put_chinese_char(xleft + 16*11, ytop + 0 ,11, 1);
	put_chinese_char(xleft + 16*12, ytop + 0 ,12, 1);
就这样搞定!
楼主 #7 2018-04-13 16:45:33
已发帖子: 9,473
交叉编译到机器上面运行。
楼主 #8 2018-04-13 17:10:39
已发帖子: 9,473
占位
#9 2018-04-13 21:14:19
daydayup
已发帖子: 343
厉害了大神,我是来学习的。
#10 2018-04-14 08:56:47
小猪佩奇
已发帖子: 59
厉害了
#11 2018-04-21 10:16:44
kgp0213
已发帖子: 149
厉害了,大神,就是把汉字的编码指向字库所在的位置
#12 2018-04-26 06:14:06
xinxiaoci
已发帖子: 71
厉害了晕哥,你这精力跟充沛啊!赶不上,只能膜拜
#13 2018-07-06 15:54:49
BugActiveDaughter
已发帖子: 118
厉害了晕哥
#14 2020-04-28 13:48:08
9990
有没有好用的字模提取工具
#15 2020-09-21 12:41:13
hukolau
厉害了
#16 2020-09-22 18:55:32
shawn.d
已发帖子: 164
这个可以有,哈哈,每天晕哥都在进步!
#17 2020-09-22 22:15:30
sprintf
已发帖子: 50
shawn.d wrote:
这个可以有,哈哈,每天晕哥都在进步!
同学你眼花了,这个是晕哥 18年发的。所以晕哥已经进步了两年你才发现=。=
#18 2021-01-18 15:33:01
大帅
已发帖子: 169
/files/members/3/QQ20180413170153.png
还算顺利, 差不多搞定了。
怎么是显示在虚拟机上?
#19 2022-05-05 01:00:01
liozeng
已发帖子: 25
这个实现中文显示。目前在研究字体
