楼主 # 2023-01-25 23:41:06
memory
已发帖子: 712
全志G2D用的是 FIMG2D(三星 ip) ?
https://linux-sunxi.org/Used_IP_cores
Allwinner implementation used. Might have connection to Exynos G2D.
https://android.googlesource.com/kernel/common.git/+/e4404fab2e0b70287a471a1e760c9338ce683fde/Documentation/devicetree/bindings/drm/exynos/g2d.txt
Samsung 2D Graphic Accelerator using DRM frame work
Samsung FIMG2D is a graphics 2D accelerator which supports Bit Block Transfer.
We set the drawing-context registers for configuring rendering parameters and
then start rendering.
This driver is for SOCs which contain G2D IPs with version 4.1.
Required properties:
-compatible:
should be "samsung,exynos-g2d-41".
-reg:
physical base address of the controller and length
of memory mapped region.
-interrupts:
interrupt combiner values.
Example:
g2d {
compatible = "samsung,exynos-g2d-41";
reg = <0x10850000 0x1000>;
interrupts = <0 91 0>;
楼主 #1 2023-01-25 23:42:03
memory
已发帖子: 712
Re: 全志G2D用的是 FIMG2D(三星 ip) ?
#2 2023-01-28 08:56:28
sokou
已发帖子: 58
D1S这款芯片吗?
楼主 #3 2023-01-28 10:34:24
memory
已发帖子: 712
sokou wrote:
D1S这款芯片吗?
是的,全志所有支持G2D功能的芯片都是这个IP,包括D1S
#5 2023-04-02 09:35:33
shaoxi2010
已发帖子: 399
这个是怎看出来的呢?
